root/radiance/ray/src/meta/plotin.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (21 years, 8 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 1.1: +104 -81 lines
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.2 static const char RCSid[] = "$Id: plotin.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Program to convert plot(5) files to metafiles
6     *
7     * cc -o plotin plotin.c primout.o mfio.o syscalls.o misc.o -lm
8     *
9     * 5/20/85
10     */
11
12 schorsch 1.2 #include <string.h>
13
14 greg 1.1 #include "meta.h"
15 schorsch 1.2 #include "plot.h"
16 greg 1.1
17     #define getsi(f, m) ICONV(geti(f)-(m), size)
18
19
20
21     char *progname;
22
23     static int xmin = 0, ymin = 0, /* current space settings */
24     size = XYSIZE;
25
26     static int curx = -1, /* current position */
27     cury = -1;
28
29     static short curmod = 0; /* current line drawing mode */
30
31 schorsch 1.2 static void convert(FILE *infp);
32     static int geti(FILE *fp);
33     static int quadr(int x, int y, int xp, int yp);
34     static void step(int d);
35
36     static void linemod(char s[]);
37     static void erase(void);
38     static void space(int xmn, int ymn, int xmx, int ymx);
39     static void move(int x, int y);
40     static void cont(int x, int y);
41     static void line(int x0, int y0, int x1, int y1);
42     static void label(register char *s);
43     static void point(int x, int y);
44     static void arc(int x, int y, int x0, int y0, int x1, int y1);
45     static void circle(int x, int y, int r);
46 greg 1.1
47
48 schorsch 1.2 int
49     main(
50     int argc,
51     char **argv
52     )
53 greg 1.1 {
54     FILE *fp;
55
56     progname = *argv++;
57     argc--;
58
59     while (argc && **argv == '-') {
60     switch (*(*argv+1)) {
61     default:
62     error(WARNING, "unknown option");
63     break;
64     }
65     argv++;
66     argc--;
67     }
68
69     if (argc)
70     while (argc) {
71     fp = efopen(*argv, "r");
72     convert(fp);
73     fclose(fp);
74     argv++;
75     argc--;
76     }
77     else
78     convert(stdin);
79
80     pglob(PEOF, 0200, NULL);
81
82     return(0);
83 schorsch 1.2 }
84 greg 1.1
85
86
87
88 schorsch 1.2 void
89     convert( /* convert to meta-file */
90     FILE *infp
91     )
92 greg 1.1 {
93     char *fgets(), sbuf[BUFSIZ];
94     int command;
95     int a1, a2, a3, a4, a5, a6;
96
97     while ((command = getc(infp)) != EOF)
98     switch (command) {
99     case 'm':
100     a1 = getsi(infp, xmin);
101     a2 = getsi(infp, ymin);
102     move(a1, a2);
103     break;
104     case 'n':
105     a1 = getsi(infp, xmin);
106     a2 = getsi(infp, ymin);
107     cont(a1, a2);
108     break;
109     case 'p':
110     a1 = getsi(infp, xmin);
111     a2 = getsi(infp, ymin);
112     point(a1, a2);
113     break;
114     case 'l':
115     a1 = getsi(infp, xmin);
116     a2 = getsi(infp, ymin);
117     a3 = getsi(infp, xmin);
118     a4 = getsi(infp, ymin);
119     line(a1, a2, a3, a4);
120     break;
121     case 't':
122     fgets(sbuf, sizeof(sbuf), infp);
123     sbuf[strlen(sbuf)-1] = '\0';
124     label(sbuf);
125     break;
126     case 'a':
127     a1 = getsi(infp, xmin);
128     a2 = getsi(infp, ymin);
129     a3 = getsi(infp, xmin);
130     a4 = getsi(infp, ymin);
131     a5 = getsi(infp, xmin);
132     a6 = getsi(infp, ymin);
133     arc(a1, a2, a3, a4, a5, a6);
134     break;
135     case 'c':
136     a1 = getsi(infp, xmin);
137     a2 = getsi(infp, ymin);
138     a3 = getsi(infp, 0);
139     circle(a1, a2, a3);
140     break;
141     case 'e':
142     erase();
143     break;
144     case 'f':
145     fgets(sbuf, sizeof(sbuf), infp);
146     linemod(sbuf);
147     break;
148     case 's':
149     a1 = geti(infp);
150     a2 = geti(infp);
151     a3 = geti(infp);
152     a4 = geti(infp);
153     space(a1, a2, a3, a4);
154     break;
155     default:
156     error(USER, "unknown command in convert");
157     break;
158     }
159     }
160
161
162
163
164     int
165 schorsch 1.2 geti( /* get two-byte integer from file */
166     register FILE *fp
167     )
168 greg 1.1 {
169     register int i;
170
171     i = getc(fp);
172     i |= getc(fp) << 8;
173     if (i & 0100000)
174     i |= ~0177777; /* manual sign extend */
175     if (feof(fp))
176     error(USER, "unexpected end of file in geti");
177
178     return(i);
179     }
180
181
182
183 schorsch 1.2 void
184     move( /* move to new position */
185     register int x,
186     register int y
187     )
188 greg 1.1 {
189     curx = x;
190     cury = y;
191     }
192
193
194
195 schorsch 1.2 void
196     cont( /* draw line to point */
