--- ray/src/meta/mgvars.c 2003/08/01 14:14:24 1.2 +++ ray/src/meta/mgvars.c 2003/11/14 00:14:40 1.4 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mgvars.c,v 1.2 2003/08/01 14:14:24 schorsch Exp $"; +static const char RCSid[] = "$Id: mgvars.c,v 1.4 2003/11/14 00:14:40 schorsch Exp $"; #endif /* * mgvars.c - routines dealing with graph variables. @@ -10,28 +10,28 @@ static const char RCSid[] = "$Id: mgvars.c,v 1.2 2003/ */ #include - #include - #include - +#include #include +#include "rtprocess.h" +#include "rterror.h" +#include "rtio.h" +#include "calcomp.h" #include "mgvars.h" #define MAXLINE 512 -#define isid(c) (isalnum(c) || (c) == '_' || (c) == '.') - #define isnum(c) (isdigit(c)||(c)=='-'||(c)=='+'||(c)=='.'||(c)=='e'||(c)=='E') -char *findfile(), *emalloc(), *ecalloc(), *erealloc(), *savestr(), *strcpy(); -FILE *fopen(), *popen(); -extern char *progname, *libpath[]; +static void mgprint(register VARIABLE *vp, FILE *fp); +static void setivar(char *vname, char *fname, char *definition); +static char *findfile(char *fname, register char **pathlist); +static void loaddata(char *fname, FILE *fp, register DARRAY *dp); +static void undefine(register VARIABLE *vp); -#ifdef DCL_ATOF -double atof(); -#endif +extern char *progname, *libpath[]; IVAR *ivhead = NULL; /* intermediate variables */ @@ -142,7 +142,8 @@ VARIABLE cparam[MAXCUR][NCVARS] = { /* curve variable }; -mgclearall() /* clear all variable settings */ +void +mgclearall(void) /* clear all variable settings */ { int j; register IVAR *iv; @@ -167,8 +168,10 @@ mgclearall() /* clear all variable settings */ } -mgload(file) /* load a file */ -char *file; +void +mgload( /* load a file */ +char *file +) { FILE *fp; char sbuf[MAXLINE], *fgets(); @@ -235,8 +238,10 @@ char *file; } -mgsave(file) /* save our variables */ -char *file; +void +mgsave( /* save our variables */ +char *file +) { FILE *fp; int j; @@ -266,10 +271,12 @@ char *file; } -setmgvar(fname, fp, string) /* set a variable */ -char *fname; -FILE *fp; -char *string; +void +setmgvar( /* set a variable */ +char *fname, +FILE *fp, +char *string +) { char name[128]; FILE *fp2; @@ -359,10 +366,12 @@ char *string; } -setivar(vname, fname, definition) /* set an intermediate variable */ -char *vname; -char *fname; -char *definition; +static void +setivar( /* set an intermediate variable */ +char *vname, +char *fname, +char *definition +) { IVAR ivbeg; register IVAR *iv; @@ -387,9 +396,11 @@ char *definition; } -mgtoa(s, vp) /* get a variable's value in ascii form */ -register char *s; -VARIABLE *vp; +void +mgtoa( /* get a variable's value in ascii form */ +register char *s, +VARIABLE *vp +) { register char *sv; @@ -417,9 +428,11 @@ VARIABLE *vp; } -mgprint(vp, fp) /* print a variable definition */ -register VARIABLE *vp; -FILE *fp; +static void +mgprint( /* print a variable definition */ +register VARIABLE *vp, +FILE *fp +) { register int i; @@ -455,8 +468,10 @@ FILE *fp; } -undefine(vp) /* undefine a variable */ -register VARIABLE *vp; +static void +undefine( /* undefine a variable */ +register VARIABLE *vp +) { if (vp == NULL || !(vp->flags & DEFINED)) return; @@ -498,10 +513,12 @@ char *vname; } -loaddata(fname, fp, dp) /* load data from a stream */ -char *fname; -FILE *fp; -register DARRAY *dp; +static void +loaddata( /* load data from a stream */ +char *fname, +FILE *fp, +register DARRAY *dp +) { char sbuf[MAXLINE], *fgets(); register char *cp; @@ -533,13 +550,13 @@ register DARRAY *dp; } -char * -findfile(fname, pathlist) /* find the file fname, return full path */ -char *fname; -register char **pathlist; +static char * +findfile( /* find the file fname, return full path */ +char *fname, +register char **pathlist +) { static char ffname[128]; - char *strcpy(), *strcat(); register int fd; if (fname[0] == '/') @@ -559,15 +576,16 @@ register char **pathlist; int -mgcurve(c, f) /* get a curve's (unmapped) values */ -int c; -int (*f)(); +mgcurve( /* get a curve's (unmapped) values */ +int c, +int (*f)() +) { int nargs; double x[2], step; register VARIABLE *cv; register float *p; - register int npts; + register int npts = 0; if (c < 0 || c >= MAXCUR) return(-1);
