root/radiance/ray/src/meta/mfio.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (21 years, 8 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R0, rad5R1, rad4R2, rad3R7P2, rad3R7P1, rad6R0, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad4R2P2, HEAD
Changes since 1.1: +17 -23 lines
Continued ANSIfication, and reduced other compile warnings.
2 static const char RCSid[] = "$Id: mfio.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * Meta-file input and output routines
6 */
7
8 #include "meta.h"
9
10
11 static PRIMITIVE peof = {PEOF, 0200, {-1, -1, -1, -1}, NULL, NULL};
12
13
14
15 #define INTARG(n) (((unsigned)inbuf[n] << 7) | (unsigned)inbuf[n+1])
16
17
18 int
19 readp( /* read in primitive from file */
20 PRIMITIVE *p,
21 FILE *fp
22 )
23
24 {
25 char inbuf[MAXARGS];
26 register int c, nargs;
27
28 if (fp == NULL) fp = stdin;
29
30 if ((c = getc(fp)) == EOF) { /* used to be fatal */
31 mcopy((char *)p, (char *)&peof, sizeof(PRIMITIVE));
32 return(0);
33 }
34 if (!(c & 0200))
35 error(USER, "readp not started on command");
36
37 p->com = c & 0177;
38 if (!iscom(p->com))
39 error(USER, "bad command in readp");
40
41 for (nargs = 0; (c = getc(fp)) != EOF && !(c & 0200) &&
42 nargs < MAXARGS-1; nargs++)
43 inbuf[nargs] = c;
44
45 if (c & 0200)
46 ungetc(c, fp);
47 else if (nargs >= MAXARGS-1)
48 error(USER, "command w/ too many arguments in readp");
49
50 c = 0;
51
52 if (nargs) {
53 p->arg0 = inbuf[c++];
54 nargs--;
55 }
56 else
57 p->arg0 = 0200;
58
59 if (isprim(p->com)) {
60 if (nargs < 8)
61 error(USER, "missing extent in readp");
62 p->xy[XMN] = INTARG(c); c += 2;
63 p->xy[YMN] = INTARG(c); c += 2;
64 p->xy[XMX] = INTARG(c); c += 2;
65 p->xy[YMX] = INTARG(c); c += 2;
66 nargs -= 8;
67 }
68 else
69 p->xy[XMN] = p->xy[YMN] = p->xy[XMX] = p->xy[YMX] = -1;
70
71 if (nargs) {
72 inbuf[c+nargs] = '\0';
73 p->args = savestr(inbuf+c);
74 }
75 else
76 p->args = NULL;
77
78 return(p->com != PEOF);
79 }
80
81 #undef INTARG
82
83
84
85
86
87
88
89 #define HI7(i) ((i >> 7) & 0177)
90
91 #define LO7(i) (i & 0177)
92
93
94 void
95 writep( /* write primitive to file */
96 register PRIMITIVE *p,
97 FILE *fp
98 )
99 {
100 if (fp == NULL) fp = stdout;
101
102 if (!iscom(p->com))
103 error(USER, "bad command in writep");
104
105 putc(p->com | 0200, fp);
106
107 if (isprim(p->com)) {
108 putc(p->arg0 & 0177, fp);
109 putc(HI7(p->xy[XMN]), fp); putc(LO7(p->xy[XMN]), fp);
110 putc(HI7(p->xy[YMN]), fp); putc(LO7(p->xy[YMN]), fp);
111 putc(HI7(p->xy[XMX]), fp); putc(LO7(p->xy[XMX]), fp);
112 putc(HI7(p->xy[YMX]), fp); putc(LO7(p->xy[YMX]), fp);
113 }
114 else if (!(p->arg0 & 0200))
115 putc(p->arg0, fp);
116
117 if (p->args != NULL)
118 fputs(p->args, fp);
119
120 if (p->com == PDRAW || p->com == PEOF)
121 if (fflush(fp) == -1)
122 error(SYSTEM, "error detected writing file in writep");
123
124 }
125
126 #undef HI7
127
128 #undef LO7
129
130
131 void
132 writeof( /* write end of file command to fp */
133 FILE *fp
134 )
135 {
136 writep(&peof, fp);
137 }
138
