root/radiance/ray/src/meta/meta2tga.c
Revision: 1.6
Committed: Wed Feb 4 18:49:24 2004 UTC (20 years, 3 months ago) by greg
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
Increased maximum number of primitives in meta2tga scanline
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 1.6 static const char RCSid[] = "$Id: meta2tga.c,v 1.5 2003/11/15 02:13:37 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Program to convert meta-files to Targa 8-bit color-mapped format
6     */
7
8 schorsch 1.4 #include "copyright.h"
9 greg 1.1
10 schorsch 1.4 #include "rtprocess.h"
11 greg 1.1 #include "meta.h"
12     #include "plot.h"
13     #include "rast.h"
14     #include "targa.h"
15
16 greg 1.6 #define MAXALLOC 30000
17 schorsch 1.4 #define DXSIZE 400 /* default x resolution */
18     #define DYSIZE 400 /* default y resolution */
19     #define XCOM "pexpand +vOCImsp -DP %s | psort +y"
20 greg 1.1
21
22     char *progname;
23
24     SCANBLOCK outblock;
25
26     int dxsize = DXSIZE, dysize = DYSIZE;
27
28     int maxalloc = MAXALLOC;
29
30     int ydown = 0;
31
32     static char outname[64];
33     static char *outtack = NULL;
34
35     static FILE *fout;
36
37     static int lineno = 0;
38
39     static short condonly = FALSE,
40     conditioned = FALSE;
41
42 schorsch 1.5 static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
43
44
45
46 greg 1.1 char *
47     findtack(s) /* find place to tack on suffix */
48     register char *s;
49     {
50     while (*s && *s != '.')
51     s++;
52     return(s);
53     }
54
55
56 schorsch 1.5 int
57     main(
58     int argc,
59     char **argv
60     )
61 greg 1.1
62     {
63     FILE *fp;
64     char comargs[200], command[300];
65
66     fout = stdout;
67     progname = *argv++;
68     argc--;
69
70     condonly = FALSE;
71     conditioned = FALSE;
72
73     while (argc && **argv == '-') {
74     switch (*(*argv+1)) {
75     case 'c':
76     condonly = TRUE;
77     break;
78     case 'r':
79     conditioned = TRUE;
80     break;
81     case 'm':
82     minwidth = atoi(*++argv);
83     argc--;
84     break;
85     case 'x':
86     dxsize = atoi(*++argv);
87     argc--;
88     break;
89     case 'y':
90     dysize = atoi(*++argv);
91     argc--;
92     break;
93     case 'o':
94     strcpy(outname, *++argv);
95     outtack = findtack(outname);
96     argc--;
97     break;
98     default:
99     error(WARNING, "unknown option");
100     break;
101     }
102     argv++;
103     argc--;
104     }
105
106     if (conditioned) {
107     if (argc)
108     while (argc) {
109     fp = efopen(*argv, "r");
110     plot(fp);
111     fclose(fp);
112     argv++;
113     argc--;
114     }
115     else
116     plot(stdin);
117     if (lineno)
118     nextpage();
119     } else {
120     comargs[0] = '\0';
121     while (argc) {
122     strcat(comargs, " ");
123     strcat(comargs, *argv);
124     argv++;
125     argc--;
126     }
127     sprintf(command, XCOM, comargs);
128     if (condonly)
129     return(system(command));
130     else {
131     if ((fp = popen(command, "r")) == NULL)
132     error(SYSTEM, "cannot execute input filter");
133     plot(fp);
134     pclose(fp);
135     if (lineno)
136     nextpage();
137     }
138     }
139
140     return(0);
141     }
142
143
144
145 schorsch 1.5 void
146     thispage(void) /* rewind current file */
147 greg 1.1 {
148     if (lineno)
149     error(USER, "cannot restart page in thispage");
150     }
151
152
153 schorsch 1.5 void
154     initfile(void) /* initialize this file */
