root/radiance/ray/src/meta/meta2tga.c
Revision 1.9 - (view) (download) (annotate) - [selected]
Wed May 13 00:30:13 2020 UTC (5 years ago) by greg
Changes since 1.8: +12 -23 lines
Diff to previous 1.8
Minor code cleanup
Mon Nov 18 22:12:32 2019 UTC (5 years, 6 months ago) by greg
Changes since 1.7: +8 -8 lines
Diff to previous 1.7 , to selected 1.9
Renamed "dysize" to avoid Linux library conflict
Tue Mar 19 19:34:41 2019 UTC (6 years, 2 months ago) by greg
Diff to previous 1.6 , to selected 1.9
Increased maximum primitive allocation
Wed Feb 4 18:49:24 2004 UTC (21 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 1.9
Increased maximum number of primitives in meta2tga scanline
Sat Nov 15 02:13:37 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.4: +30 -23 lines
Diff to previous 1.4 , to selected 1.9
Continued ANSIfication, and reduced other compile warnings.
Mon Oct 27 10:28:59 2003 UTC (21 years, 7 months ago) by schorsch
Changes since 1.3: +7 -17 lines
Diff to previous 1.3 , to selected 1.9
Various compatibility fixes.
Tue Sep 16 06:32:21 2003 UTC (21 years, 8 months ago) by greg
Changes since 1.2: +5 -1 lines
Diff to previous 1.2 , to selected 1.9
Changed meta2tga so it outputs correct colors
Fri Aug 1 14:14:24 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 1.1: +1 -15 lines
Diff to previous 1.1 , to selected 1.9
Eliminated CPM, MAC, and UNIX conditional compiles.
Sat Feb 22 02:07:26 2003 UTC (22 years, 3 months ago) by greg
Diff to selected 1.9
