root/radiance/ray/src/meta/mgvars.h
Revision: 1.4
Committed: Sat Nov 15 02:13:37 2003 UTC (20 years, 6 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 schorsch 1.4 /* RCSid: $Id: mgvars.h,v 1.3 2003/11/14 00:14:40 schorsch Exp $ */
2 greg 1.1 /*
3     * mgvars.h - header file for graphing routines using variables.
4     *
5     * 6/23/86
6     *
7     * Greg Ward Larson
8     */
9 schorsch 1.2 #ifndef _RAD_MGVARS_H_
10     #define _RAD_MGVARS_H_
11
12     #include <errno.h>
13
14 schorsch 1.3 #include "calcomp.h"
15
16 schorsch 1.2 #ifdef __cplusplus
17     extern "C" {
18     #endif
19 greg 1.1
20     /*
21     * Data arrays are used to store point data.
22     */
23
24     typedef struct {
25     int size; /* the size of the array */
26     float *data; /* pointer to the array */
27     } DARRAY;
28
29     /*
30     * Intermediate variables are not referenced
31     * directly by the program, but may be used
32     * for defining other variables.
33     */
34
35     typedef struct ivar {
36     char *name; /* the variable name */
37     char *dfn; /* its definition */
38     struct ivar *next; /* next in list */
39     } IVAR; /* an intermediate variable */
40
41     /*
42     * Variables are used for all graph parameters. The four variable
43     * types are: REAL, FUNCTION, STRING and DATA.
44     * Of these, only STRING and DATA must be interpreted by us; an
45     * expression parser will handle the rest.
46     */
47     /* standard variables */
48     #define FTHICK 0 /* frame thickness */
49     #define GRID 1 /* grid on? */
50     #define LEGEND 2 /* legend title */
51     #define OTHICK 3 /* origin thickness */
52     #define PERIOD 4 /* period of polar plot */
53     #define SUBTITLE 5 /* subtitle */
54     #define SYMFILE 6 /* symbol file */
55     #define TSTYLE 7 /* tick mark style */
56     #define TITLE 8 /* title */
57     #define XLABEL 9 /* x axis label */
58     #define XMAP 10 /* x axis mapping */
59     #define XMAX 11 /* x axis maximum */
60     #define XMIN 12 /* x axis minimum */
61     #define XSTEP 13 /* x axis step */
62     #define YLABEL 14 /* y axis label */
63     #define YMAP 15 /* y axis mapping */
64     #define YMAX 16 /* y axis maximum */
65     #define YMIN 17 /* y axis minimum */
66     #define YSTEP 18 /* y axis step */
67
68     #define NVARS 19 /* number of standard variables */
69
70     /* curve variables */
71     #define C 0 /* the curve function */
72     #define CCOLOR 1 /* the curve color */
73     #define CDATA 2 /* the curve data */
74     #define CLABEL 3 /* the curve label */
75     #define CLINTYPE 4 /* the curve line type */
76     #define CNPOINTS 5 /* number of curve points to plot */
77     #define CSYMSIZE 6 /* the curve symbol size */
78     #define CSYMTYPE 7 /* the curve symbol type */
79     #define CTHICK 8 /* the curve line thickness */
80
81     #define NCVARS 9 /* number of curve variables */
82
83     #define MAXCUR 8 /* maximum number of curves */
84
85     /* types */
86     #define REAL 1 /* floating point */
87     #define STRING 2 /* character array */
88     #define FUNCTION 3 /* function definition */
89     #define DATA 4 /* a set of real points */
90
91     /* flags */
92     #define DEFINED 01 /* variable is defined */
93
94     typedef struct {
95     char *name; /* the variable name */
96     short type; /* the variable type */
97     char *descrip; /* brief description */
98     unsigned short flags; /* DEFINED, etc. */
99     union {
100     char *s; /* STRING value */
101     DARRAY d; /* DATA value */
102     char *dfn; /* variable definition */
103     } v; /* value */
104     } VARIABLE; /* a variable */
105
106     extern IVAR *ivhead; /* the intermediate list */
107
108     extern VARIABLE gparam[NVARS]; /* the graph variables */
109     extern VARIABLE cparam[MAXCUR][NCVARS]; /* the curve variables */
110
111     extern VARIABLE *vlookup();
112
113 schorsch 1.3 #define mgclear(vname) undefine(vlookup(vname))
114 greg 1.1
115 schorsch 1.3 extern void mgclearall(void);
116     extern void mgload(char *file);
117     extern void mgsave(char *file);
118     extern void setmgvar(char *fname, FILE *fp, char *string);
119 schorsch 1.4 extern int mgcurve(int c, void (*f)(int c, double x, double y));
120 schorsch 1.3 extern void mgtoa(register char *s, VARIABLE *vp);
121 schorsch 1.2
122
123     #ifdef __cplusplus
124     }
125     #endif
126     #endif /* _RAD_MGVARS_H_ */
127 greg 1.1
