--- ray/src/meta/misc.c 2005/09/23 19:22:37 1.5 +++ ray/src/meta/misc.c 2023/06/09 15:25:49 1.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: misc.c,v 1.5 2005/09/23 19:22:37 greg Exp $"; +static const char RCSid[] = "$Id: misc.c,v 1.6 2023/06/09 15:25:49 greg Exp $"; #endif /* * Miscellaneous functions for meta-files @@ -18,11 +18,11 @@ char coms[] = COML; int comndx( /* return index for command */ - register int c + int c ) { - register char *cp; + char *cp; if (!isalpha(c)) return(-1); @@ -41,11 +41,11 @@ comndx( /* return index for command */ PRIMITIVE * pop( /* pop top off plist */ - register PLIST *pl + PLIST *pl ) { - register PRIMITIVE *p; + PRIMITIVE *p; if ((p = pl->ptop) != NULL) { if ((pl->ptop = p->pnext) == NULL) @@ -60,8 +60,8 @@ pop( /* pop top off plist */ void push( /* push primitive onto plist */ - register PRIMITIVE *p, - register PLIST *pl + PRIMITIVE *p, + PLIST *pl ) { @@ -76,8 +76,8 @@ push( /* push primitive onto plist */ void add( /* add primitive to plist */ - register PRIMITIVE *p, - register PLIST *pl + PRIMITIVE *p, + PLIST *pl ) { @@ -94,8 +94,8 @@ add( /* add primitive to plist */ void append( /* append pl1 to the end of pl2 */ - register PLIST *pl1, - register PLIST *pl2 + PLIST *pl1, + PLIST *pl2 ) { @@ -114,7 +114,7 @@ append( /* append pl1 to the end of pl2 */ void fargs( /* free any arguments p has */ -register PRIMITIVE *p +PRIMITIVE *p ) { @@ -130,7 +130,7 @@ register PRIMITIVE *p char * nextscan( /* scan and advance through string */ - register char *start, + char *start, char *format, char *result ) @@ -151,9 +151,9 @@ nextscan( /* scan and advance through string */ void mcopy( /* copy p2 into p1 size n */ -register char *p1, -register char *p2, -register int n +char *p1, +char *p2, +int n ) {
