root/Development/ray/src/meta/plot.c
Revision: 1.3
Committed: Sat Nov 15 02:13:37 2003 UTC (22 years, 1 month ago) by schorsch
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6, HEAD
Changes since 1.2: +4 -5 lines
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.3 static const char RCSid[] = "$Id: plot.c,v 1.2 2003/06/08 12:03:10 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Plotting routines for meta-files
6     */
7
8
9 schorsch 1.3 #include "rtio.h"
10 greg 1.1 #include "meta.h"
11     #include "plot.h"
12
13
14     int pati[4] = {0, 1, 2, 3}; /* pattern indices */
15
16     /*
17     * Patterns are 16 X 16, ordered left to right, bottom to top.
18     * Each byte represents a column in an 8-bit high row.
19     */
20
21     unsigned char pattern[NPATS+4][PATSIZE/8][PATSIZE] = {
22     { /* solid */
23     {
24     0377,0377,0377,0377,0377,0377,0377,0377,
25     0377,0377,0377,0377,0377,0377,0377,0377
26     }, {
27     0377,0377,0377,0377,0377,0377,0377,0377,
28     0377,0377,0377,0377,0377,0377,0377,0377
29     }
30     }, { /* thick \\\ (dashed) */
31     {
32     0377,0177,077,037,017,0207,0303,0341,
33     0360,0370,0374,0376,0377,0377,0377,0377
34     }, {
35     0360,0370,0374,0376,0377,0377,0377,0377,
36     0377,0177,077,037,017,0207,0303,0341
37     }
38     }, { /* thin \\\ (dotted) */
39     {
40     0314,0146,063,0231,0314,0146,063,0231,
41     0314,0146,063,0231,0314,0146,063,0231
42     }, {
43     0314,0146,063,0231,0314,0146,063,0231,
44     0314,0146,063,0231,0314,0146,063,0231
45     }
46     }, { /* mix \\\ (dotted-dashed) */
47     {
48     0376,0177,077,037,0217,0307,0343,0161,
49     070,034,0216,0307,0343,0361,0370,0374
50     }, {
51     070,034,0216,0307,0343,0361,0370,0374,
52     0376,0177,077,037,0217,0307,0343,0161
53     }
54     }, { /* thick /// (dashed) */
55     {
56     0377,0377,0377,0377,0376,0374,0370,0360,
57     0341,0303,0207,017,037,077,0177,0377
58     }, {
59     0341,0303,0207,017,037,077,0177,0377,
60     0377,0377,0377,0377,0376,0374,0370,0360
61     }
62     }, { /* thin /// (dotted) */
63     {
64     0231,063,0146,0314,0231,063,0146,0314,
65     0231,063,0146,0314,0231,063,0146,0314
66     }, {
67     0231,063,0146,0314,0231,063,0146,0314,
68     0231,063,0146,0314,0231,063,0146,0314
69     }
70     }, { /* mix /// (dotted-dashed) */
71     {
72     0374,0370,0361,0343,0307,0216,034,070,
73     0161,0343,0307,0217,037,077,0177,0376
74     }, {
75     0161,0343,0307,0217,037,077,0177,0376,
76     0374,0370,0361,0343,0307,0216,034,070
77     }
78     }, { /* crisscross */
79     {
80     0201,0102,044,030,030,044,0102,0201,
81     0201,0102,044,030,030,044,0102,0201
82     }, {
83     0201,0102,044,030,030,044,0102,0201,
84     0201,0102,044,030,030,044,0102,0201
85     }
86     }, { /* web */
87     {
88     0377,0300,0240,0220,0210,0204,0202,0201,
89     0201,0202,0204,0210,0220,0240,0300,0200
90     }, {
91     0377,02,04,010,020,040,0100,0200,
92     0200,0100,040,020,010,04,02,01
93     }
94     }
95     };
96
97     static int context = 0;
98
99     struct setting {
100     int cnx; /* setting context */
101     char *val; /* attribute value */
102     struct setting *snext; /* next setting in list */
103     };
104
105     static struct setting *sets[0200];
106
107 schorsch 1.2 static void spop(int attrib);
108     static int spat(int pat, char *patval);
109 greg 1.1
110 schorsch 1.2 void
111     set( /* set attribute to value */
112     int attrib,
