--- ray/src/meta/meta2tga.c 2003/02/22 02:07:26 1.1 +++ ray/src/meta/meta2tga.c 2003/09/16 06:32:21 1.3 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: meta2tga.c,v 1.1 2003/02/22 02:07:26 greg Exp $"; +static const char RCSid[] = "$Id: meta2tga.c,v 1.3 2003/09/16 06:32:21 greg Exp $"; #endif /* * Program to convert meta-files to Targa 8-bit color-mapped format @@ -65,36 +65,24 @@ char **argv; { FILE *fp; -#ifdef UNIX FILE *popen(); -#endif char comargs[200], command[300]; -#ifdef CPM - fixargs("meta2tga", &argc, &argv); -#endif - fout = stdout; progname = *argv++; argc--; condonly = FALSE; -#ifdef CPM - conditioned = TRUE; -#else conditioned = FALSE; -#endif while (argc && **argv == '-') { switch (*(*argv+1)) { -#ifdef UNIX case 'c': condonly = TRUE; break; case 'r': conditioned = TRUE; break; -#endif case 'm': minwidth = atoi(*++argv); argc--; @@ -142,7 +130,6 @@ char **argv; argc--; } sprintf(command, XCOM, comargs); -#ifdef UNIX if (condonly) return(system(command)); else { @@ -153,7 +140,6 @@ char **argv; if (lineno) nextpage(); } -#endif } return(0); @@ -175,8 +161,12 @@ thispage() /* rewind current file */ initfile() /* initialize this file */ { static int filenum = 0; + /* static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255, 179,179,0, 255,0,255, 0,200,200, 0,0,0}; + */ + static unsigned char cmap[24] = {0,0,0, 0,0,255, 0,188,0, 255,152,0, + 0,200,200, 255,0,255, 179,179,0, 255,255,255}; struct hdStruct thead; register int i;
