root/radiance/ray/src/meta/mgraph.h
Revision: 1.3
Committed: Sat Nov 15 02:13:37 2003 UTC (20 years, 5 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 1.2: +3 -1 lines
Continued ANSIfication, and reduced other compile warnings.
1 /* RCSid: $Id: mgraph.h,v 1.2 2003/07/14 22:24:00 schorsch Exp $ */
2 /*
3 * mgraph.h - header file for graphing routines.
4 *
5 * 6/23/86
6 *
7 * Greg Ward Larson
8 */
9 #ifndef _RAD_MGRAPH_H_
10 #define _RAD_MGRAPH_H_
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #define PI 3.14159265358979323846
17 #define FHUGE 1e20
18 #define FTINY 1e-7
19 /* text density */
20 #define CPI 10
21 #define CWID (2048/CPI)
22 /* character aspect ratio */
23 #define ASPECT 1.67
24 /* fraction of period for polar arc */
25 #define PL_F 0.02
26 /* minimum # of axis divisions */
27 #define MINDIVS 4
28 /* coordinate axis box */
29 #define AX_L 2048
30 #define AX_R 12288
31 #define AX_D 2048
32 #define AX_U 12288
33 /* polar plot center and radius */
34 #define PL_X 6912
35 #define PL_Y 7168
36 #define PL_R 5120
37 /* axis tick length */
38 #define TLEN 200
39 /* x numbering offsets */
40 #define XN_X 0
41 #define XN_Y (AX_D-TLEN-300)
42 #define XN_S 1000
43 /* y numbering offsets */
44 #define YN_X (AX_L-TLEN-200)
45 #define YN_Y 64
46 #define YN_S 500
47 /* polar numbering offsets */
48 #define TN_X PL_X
49 #define TN_Y (PL_Y+150)
50 #define TN_R (PL_R+TLEN+250)
51 #define RN_X PL_X
52 #define RN_Y (PL_Y-TLEN/2-200)
53 #define RN_S XN_S
54 /* title box */
55 #define TI_L 0
56 #define TI_R 16383
57 #define TI_D 14500
58 #define TI_U 15300
59 /* subtitle box */
60 #define ST_L 0
61 #define ST_R 16383
62 #define ST_D 13675
63 #define ST_U 14170
64 /* x label box */
65 #define XL_L 2048
66 #define XL_R 9850
67 #define XL_D 500
68 #define XL_U 1000
69 /* x mapping box */
70 #define XM_L 10000
71 #define XM_R 12288
72 #define XM_D 670
73 #define XM_U 1000
74 /* y label box */
75 #define YL_L 0
76 #define YL_R 500
77 #define YL_D 2048
78 #define YL_U 9850
79 /* y mapping box */
80 #define YM_L 170
81 #define YM_R 500
82 #define YM_D 10000
83 #define YM_U 12288
84 /* legend box */
85 #define LE_L 13100
86 #define LE_R 16383
87 #define LE_D 4000
88 #define LE_U 10000
89 /* legend title */
90 #define LT_X LE_L
91 #define LT_Y (LE_U+800)
92 /* parameter defaults */
93 #define DEFFTHICK 3 /* frame thickness */
94 #define DEFTSTYLE 1 /* tick mark style */
95 #define DEFOTHICK 0 /* origin thickness */
96 #define DEFGRID 0 /* default grid */
97 #define DEFSYMSIZE 100 /* symbol size */
98 #define DEFLINTYPE 1 /* line type */
99 #define DEFTHICK 2 /* line thickness */
100 #define DEFCOLOR 1 /* color */
101 #define DEFPERIOD 0.0 /* period for polar plot */
102 #define DEFPLSTEP (1./12.) /* default angular step */
103
104 /*
105 * Bounds are used to hold the axis specifications.
106 */
107
108 typedef struct {
109 double min, max, step;
110 } BOUNDS;
111
112 extern void mgraph(void);
113
114 #ifdef __cplusplus
115 }
116 #endif
117 #endif /* _RAD_MGRAPH_H_ */
118