113     char *value
114     )
115 greg 1.1 {
116     struct setting *newset;
117
118     switch (attrib) {
119     case SALL:
120     context++;
121     return;
122     case SPAT0:
123     case SPAT1:
124     case SPAT2:
125     case SPAT3:
126     if (!spat(attrib, value)) {
127     sprintf(errmsg, "Bad pattern set value: %s", value);
128     error(WARNING, errmsg);
129     return;
130     }
131     break;
132     default:
133     sprintf(errmsg, "Can't set attribute: %o", attrib);
134     error(WARNING, errmsg);
135     return;
136     }
137     newset = (struct setting *)malloc(sizeof(struct setting));
138     newset->cnx = context;
139     newset->val = savestr(value);
140     newset->snext = sets[attrib];
141     sets[attrib] = newset;
142     }
143
144
145
146 schorsch 1.2 void
147     unset( /* return attribute to previous setting */
148     int attrib
149     )
150 greg 1.1 {
151     register int i;
152
153     if (attrib == SALL) {
154     if (context == 0)
155     reset(SALL);
156     else {
157     context--;
158     for (i = 0; i < 0200; i++)
159     while (sets[i] != NULL && sets[i]->cnx > context)
160     spop(i);
161     }
162     return;
163     }
164     spop(attrib);
165     if (sets[attrib] == NULL)
166     reset(attrib);
167
168     switch (attrib) {
169     case SPAT0:
170     case SPAT1:
171     case SPAT2:
172     case SPAT3:
173     spat(attrib, sets[attrib]->val);
174     break;
175     default:
176     sprintf(errmsg, "Can't unset attribute: %o", attrib);
177     error(WARNING, errmsg);
178     return;
179     }
180     }
181
182
183
184 schorsch 1.2 void
185     reset( /* return attribute to default setting */
186     int attrib
187     )
188 greg 1.1 {
189     switch (attrib) {
190     case SALL:
191     reset(SPAT0);
192     reset(SPAT1);
193     reset(SPAT2);
194     reset(SPAT3);
195     context = 0;
196     return;
197     case SPAT0:
198     spat(SPAT0, "P0");
199     break;
200     case SPAT1:
201     spat(SPAT1, "P1");
202     break;
203     case SPAT2:
204     spat(SPAT2, "P2");
205     break;
206     case SPAT3:
207     spat(SPAT3, "P3");
208     break;
209     default:
210     sprintf(errmsg, "Can't reset attribute: %o", attrib);
211     error(WARNING, errmsg);
212     return;
213     }
214     while (sets[attrib] != NULL)
215     spop(attrib);
216     }
217
218
219
220 schorsch 1.2 static void
221     spop( /* pop top off attrib settings list */
222     int attrib
223     )
224 greg 1.1 {
225
226     if (sets[attrib] != NULL) {
227     if (sets[attrib]->val != NULL)
228     freestr(sets[attrib]->val);
229     free((char *)sets[attrib]);
230     sets[attrib] = sets[attrib]->snext;
231     }
232
233     }
234
235
236
237     static int
238 schorsch 1.2 spat( /* set a pattern */
239     int pat,
240     char *patval
241     )
242 greg 1.1 {
243     int n, i, j, v;
244     register char *cp;
245
246     if (patval == NULL) return(FALSE);
247
248     if (patval[0] == 'P' || patval[0] == 'p') {
249 schorsch 1.3 if (nextscan(patval+1, "%d", (char*)&n) == NULL || n < 0 || n >= NPATS)
250 greg 1.1 return(FALSE);
251     } else {
252     n = NPATS + pat - SPAT0;
253     cp = patval;
254     for (i = 0; i < PATSIZE>>3; i++)
255     for (j = 0; j < PATSIZE; j++) {
256 schorsch 1.3 if ((cp = nextscan(cp, "%o", (char*)&v)) == NULL || v < 0 || v > 0377)
257 greg 1.1 return(FALSE);
258     pattern[n][i][j] = v;
259     }
260     }
261     pati[pat-SPAT0] = n;
262     return(TRUE);
263     }
