root/radiance/ray/src/meta/misc.c
Revision: 1.5
Committed: Fri Sep 23 19:22:37 2005 UTC (19 years, 7 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1, rad5R3
Removed some redundant globals
2 static const char RCSid[] = "$Id: misc.c,v 1.4 2003/11/15 02:13:37 schorsch Exp $";
5 * Miscellaneous functions for meta-files
6 */
7
8
9 #include "rtio.h"
10 #include "meta.h"
11
12
13 char coms[] = COML;
14
15 /* char errmsg[128]; redundant to error.c in ../commmon */
16
17
18
19 int
20 comndx( /* return index for command */
21 register int c
22 )
23
24 {
25 register char *cp;
26
27 if (!isalpha(c))
28 return(-1);
29
30 for (cp = coms; *cp; cp++)
31 if(*cp == c)
32 return(cp-coms);
33
34 return(-1);
35 }
36
37
38
39
40
41
42 PRIMITIVE *
43 pop( /* pop top off plist */
44 register PLIST *pl
45 )
46
47 {
48 register PRIMITIVE *p;
49
50 if ((p = pl->ptop) != NULL) {
51 if ((pl->ptop = p->pnext) == NULL)
52 pl->pbot = NULL;
53 p->pnext = NULL;
54 }
55
56 return(p);
57 }
58
59
60
61 void
62 push( /* push primitive onto plist */
63 register PRIMITIVE *p,
64 register PLIST *pl
65 )
66
67 {
68
69 if ((p->pnext = pl->ptop) == NULL)
70 pl->pbot = p;
71 pl->ptop = p;
72
73 }
74
75
76
77 void
78 add( /* add primitive to plist */
79 register PRIMITIVE *p,
80 register PLIST *pl
81 )
82 {
83
84 if (pl->ptop == NULL)
85 pl->ptop = p;
86 else
87 pl->pbot->pnext = p;
88 p->pnext = NULL;
89 pl->pbot = p;
90
91 }
92
93
94
95 void
96 append( /* append pl1 to the end of pl2 */
97 register PLIST *pl1,
98 register PLIST *pl2
99 )
100
101 {
102
103 if (pl1->ptop != NULL) {
104 if (pl2->ptop != NULL)
105 pl2->pbot->pnext = pl1->ptop;
106 else
107 pl2->ptop = pl1->ptop;
108 pl2->pbot = pl1->pbot;
109 }
110
111 }
112
113
114
115 void
116 fargs( /* free any arguments p has */
117 register PRIMITIVE *p
118 )
119
120 {
121
122 if (p->args != NULL) {
123 freestr(p->args);
124 p->args = NULL;
125 }
126
127 }
128
129
130
131 char *
132 nextscan( /* scan and advance through string */
133 register char *start,
134 char *format,
135 char *result
136 )
137
138 {
139
140 if (start == NULL) return(NULL);
141
142 while (isspace(*start)) start++;
143
144 if (sscanf(start, format, result) != 1) return(NULL);
145
146 while (*start && !isspace(*start)) start++;
147
148 return(start);
149 }
150
151
152 void
153 mcopy( /* copy p2 into p1 size n */
154 register char *p1,
155 register char *p2,
156 register int n
157 )
158
159 {
160
161 while (n--)
162 *p1++ = *p2++;
163
164 }
165
