root/radiance/ray/src/meta/metacalls.c
Revision: 1.2
Committed: Sun Jun 8 12:03:10 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 1.1: +83 -51 lines
2 static const char RCSid[] = "$Id: metacalls.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * metacalls.c - functional interface to metafile.
6 *
7 * 2/24/86
8 */
9
10 #include "meta.h"
11
12
13 #define RIGHT 0
14 #define UP 1
15 #define LEFT 2
16 #define DOWN 3
17
18 #define pflush() if (inpoly) closepoly()
19
20 #define putdec(v) if (v) decival(v); else *cap++ = '0';
21
22
23 static int curx = 0;
24 static int cury = 0;
25 static int cura0 = 0;
26 static int inpoly = FALSE;
27 static char curargs[MAXARGS] = "";
28 static char *cap;
29
30
31 static int let_dir( register int c);
32 static void closepoly(void);
33 static void polyval( register int x, register int y);
34 static void decival( register int v);
35
36
37 void
38 mendpage(void) /* end of page */
39 {
40 pflush();
41 pglob(PEOP, 0200, NULL);
42 }
43
44 void
45 mdone(void) /* end of graphics metafile */
46 {
47 pflush();
48 pglob(PEOF, 0200, NULL);
49 }
50
51 void
52 minclude( /* include a file */
53 char *fname
54 )
55 {
56 pflush();
57 pglob(PINCL, 1, fname);
58 }
59
60 void
61 msetpat( /* set a pattern */
62 int pn,
63 char *pat
64 )
65 {
66 pflush();
67 pglob(PSET, pn+4, pat);
68 }
69
70
71 void
72 mopenseg( /* open a segment */
73 char *sname
74 )
75 {
76 pflush();
77 pglob(POPEN, 0, sname);
78 }
79
80
81 void
82 mcloseseg(void) /* close current segment */
83 {
84 pflush();
85 pglob(PCLOSE, 0200, NULL);
86 }
87
88
89 void
90 mline( /* start a line */
91 int x, int y,
92 int type, int thick, int color
93 )
94 {
95 pflush();
96 cura0 = (type<<4 & 060) | (thick<<2 & 014) | (color & 03);
97 curx = x;
98 cury = y;
99 }
100
101
102 void
103 mrectangle( /* fill a rectangle */
104 int xmin, int ymin, int xmax, int ymax,
105 int pat, int color
106 )
107 {
108 pflush();
109 cura0 = (pat<<2 & 014) | (color & 03);
110 pprim(PRFILL, cura0, xmin, ymin, xmax, ymax, NULL);
111 }
112
113
114 void
115 mtriangle( /* fill a triangle */
116 int xmin, int ymin, int xmax, int ymax,
117 int d, int pat, int color
118 )
119 {
120 pflush();
121 cura0 = (let_dir(d)<<4 & 060) | (pat<<2 & 014) | (color & 03);
122 pprim(PTFILL, cura0, xmin, ymin, xmax, ymax, NULL);
123 }
124
125
126 void
127 mpoly( /* start a polygon */
128 int x, int y,
129 int border, int pat, int color
130 )
131 {
132 pflush();
133 cura0 = (border<<6 & 0100) | (pat<<2 & 014) | (color & 03);
134 cap = curargs;
135 inpoly = TRUE;
136 putdec(x);
137 *cap++ = ' ';
138 putdec(y);
139 }
140
141
142 void
143 mtext( /* matrix string */
144 int x, int y,
145 char *s,
146 int cpi,
147 int color
148 )
149 {
150 pflush();
151 cura0 = (color & 03);
152 if (cpi < 10) {
153 cura0 += 04;
154 cpi *= 2;
155 }
156 if (cpi > 11)
157 cura0 += 020;
158 if (cpi > 14)
159 cura0 += 020;
160 if (cpi > 18)
161 cura0 += 020;
162 pprim(PMSTR, cura0, x, y, x, y, s);
163 }
164
165
166 void
167 mvstr( /* vector string */
168 int xmin, int ymin, int xmax, int ymax,
169 char *s,
170 int d, int thick, int color
171 )
172 {
173 pflush();
174 cura0 = (let_dir(d)<<4 & 060) | (thick<<2 & 014) | (color & 03);
175 pprim(PVSTR, cura0, xmin, ymin, xmax, ymax, s);
176 }
177
178
179 void
180 msegment( /* segment */
181 int xmin, int ymin, int xmax, int ymax,
182 char *sname,
183 int d, int thick, int color
184 )
185 {
186 pflush();
187 cura0 = (let_dir(d)<<4 & 060) | (thick<<2 & 014) | (color & 03);
188 pprim(PSEG, cura0, xmin, ymin, xmax, ymax, sname);
189 }
190
191
192 void
193 mdraw( /* draw to next point */
194 int x, int y
195 )
196 {
197 if (inpoly) {
198 polyval(x, y);
199 } else if (x != curx || y != cury) {
200 plseg(cura0, curx, cury, x, y);
201 curx = x;
202 cury = y;
203 }
204 }
205
206
207 static void
208 decival( /* add value to polygon */
209 register int v
210 )
211 {
212 if (!v)
213 return;
214 decival(v/10);
215 *cap++ = v%10 + '0';
216 }
217
218
219 static void
220 polyval( /* add vertex to a polygon */
221 register int x,
222 register int y
223 )
224 {
225 *cap++ = ' ';
226 putdec(x);
227 *cap++ = ' ';
228 putdec(y);
229 }
230
231
232 static void
233 closepoly(void) /* close current polygon */
234 {
235 *cap = '\0';
236 pprim(PPFILL, cura0, 0, 0, XYSIZE-1, XYSIZE-1, curargs);
237 inpoly = FALSE;
238 }
239
240
241 static int
242 let_dir( /* convert letter to corresponding direction */
243 register int c
244 )
245 {
246 switch (c) {
247 case 'R':
248 case 'r':
249 return(RIGHT);
250 case 'U':
251 case 'u':
252 return(UP);
253 case 'L':
254 case 'l':
255 return(LEFT);
256 case 'D':
257 case 'd':
258 return(DOWN);
259 }
260 return(0);
261 }
