root/radiance/ray/src/meta/misc.c
Revision: 1.3
Committed: Mon Jul 14 16:05:45 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.2: +1 -39 lines
Changed to relying on error() call in Radiance library
2 static const char RCSid[] = "$Id: misc.c,v 1.2 2003/07/03 22:41:44 schorsch Exp $";
5 * Miscellaneous functions for meta-files
6 */
7
8
9 #include "meta.h"
10
11
12 char coms[] = COML;
13
14 char errmsg[128];
15
16
17
18 int
19 comndx(c) /* return index for command */
20
21 register int c;
22
23 {
24 register char *cp;
25
26 if (!isalpha(c))
27 return(-1);
28
29 for (cp = coms; *cp; cp++)
30 if(*cp == c)
31 return(cp-coms);
32
33 return(-1);
34 }
35
36
37
38
39
40
41 PRIMITIVE *
42 pop(pl) /* pop top off plist */
43
44 register PLIST *pl;
45
46 {
47 register PRIMITIVE *p;
48
49 if ((p = pl->ptop) != NULL) {
50 if ((pl->ptop = p->pnext) == NULL)
51 pl->pbot = NULL;
52 p->pnext = NULL;
53 }
54
55 return(p);
56 }
57
58
59
60
61 push(p, pl) /* push primitive onto plist */
62
63 register PRIMITIVE *p;
64 register PLIST *pl;
65
66 {
67
68 if ((p->pnext = pl->ptop) == NULL)
69 pl->pbot = p;
70 pl->ptop = p;
71
72 }
73
74
75
76
77 add(p, pl) /* add primitive to plist */
78
79 register PRIMITIVE *p;
80 register PLIST *pl;
81
82 {
83
84 if (pl->ptop == NULL)
85 pl->ptop = p;
86 else
87 pl->pbot->pnext = p;
88 p->pnext = NULL;
89 pl->pbot = p;
90
91 }
92
93
94
95
96 append(pl1, pl2) /* append pl1 to the end of pl2 */
97
98 register PLIST *pl1, *pl2;
99
100 {
101
102 if (pl1->ptop != NULL) {
103 if (pl2->ptop != NULL)
104 pl2->pbot->pnext = pl1->ptop;
105 else
106 pl2->ptop = pl1->ptop;
107 pl2->pbot = pl1->pbot;
108 }
109
110 }
111
112
113
114
115 fargs(p) /* free any arguments p has */
116
117 register PRIMITIVE *p;
118
119 {
120
121 if (p->args != NULL) {
122 freestr(p->args);
123 p->args = NULL;
124 }
125
126 }
127
128
129
130 char *
131 nextscan(start, format, result) /* scan and advance through string */
132
133 register char *start;
134 char *format;
135 char *result;
136
137 {
138
139 if (start == NULL) return(NULL);
140
141 while (isspace(*start)) start++;
142
143 if (sscanf(start, format, result) != 1) return(NULL);
144
145 while (*start && !isspace(*start)) start++;
146
147 return(start);
148 }
149
150
151
152 mcopy(p1, p2, n) /* copy p2 into p1 size n */
153
154 register char *p1, *p2;
155 register int n;
156
157 {
158
159 while (n--)
160 *p1++ = *p2++;
161
162 }
163