197     register int x,
198     register int y
199     )
200 greg 1.1 {
201     plseg(curmod, curx, cury, x, y);
202     curx = x;
203     cury = y;
204     }
205
206
207 schorsch 1.2 void
208     point( /* draw a point */
209     register int x,
210     register int y
211     )
212 greg 1.1 {
213     plseg(0, x, y, x, y);
214     curx = x;
215     cury = y;
216     }
217
218
219
220 schorsch 1.2 void
221     line( /* draw a line segment */
222     int x0,
223     int y0,
224     int x1,
225     int y1
226     )
227 greg 1.1 {
228     move(x0, y0);
229     cont(x1, y1);
230     }
231
232
233 schorsch 1.2 void
234     label( /* print a label */
235     register char *s
236     )
237 greg 1.1 {
238     pprim(PMSTR, 0, curx, cury, curx, cury, s);
239     }
240
241
242
243 schorsch 1.2 static int del = 100;
244 greg 1.1
245 schorsch 1.2 void
246     step(
247     int d
248     )
249     {
250 greg 1.1 del = d;
251     }
252 schorsch 1.2
253     void
254     arc(
255     int x,
256     int y,
257     int x0,
258     int y0,
259     int x1,
260     int y1
261     )
262     {
263 greg 1.1 double pc;
264     double sqrt();
265     int flg,m,xc,yc,xs,ys,qs,qf;
266     float dx,dy,r;
267     char use;
268     dx = x-x0;
269     dy = y-y0;
270     r = dx*dx+dy*dy;
271     pc = r;
272     pc = sqrt(pc);
273     flg = pc/4;
274     if(flg == 0)step(1);
275     else if(flg < del)step(flg);
276     xc = xs = x0;
277     yc = ys = y0;
278     move(xs,ys);
279     if(x0 == x1 && y0 == y1)flg=0;
280     else flg=1;
281     qs = quadr(x,y,x0,y0);
282     qf = quadr(x,y,x1,y1);
283     if(abs(x-x1) < abs(y-y1)){
284     use = 'x';
285     if(qs == 2 || qs ==3)m = -1;
286     else m=1;
287     }
288     else {
289     use = 'y';
290     if(qs > 2)m= -1;
291     else m= 1;
292     }
293     while(1){
294     switch(use){
295     case 'x':
296     if(qs == 2 || qs == 3)yc -= del;
297     else yc += del;
298     dy = yc-y;
299     pc = r-dy*dy;
300     xc = m*sqrt(pc)+x;
301     if((x < xs && x >= xc) || ( x > xs && x <= xc) ||
302     (y < ys && y >= yc) || ( y > ys && y <= yc) )
303     {
304     if(++qs > 4)qs=1;
305     if(qs == 2 || qs == 3)m= -1;
306     else m=1;
307     flg=1;
308     }
309     cont(xc,yc);
310     xs = xc;
311     ys = yc;
312     if(qs == qf && flg == 1)
313     switch(qf){
314     case 3:
315     case 4:
316     if(xs >= x1)return;
317     continue;
318     case 1:
319     case 2:
320     if(xs <= x1)return;
321     }
322     continue;
323     case 'y':
324     if(qs > 2)xc += del;
325     else xc -= del;
326     dx = xc-x;
327     pc = r-dx*dx;
328     yc = m*sqrt(pc)+y;
329     if((x < xs && x >= xc) || ( x > xs && x <= xc ) ||
330     (y < ys && y >= yc) || (y > ys && y <= yc) )
331     {
332     if(++qs > 4)qs=1;
333     if(qs > 2)m = -1;
334     else m = 1;
335     flg=1;
336     }
337     cont(xc,yc);
338     xs = xc;
339     ys = yc;
340     if(qs == qf && flg == 1)
341     switch(qs){
342     case 1:
343     case 4:
344     if(ys >= y1)return;
345     continue;
346     case 2:
347     case 3:
348     if(ys <= y1)return;
349     }
350     }
351     }
352     }
353 schorsch 1.2
354     int
355     quadr(
356     int x,
357     int y,
358     int xp,
359     int yp
360     )
361     {
362 greg 1.1 if(x < xp)
363     if(y <= yp)return(1);
364     else return(4);
365     else if(x > xp)
366     if(y < yp)return(2);
367     else return(3);
368     else if(y < yp)return(2);
369     else return(4);
370     }
371
372
373 schorsch 1.2 void
374     circle(
375     int x,
376     int y,
377     int r
378     )
379     {
380 greg 1.1 arc(x,y,x+r,y,x+r,y);
381     }
382
383
384
385 schorsch 1.2 void
386     erase(void) /* erase plot */
387 greg 1.1 {
388     pglob(PEOP, 0200, NULL);
389     }
390
391
392 schorsch 1.2 void
393     linemod( /* set line mode according to s */
394     char s[]
395     )
396 greg 1.1 {
397     switch (s[2]) {
398     case 'l': /* solid */
399     curmod = 0;
400     break;
401     case 't': /* dotted */
402     curmod = 1;
403     break;
404     case 'n': /* long dashed */
405     curmod = 2;
406     break;
407     case 'o': /* short dashed (dot dashed) */
408     curmod = 3;
409     break;
410     default:
411     error(WARNING, "unknown line mode in linemod");
412     break;
413     }
414     }
415
416
417 schorsch 1.2 void
418     space( /* change space */
419     int xmn,
420     int ymn,
421     int xmx,
422     int ymx
423     )
424 greg 1.1 {
425     if (xmn >= xmx || ymn >= ymx)
426     error(USER, "illegal space specification in space");
427
428     xmin = xmn;
429     ymin = ymn;
430     size = min(xmx-xmn, ymx-ymn);
431     }
