root/radiance/ray/src/meta/misc.c
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years, 3 months ago) by greg
5 * Miscellaneous functions for meta-files
6 */
7
8
9 #include "meta.h"
10
11
12
13 char coms[] = COML;
14
15 char errmsg[128];
16
17
18
19 error(errtype, emsg) /* report error */
20
21 int errtype;
22 char *emsg;
23
24 {
25
26 switch (errtype) {
27
28 case WARNING:
29 wputs(progname);
30 wputs(": warning - ");
31 wputs(emsg);
32 wputs("\n");
33 break;
34
35 case USER:
36 eputs(progname);
37 eputs(": fatal - ");
38 eputs(emsg);
39 eputs("\n");
40 exit(1);
41 break;
42
43 case SYSTEM:
44 eputs(progname);
45 eputs(": system - ");
46 eputs(emsg);
47 eputs("\n");
48 exit(1);
49 break;
50 }
51
52 }
53
54
55
56
57 int
58 comndx(c) /* return index for command */
59
60 register int c;
61
62 {
63 register char *cp;
64
65 if (!isalpha(c))
66 return(-1);
67
68 for (cp = coms; *cp; cp++)
69 if(*cp == c)
70 return(cp-coms);
71
72 return(-1);
73 }
74
75
76
77
78
79
80 PRIMITIVE *
81 pop(pl) /* pop top off plist */
82
83 register PLIST *pl;
84
85 {
86 register PRIMITIVE *p;
87
88 if ((p = pl->ptop) != NULL) {
89 if ((pl->ptop = p->pnext) == NULL)
90 pl->pbot = NULL;
91 p->pnext = NULL;
92 }
93
94 return(p);
95 }
96
97
98
99
100 push(p, pl) /* push primitive onto plist */
101
102 register PRIMITIVE *p;
103 register PLIST *pl;
104
105 {
106
107 if ((p->pnext = pl->ptop) == NULL)
108 pl->pbot = p;
109 pl->ptop = p;
110
111 }
112
113
114
115
116 add(p, pl) /* add primitive to plist */
117
118 register PRIMITIVE *p;
119 register PLIST *pl;
120
121 {
122
123 if (pl->ptop == NULL)
124 pl->ptop = p;
125 else
126 pl->pbot->pnext = p;
127 p->pnext = NULL;
128 pl->pbot = p;
129
130 }
131
132
133
134
135 append(pl1, pl2) /* append pl1 to the end of pl2 */
136
137 register PLIST *pl1, *pl2;
138
139 {
140
141 if (pl1->ptop != NULL) {
142 if (pl2->ptop != NULL)
143 pl2->pbot->pnext = pl1->ptop;
144 else
145 pl2->ptop = pl1->ptop;
146 pl2->pbot = pl1->pbot;
147 }
148
149 }
150
151
152
153
154 fargs(p) /* free any arguments p has */
155
156 register PRIMITIVE *p;
157
158 {
159
160 if (p->args != NULL) {
161 freestr(p->args);
162 p->args = NULL;
163 }
164
165 }
166
167
168
169 char *
170 nextscan(start, format, result) /* scan and advance through string */
171
172 register char *start;
173 char *format;
174 char *result;
175
176 {
177
178 if (start == NULL) return(NULL);
179
180 while (isspace(*start)) start++;
181
182 if (sscanf(start, format, result) != 1) return(NULL);
183
184 while (*start && !isspace(*start)) start++;
185
186 return(start);
187 }
188
189
190
191 mcopy(p1, p2, n) /* copy p2 into p1 size n */
192
193 register char *p1, *p2;
194 register int n;
195
196 {
197
198 while (n--)
199 *p1++ = *p2++;
200
201 }
202
