root/radiance/ray/src/meta/mfio.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (20 years, 11 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 1.1: +17 -23 lines
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.2 static const char RCSid[] = "$Id: mfio.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Meta-file input and output routines
6     */
7
8     #include "meta.h"
9
10
11 schorsch 1.2 static PRIMITIVE peof = {PEOF, 0200, {-1, -1, -1, -1}, NULL, NULL};
12 greg 1.1
13
14
15     #define INTARG(n) (((unsigned)inbuf[n] << 7) | (unsigned)inbuf[n+1])
16
17
18 schorsch 1.2 int
19     readp( /* read in primitive from file */
20     PRIMITIVE *p,
21     FILE *fp
22     )
23 greg 1.1
24     {
25     char inbuf[MAXARGS];
26     register int c, nargs;
27
28     if (fp == NULL) fp = stdin;
29
30     if ((c = getc(fp)) == EOF) { /* used to be fatal */
31     mcopy((char *)p, (char *)&peof, sizeof(PRIMITIVE));
32     return(0);
33     }
34     if (!(c & 0200))
35     error(USER, "readp not started on command");
36
37     p->com = c & 0177;
38     if (!iscom(p->com))
39     error(USER, "bad command in readp");
40
41     for (nargs = 0; (c = getc(fp)) != EOF && !(c & 0200) &&
42     nargs < MAXARGS-1; nargs++)
43     inbuf[nargs] = c;
44
45     if (c & 0200)
46     ungetc(c, fp);
47     else if (nargs >= MAXARGS-1)
48     error(USER, "command w/ too many arguments in readp");
49
50     c = 0;
51
52     if (nargs) {
53     p->arg0 = inbuf[c++];
54     nargs--;
55     }
56     else
57     p->arg0 = 0200;
58
59     if (isprim(p->com)) {
60     if (nargs < 8)
61     error(USER, "missing extent in readp");
62     p->xy[XMN] = INTARG(c); c += 2;
63     p->xy[YMN] = INTARG(c); c += 2;
64     p->xy[XMX] = INTARG(c); c += 2;
65     p->xy[YMX] = INTARG(c); c += 2;
66     nargs -= 8;
67     }
68     else
69     p->xy[XMN] = p->xy[YMN] = p->xy[XMX] = p->xy[YMX] = -1;
70
71     if (nargs) {
72     inbuf[c+nargs] = '\0';
73     p->args = savestr(inbuf+c);
74     }
75     else
76     p->args = NULL;
77
78     return(p->com != PEOF);
79     }
80
81     #undef INTARG
82
83
84
85
86
87
88
89     #define HI7(i) ((i >> 7) & 0177)
90
91     #define LO7(i) (i & 0177)
92
93
94 schorsch 1.2 void
95     writep( /* write primitive to file */
96     register PRIMITIVE *p,
97     FILE *fp
98     )
99 greg 1.1 {
100     if (fp == NULL) fp = stdout;
101
102     if (!iscom(p->com))
103     error(USER, "bad command in writep");
104
105     putc(p->com | 0200, fp);
106
107     if (isprim(p->com)) {
108     putc(p->arg0 & 0177, fp);
109     putc(HI7(p->xy[XMN]), fp); putc(LO7(p->xy[XMN]), fp);
110     putc(HI7(p->xy[YMN]), fp); putc(LO7(p->xy[YMN]), fp);
111     putc(HI7(p->xy[XMX]), fp); putc(LO7(p->xy[XMX]), fp);
112     putc(HI7(p->xy[YMX]), fp); putc(LO7(p->xy[YMX]), fp);
113     }
114     else if (!(p->arg0 & 0200))
115     putc(p->arg0, fp);
116
117     if (p->args != NULL)
118     fputs(p->args, fp);
119
120     if (p->com == PDRAW || p->com == PEOF)
121     if (fflush(fp) == -1)
122     error(SYSTEM, "error detected writing file in writep");
123
124     }
125
126     #undef HI7
127
128     #undef LO7
129
130
131 schorsch 1.2 void
132     writeof( /* write end of file command to fp */
133     FILE *fp
134     )
135 greg 1.1 {
136     writep(&peof, fp);
137 schorsch 1.2 }
138 greg 1.1
