--- ray/src/meta/metacalls.c 2003/02/22 02:07:26 1.1 +++ ray/src/meta/metacalls.c 2003/06/08 12:03:10 1.2 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: metacalls.c,v 1.1 2003/02/22 02:07:26 greg Exp $"; +static const char RCSid[] = "$Id: metacalls.c,v 1.2 2003/06/08 12:03:10 schorsch Exp $"; #endif /* * metacalls.c - functional interface to metafile. @@ -28,55 +28,69 @@ static char curargs[MAXARGS] = ""; static char *cap; -mendpage() /* end of page */ +static int let_dir( register int c); +static void closepoly(void); +static void polyval( register int x, register int y); +static void decival( register int v); + + +void +mendpage(void) /* end of page */ { pflush(); pglob(PEOP, 0200, NULL); } - -mdone() /* end of graphics metafile */ +void +mdone(void) /* end of graphics metafile */ { pflush(); pglob(PEOF, 0200, NULL); } - -minclude(fname) /* include a file */ -char *fname; +void +minclude( /* include a file */ +char *fname +) { pflush(); pglob(PINCL, 1, fname); } - -msetpat(pn, pat) /* set a pattern */ -int pn; -char *pat; +void +msetpat( /* set a pattern */ +int pn, +char *pat +) { pflush(); pglob(PSET, pn+4, pat); } -mopenseg(sname) /* open a segment */ -char *sname; +void +mopenseg( /* open a segment */ +char *sname +) { pflush(); pglob(POPEN, 0, sname); } -mcloseseg() /* close current segment */ +void +mcloseseg(void) /* close current segment */ { pflush(); pglob(PCLOSE, 0200, NULL); } -mline(x, y, type, thick, color) /* start a line */ -int x, y; -int type, thick, color; +void +mline( /* start a line */ +int x, int y, +int type, int thick, int color +) { pflush(); cura0 = (type<<4 & 060) | (thick<<2 & 014) | (color & 03); @@ -85,9 +99,11 @@ int type, thick, color; } -mrectangle(xmin, ymin, xmax, ymax, pat, color) /* fill a rectangle */ -int xmin, ymin, xmax, ymax; -int pat, color; +void +mrectangle( /* fill a rectangle */ +int xmin, int ymin, int xmax, int ymax, +int pat, int color +) { pflush(); cura0 = (pat<<2 & 014) | (color & 03); @@ -95,9 +111,11 @@ int pat, color; } -mtriangle(xmin, ymin, xmax, ymax, d, pat, color) /* fill a triangle */ -int xmin, ymin, xmax, ymax; -int d, pat, color; +void +mtriangle( /* fill a triangle */ +int xmin, int ymin, int xmax, int ymax, +int d, int pat, int color +) { pflush(); cura0 = (let_dir(d)<<4 & 060) | (pat<<2 & 014) | (color & 03); @@ -105,9 +123,11 @@ int d, pat, color; } -mpoly(x, y, border, pat, color) /* start a polygon */ -int x, y; -int border, pat, color; +void +mpoly( /* start a polygon */ +int x, int y, +int border, int pat, int color +) { pflush(); cura0 = (border<<6 & 0100) | (pat<<2 & 014) | (color & 03); @@ -119,11 +139,13 @@ int border, pat, color; } -mtext(x, y, s, cpi, color) /* matrix string */ -int x, y; -char *s; -int cpi; -int color; +void +mtext( /* matrix string */ +int x, int y, +char *s, +int cpi, +int color +) { pflush(); cura0 = (color & 03); @@ -141,10 +163,12 @@ int color; } -mvstr(xmin, ymin, xmax, ymax, s, d, thick, color) /* vector string */ -int xmin, ymin, xmax, ymax; -char *s; -int d, thick, color; +void +mvstr( /* vector string */ +int xmin, int ymin, int xmax, int ymax, +char *s, +int d, int thick, int color +) { pflush(); cura0 = (let_dir(d)<<4 & 060) | (thick<<2 & 014) | (color & 03); @@ -152,10 +176,12 @@ int d, thick, color; } -msegment(xmin, ymin, xmax, ymax, sname, d, thick, color) /* segment */ -int xmin, ymin, xmax, ymax; -char *sname; -int d, thick, color; +void +msegment( /* segment */ +int xmin, int ymin, int xmax, int ymax, +char *sname, +int d, int thick, int color +) { pflush(); cura0 = (let_dir(d)<<4 & 060) | (thick<<2 & 014) | (color & 03); @@ -163,8 +189,10 @@ int d, thick, color; } -mdraw(x, y) /* draw to next point */ -int x, y; +void +mdraw( /* draw to next point */ +int x, int y +) { if (inpoly) { polyval(x, y); @@ -176,9 +204,10 @@ int x, y; } -static -decival(v) /* add value to polygon */ -register int v; +static void +decival( /* add value to polygon */ +register int v +) { if (!v) return; @@ -187,9 +216,11 @@ register int v; } -static -polyval(x, y) /* add vertex to a polygon */ -register int x, y; +static void +polyval( /* add vertex to a polygon */ +register int x, +register int y +) { *cap++ = ' '; putdec(x); @@ -198,8 +229,8 @@ register int x, y; } -static -closepoly() /* close current polygon */ +static void +closepoly(void) /* close current polygon */ { *cap = '\0'; pprim(PPFILL, cura0, 0, 0, XYSIZE-1, XYSIZE-1, curargs); @@ -208,8 +239,9 @@ closepoly() /* close current polygon */ static int -let_dir(c) /* convert letter to corresponding direction */ -register int c; +let_dir( /* convert letter to corresponding direction */ +register int c +) { switch (c) { case 'R':