155 greg 1.1 {
156     static int filenum = 0;
157 greg 1.3 /*
158 greg 1.1 static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255,
159     179,179,0, 255,0,255, 0,200,200, 0,0,0};
160 greg 1.3 */
161     static unsigned char cmap[24] = {0,0,0, 0,0,255, 0,188,0, 255,152,0,
162     0,200,200, 255,0,255, 179,179,0, 255,255,255};
163 greg 1.1 struct hdStruct thead;
164     register int i;
165
166     if (outtack != NULL) {
167     sprintf(outtack, "%d.tga", ++filenum);
168     fout = efopen(outname, "w");
169     }
170     if (fout == NULL)
171     error(USER, "no output file");
172     thead.mapType = CM_HASMAP;
173     thead.dataType = IM_CCMAP;
174     thead.mapOrig = 0;
175     thead.mapLength = 256;
176     thead.CMapBits = 24;
177     thead.XOffset = 0;
178     thead.YOffset = 0;
179     thead.x = dxsize;
180     thead.y = dysize;
181     thead.dataBits = 8;
182     thead.imType = 0;
183     putthead(&thead, NULL, fout);
184     for (i = 0; i < 8*3; i++)
185     putc(cmap[i], fout);
186     while (i++ < 256*3)
187     putc(0, fout);
188     }
189
190
191
192 schorsch 1.5 void
193     nextpage(void) /* advance to next page */
194 greg 1.1
195     {
196
197     if (lineno == 0)
198     return;
199     if (fout != NULL) {
200     while (lineno < dysize) {
201     nextblock();
202     outputblock();
203     }
204     fclose(fout);
205     fout = NULL;
206     }
207     lineno = 0;
208
209     }
210
211
212
213     #define MINRUN 4
214
215 schorsch 1.5 extern void
216     printblock(void) /* output scanline block to file */
217 greg 1.1
218     {
219     int i, c2;
220     register unsigned char *scanline;
221 schorsch 1.5 register int j, beg, cnt = 0;
222 greg 1.1
223     if (lineno == 0)
224     initfile();
225     for (i = outblock.ybot; i <= outblock.ytop && i < dysize; i++) {
226     scanline = outblock.cols[i-outblock.ybot];
227     for (j = outblock.xleft; j <= outblock.xright; j += cnt) {
228     for (beg = j; beg <= outblock.xright; beg += cnt) {
229     for (cnt = 1; cnt < 128 && beg+cnt <= outblock.xright &&
230     scanline[beg+cnt] == scanline[beg]; cnt++)
231     ;
232     if (cnt >= MINRUN)
233     break; /* long enough */
234     }
235     while (j < beg) { /* write out non-run */
236     if ((c2 = beg-j) > 128) c2 = 128;
237     putc(c2-1, fout);
238     while (c2--)
239     putc(scanline[j++], fout);
240     }
241     if (cnt >= MINRUN) { /* write out run */
242     putc(127+cnt, fout);
243     putc(scanline[beg], fout);
244     } else
245     cnt = 0;
246     }
247     lineno++;
248     }
249
250     }
251
252
253 schorsch 1.5 void
254     putint2( /* put a 2-byte positive integer */
255     register int i,
256     register FILE *fp
257     )
258 greg 1.1 {
259     putc(i&0xff, fp);
260     putc(i>>8&0xff, fp);
261     }
262
263
264 schorsch 1.5 int
265     putthead( /* write header to output */
266     struct hdStruct *hp,
267     char *ip,
268     register FILE *fp
269     )
270 greg 1.1 {
271     if (ip != NULL)
272     putc(strlen(ip), fp);
273     else
274     putc(0, fp);
275     putc(hp->mapType, fp);
276     putc(hp->dataType, fp);
277     putint2(hp->mapOrig, fp);
278     putint2(hp->mapLength, fp);
279     putc(hp->CMapBits, fp);
280     putint2(hp->XOffset, fp);
281     putint2(hp->YOffset, fp);
282     putint2(hp->x, fp);
283     putint2(hp->y, fp);
284     putc(hp->dataBits, fp);
285     putc(hp->imType, fp);
286
287     if (ip != NULL)
288     fputs(ip, fp);
289
290     return(ferror(fp) ? -1 : 0);
291     }
