root/radiance/ray/src/meta/misc.c
Fri Sep 23 19:22:37 2005 UTC (19 years, 8 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 1.4
Removed some redundant globals
Sat Nov 15 02:13:37 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.3: +38 -36 lines
Diff to previous 1.3
Continued ANSIfication, and reduced other compile warnings.
Mon Jul 14 16:05:45 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.2: +1 -39 lines
Diff to previous 1.2
Changed to relying on error() call in Radiance library
Thu Jul 3 22:41:44 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +1 -2 lines
Diff to previous 1.1
Sat Feb 22 02:07:26 2003 UTC (22 years, 3 months ago) by greg
