root/radiance/ray/src/meta/misc.c
Revision: 1.2
Committed: Thu Jul 3 22:41:44 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 1.1: +1 -2 lines
2 static const char RCSid[] = "$Id: misc.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * Miscellaneous functions for meta-files
6 */
7
8
9 #include "meta.h"
10
11
12 char coms[] = COML;
13
14 char errmsg[128];
15
16
17
18 error(errtype, emsg) /* report error */
19
20 int errtype;
21 char *emsg;
22
23 {
24
25 switch (errtype) {
26
27 case WARNING:
28 wputs(progname);
29 wputs(": warning - ");
30 wputs(emsg);
31 wputs("\n");
32 break;
33
34 case USER:
35 eputs(progname);
36 eputs(": fatal - ");
37 eputs(emsg);
38 eputs("\n");
39 exit(1);
40 break;
41
42 case SYSTEM:
43 eputs(progname);
44 eputs(": system - ");
45 eputs(emsg);
46 eputs("\n");
47 exit(1);
48 break;
49 }
50
51 }
52
53
54
55
56 int
57 comndx(c) /* return index for command */
58
59 register int c;
60
61 {
62 register char *cp;
63
64 if (!isalpha(c))
65 return(-1);
66
67 for (cp = coms; *cp; cp++)
68 if(*cp == c)
69 return(cp-coms);
70
71 return(-1);
72 }
73
74
75
76
77
78
79 PRIMITIVE *
80 pop(pl) /* pop top off plist */
81
82 register PLIST *pl;
83
84 {
85 register PRIMITIVE *p;
86
87 if ((p = pl->ptop) != NULL) {
88 if ((pl->ptop = p->pnext) == NULL)
89 pl->pbot = NULL;
90 p->pnext = NULL;
91 }
92
93 return(p);
94 }
95
96
97
98
99 push(p, pl) /* push primitive onto plist */
100
101 register PRIMITIVE *p;
102 register PLIST *pl;
103
104 {
105
106 if ((p->pnext = pl->ptop) == NULL)
107 pl->pbot = p;
108 pl->ptop = p;
109
110 }
111
112
113
114
115 add(p, pl) /* add primitive to plist */
116
117 register PRIMITIVE *p;
118 register PLIST *pl;
119
120 {
121
122 if (pl->ptop == NULL)
123 pl->ptop = p;
124 else
125 pl->pbot->pnext = p;
126 p->pnext = NULL;
127 pl->pbot = p;
128
129 }
130
131
132
133
134 append(pl1, pl2) /* append pl1 to the end of pl2 */
135
136 register PLIST *pl1, *pl2;
137
138 {
139
140 if (pl1->ptop != NULL) {
141 if (pl2->ptop != NULL)
142 pl2->pbot->pnext = pl1->ptop;
143 else
144 pl2->ptop = pl1->ptop;
145 pl2->pbot = pl1->pbot;
146 }
147
148 }
149
150
151
152
153 fargs(p) /* free any arguments p has */
154
155 register PRIMITIVE *p;
156
157 {
158
159 if (p->args != NULL) {
160 freestr(p->args);
161 p->args = NULL;
162 }
163
164 }
165
166
167
168 char *
169 nextscan(start, format, result) /* scan and advance through string */
170
171 register char *start;
172 char *format;
173 char *result;
174
175 {
176
177 if (start == NULL) return(NULL);
178
179 while (isspace(*start)) start++;
180
181 if (sscanf(start, format, result) != 1) return(NULL);
182
183 while (*start && !isspace(*start)) start++;
184
185 return(start);
186 }
187
188
189
190 mcopy(p1, p2, n) /* copy p2 into p1 size n */
191
192 register char *p1, *p2;
193 register int n;
194
195 {
196
197 while (n--)
198 *p1++ = *p2++;
199
200 }
201
