root/Development/ray/src/meta/meta2tga.c
Revision: 1.5
Committed: Sat Nov 15 02:13:37 2003 UTC (22 years ago) by schorsch
Changes since 1.4: +30 -23 lines
Continued ANSIfication, and reduced other compile warnings.
2 static const char RCSid[] = "$Id: meta2tga.c,v 1.4 2003/10/27 10:28:59 schorsch Exp $";
5 * Program to convert meta-files to Targa 8-bit color-mapped format
6 */
7
8 #include "copyright.h"
9
10 #include "rtprocess.h"
11 #include "meta.h"
12 #include "plot.h"
13 #include "rast.h"
14 #include "targa.h"
15
16 #define MAXALLOC 5000
17 #define DXSIZE 400 /* default x resolution */
18 #define DYSIZE 400 /* default y resolution */
19 #define XCOM "pexpand +vOCImsp -DP %s | psort +y"
20
21
22 char *progname;
23
24 SCANBLOCK outblock;
25
26 int dxsize = DXSIZE, dysize = DYSIZE;
27
28 int maxalloc = MAXALLOC;
29
30 int ydown = 0;
31
32 static char outname[64];
33 static char *outtack = NULL;
34
35 static FILE *fout;
36
37 static int lineno = 0;
38
39 static short condonly = FALSE,
40 conditioned = FALSE;
41
42 static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
43
44
45
46 char *
47 findtack(s) /* find place to tack on suffix */
48 register char *s;
49 {
50 while (*s && *s != '.')
51 s++;
52 return(s);
53 }
54
55
56 int
57 main(
58 int argc,
59 char **argv
60 )
61
62 {
63 FILE *fp;
64 char comargs[200], command[300];
65
66 fout = stdout;
67 progname = *argv++;
68 argc--;
69
70 condonly = FALSE;
71 conditioned = FALSE;
72
73 while (argc && **argv == '-') {
74 switch (*(*argv+1)) {
75 case 'c':
76 condonly = TRUE;
77 break;
78 case 'r':
79 conditioned = TRUE;
80 break;
81 case 'm':
82 minwidth = atoi(*++argv);
83 argc--;
84 break;
85 case 'x':
86 dxsize = atoi(*++argv);
87 argc--;
88 break;
89 case 'y':
90 dysize = atoi(*++argv);
91 argc--;
92 break;
93 case 'o':
94 strcpy(outname, *++argv);
95 outtack = findtack(outname);
96 argc--;
97 break;
98 default:
99 error(WARNING, "unknown option");
100 break;
101 }
102 argv++;
103 argc--;
104 }
105
106 if (conditioned) {
107 if (argc)
108 while (argc) {
109 fp = efopen(*argv, "r");
110 plot(fp);
111 fclose(fp);
112 argv++;
113 argc--;
114 }
115 else
116 plot(stdin);
117 if (lineno)
118 nextpage();
119 } else {
120 comargs[0] = '\0';
121 while (argc) {
122 strcat(comargs, " ");
123 strcat(comargs, *argv);
124 argv++;
125 argc--;
126 }
127 sprintf(command, XCOM, comargs);
128 if (condonly)
129 return(system(command));
130 else {
131 if ((fp = popen(command, "r")) == NULL)
132 error(SYSTEM, "cannot execute input filter");
133 plot(fp);
134 pclose(fp);
135 if (lineno)
136 nextpage();
137 }
138 }
139
140 return(0);
141 }
142
143
144
145 void
146 thispage(void) /* rewind current file */
147 {
148 if (lineno)
149 error(USER, "cannot restart page in thispage");
150 }
151
152
153 void
154 initfile(void) /* initialize this file */
155 {
156 static int filenum = 0;
157 /*
158 static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255,
159 179,179,0, 255,0,255, 0,200,200, 0,0,0};
160 */
161 static unsigned char cmap[24] = {0,0,0, 0,0,255, 0,188,0, 255,152,0,
162 0,200,200, 255,0,255, 179,179,0, 255,255,255};
163 struct hdStruct thead;
164 register int i;
165
166 if (outtack != NULL) {
167 sprintf(outtack, "%d.tga", ++filenum);
168 fout = efopen(outname, "w");
169 }
170 if (fout == NULL)
171 error(USER, "no output file");
172 thead.mapType = CM_HASMAP;
173 thead.dataType = IM_CCMAP;
174 thead.mapOrig = 0;
175 thead.mapLength = 256;
176 thead.CMapBits = 24;
177 thead.XOffset = 0;
178 thead.YOffset = 0;
179 thead.x = dxsize;
180 thead.y = dysize;
181 thead.dataBits = 8;
182 thead.imType = 0;
183 putthead(&thead, NULL, fout);
184 for (i = 0; i < 8*3; i++)
185 putc(cmap[i], fout);
186 while (i++ < 256*3)
187 putc(0, fout);
188 }
189
190
191
192 void
193 nextpage(void) /* advance to next page */
194
195 {
196
197 if (lineno == 0)
198 return;
199 if (fout != NULL) {
200 while (lineno < dysize) {
201 nextblock();
202 outputblock();
203 }
204 fclose(fout);
205 fout = NULL;
206 }
207 lineno = 0;
208
209 }
210
211
212
213 #define MINRUN 4
214
215 extern void
216 printblock(void) /* output scanline block to file */
217
218 {
219 int i, c2;
220 register unsigned char *scanline;
221 register int j, beg, cnt = 0;
222
223 if (lineno == 0)
224 initfile();
225 for (i = outblock.ybot; i <= outblock.ytop && i < dysize; i++) {
226 scanline = outblock.cols[i-outblock.ybot];
227 for (j = outblock.xleft; j <= outblock.xright; j += cnt) {
228 for (beg = j; beg <= outblock.xright; beg += cnt) {
229 for (cnt = 1; cnt < 128 && beg+cnt <= outblock.xright &&
230 scanline[beg+cnt] == scanline[beg]; cnt++)
231 ;
232 if (cnt >= MINRUN)
233 break; /* long enough */
234 }
235 while (j < beg) { /* write out non-run */
236 if ((c2 = beg-j) > 128) c2 = 128;
237 putc(c2-1, fout);
238 while (c2--)
239 putc(scanline[j++], fout);
240 }
241 if (cnt >= MINRUN) { /* write out run */
242 putc(127+cnt, fout);
243 putc(scanline[beg], fout);
244 } else
245 cnt = 0;
246 }
247 lineno++;
248 }
249
250 }
251
252
253 void
254 putint2( /* put a 2-byte positive integer */
255 register int i,
256 register FILE *fp
257 )
258 {
259 putc(i&0xff, fp);
260 putc(i>>8&0xff, fp);
261 }
262
263
264 int
265 putthead( /* write header to output */
266 struct hdStruct *hp,
267 char *ip,
268 register FILE *fp
269 )
270 {
271 if (ip != NULL)
272 putc(strlen(ip), fp);
273 else
274 putc(0, fp);
275 putc(hp->mapType, fp);
276 putc(hp->dataType, fp);
277 putint2(hp->mapOrig, fp);
278 putint2(hp->mapLength, fp);
279 putc(hp->CMapBits, fp);
280 putint2(hp->XOffset, fp);
281 putint2(hp->YOffset, fp);
282 putint2(hp->x, fp);
283 putint2(hp->y, fp);
284 putc(hp->dataBits, fp);
285 putc(hp->imType, fp);
286
287 if (ip != NULL)
288 fputs(ip, fp);
289
290 return(ferror(fp) ? -1 : 0);
291 }
