root/radiance/ray/src/meta/mgvars.h
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years ago) by greg
1 /* RCSid: $Id$ */
2 /*
3 * mgvars.h - header file for graphing routines using variables.
4 *
5 * 6/23/86
6 *
7 * Greg Ward Larson
8 */
9
10 /*
11 * Data arrays are used to store point data.
12 */
13
14 typedef struct {
15 int size; /* the size of the array */
16 float *data; /* pointer to the array */
17 } DARRAY;
18
19 /*
20 * Intermediate variables are not referenced
21 * directly by the program, but may be used
22 * for defining other variables.
23 */
24
25 typedef struct ivar {
26 char *name; /* the variable name */
27 char *dfn; /* its definition */
28 struct ivar *next; /* next in list */
29 } IVAR; /* an intermediate variable */
30
31 /*
32 * Variables are used for all graph parameters. The four variable
33 * types are: REAL, FUNCTION, STRING and DATA.
34 * Of these, only STRING and DATA must be interpreted by us; an
35 * expression parser will handle the rest.
36 */
37 /* standard variables */
38 #define FTHICK 0 /* frame thickness */
39 #define GRID 1 /* grid on? */
40 #define LEGEND 2 /* legend title */
41 #define OTHICK 3 /* origin thickness */
42 #define PERIOD 4 /* period of polar plot */
43 #define SUBTITLE 5 /* subtitle */
44 #define SYMFILE 6 /* symbol file */
45 #define TSTYLE 7 /* tick mark style */
46 #define TITLE 8 /* title */
47 #define XLABEL 9 /* x axis label */
48 #define XMAP 10 /* x axis mapping */
49 #define XMAX 11 /* x axis maximum */
50 #define XMIN 12 /* x axis minimum */
51 #define XSTEP 13 /* x axis step */
52 #define YLABEL 14 /* y axis label */
53 #define YMAP 15 /* y axis mapping */
54 #define YMAX 16 /* y axis maximum */
55 #define YMIN 17 /* y axis minimum */
56 #define YSTEP 18 /* y axis step */
57
58 #define NVARS 19 /* number of standard variables */
59
60 /* curve variables */
61 #define C 0 /* the curve function */
62 #define CCOLOR 1 /* the curve color */
63 #define CDATA 2 /* the curve data */
64 #define CLABEL 3 /* the curve label */
65 #define CLINTYPE 4 /* the curve line type */
66 #define CNPOINTS 5 /* number of curve points to plot */
67 #define CSYMSIZE 6 /* the curve symbol size */
68 #define CSYMTYPE 7 /* the curve symbol type */
69 #define CTHICK 8 /* the curve line thickness */
70
71 #define NCVARS 9 /* number of curve variables */
72
73 #define MAXCUR 8 /* maximum number of curves */
74
75 /* types */
76 #define REAL 1 /* floating point */
77 #define STRING 2 /* character array */
78 #define FUNCTION 3 /* function definition */
79 #define DATA 4 /* a set of real points */
80
81 /* flags */
82 #define DEFINED 01 /* variable is defined */
83
84 typedef struct {
85 char *name; /* the variable name */
86 short type; /* the variable type */
87 char *descrip; /* brief description */
88 unsigned short flags; /* DEFINED, etc. */
89 union {
90 char *s; /* STRING value */
91 DARRAY d; /* DATA value */
92 char *dfn; /* variable definition */
93 } v; /* value */
94 } VARIABLE; /* a variable */
95
96 extern IVAR *ivhead; /* the intermediate list */
97
98 extern VARIABLE gparam[NVARS]; /* the graph variables */
99 extern VARIABLE cparam[MAXCUR][NCVARS]; /* the curve variables */
100
101 extern VARIABLE *vlookup();
102
103 extern double varvalue(), funvalue();
104
105 extern int errno;
106
107 #define mgclear(vname) undefine(vlookup(vname))
