| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: meta2tga.c,v 1.5 2003/11/15 02:13:37 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Program to convert meta-files to Targa 8-bit color-mapped format
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "rtprocess.h"
| 11 |
#include "meta.h"
| 12 |
#include "plot.h"
| 13 |
#include "rast.h"
| 14 |
#include "targa.h"
| 15 |
| 16 |
#define MAXALLOC 30000
| 17 |
#define DXSIZE 400 /* default x resolution */
| 18 |
#define DYSIZE 400 /* default y resolution */
| 19 |
#define XCOM "pexpand +vOCImsp -DP %s | psort +y"
| 20 |
| 21 |
| 22 |
char *progname;
| 23 |
| 24 |
SCANBLOCK outblock;
| 25 |
| 26 |
int dxsize = DXSIZE, dysize = DYSIZE;
| 27 |
| 28 |
int maxalloc = MAXALLOC;
| 29 |
| 30 |
int ydown = 0;
| 31 |
| 32 |
static char outname[64];
| 33 |
static char *outtack = NULL;
| 34 |
| 35 |
static FILE *fout;
| 36 |
| 37 |
static int lineno = 0;
| 38 |
| 39 |
static short condonly = FALSE,
| 40 |
conditioned = FALSE;
| 41 |
| 42 |
static int putthead(struct hdStruct *hp, char *ip, FILE *fp);
| 43 |
| 44 |
| 45 |
| 46 |
char *
| 47 |
findtack(s) /* find place to tack on suffix */
| 48 |
register char *s;
| 49 |
| 50 |
while (*s && *s != '.')
| 51 |
s++;
| 52 |
return(s);
| 53 |
| 54 |
| 55 |
| 56 |
int
| 57 |
main(
| 58 |
int argc,
| 59 |
char **argv
| 60 |
| 61 |
| 62 |
| 63 |
FILE *fp;
| 64 |
char comargs[200], command[300];
| 65 |
| 66 |
fout = stdout;
| 67 |
progname = *argv++;
| 68 |
argc--;
| 69 |
| 70 |
condonly = FALSE;
| 71 |
| 72 |
| 73 |
while (argc && **argv == '-') {
| 74 |
switch (*(*argv+1)) {
| 75 |
case 'c':
| 76 |
condonly = TRUE;
| 77 |
break;
| 78 |
case 'r':
| 79 |
conditioned = TRUE;
| 80 |
break;
| 81 |
case 'm':
| 82 |
minwidth = atoi(*++argv);
| 83 |
argc--;
| 84 |
break;
| 85 |
case 'x':
| 86 |
dxsize = atoi(*++argv);
| 87 |
argc--;
| 88 |
break;
| 89 |
case 'y':
| 90 |
dysize = atoi(*++argv);
| 91 |
argc--;
| 92 |
break;
| 93 |
case 'o':
| 94 |
strcpy(outname, *++argv);
| 95 |
outtack = findtack(outname);
| 96 |
argc--;
| 97 |
break;
| 98 |
default:
| 99 |
error(WARNING, "unknown option");
| 100 |
break;
| 101 |
| 102 |
argv++;
| 103 |
argc--;
| 104 |
| 105 |
| 106 |
if (conditioned) {
| 107 |
if (argc)
| 108 |
while (argc) {
| 109 |
fp = efopen(*argv, "r");
| 110 |
plot(fp);
| 111 |
fclose(fp);
| 112 |
argv++;
| 113 |
argc--;
| 114 |
| 115 |
else
| 116 |
plot(stdin);
| 117 |
if (lineno)
| 118 |
nextpage();
| 119 |
} else {
| 120 |
comargs[0] = '\0';
| 121 |
while (argc) {
| 122 |
strcat(comargs, " ");
| 123 |
strcat(comargs, *argv);
| 124 |
argv++;
| 125 |
argc--;
| 126 |
| 127 |
sprintf(command, XCOM, comargs);
| 128 |
if (condonly)
| 129 |
return(system(command));
| 130 |
else {
| 131 |
if ((fp = popen(command, "r")) == NULL)
| 132 |
error(SYSTEM, "cannot execute input filter");
| 133 |
plot(fp);
| 134 |
pclose(fp);
| 135 |
if (lineno)
| 136 |
nextpage();
| 137 |
| 138 |
| 139 |
| 140 |
return(0);
| 141 |
| 142 |
| 143 |
| 144 |
| 145 |
void
| 146 |
thispage(void) /* rewind current file */
| 147 |
| 148 |
if (lineno)
| 149 |
error(USER, "cannot restart page in thispage");
| 150 |
| 151 |
| 152 |
| 153 |
void
| 154 |
initfile(void) /* initialize this file */
| 155 |
| 156 |
static int filenum = 0;
| 157 |
| 158 |
static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255,
| 159 |
179,179,0, 255,0,255, 0,200,200, 0,0,0};
| 160 |
| 161 |
static unsigned char cmap[24] = {0,0,0, 0,0,255, 0,188,0, 255,152,0,
| 162 |
0,200,200, 255,0,255, 179,179,0, 255,255,255};
| 163 |
struct hdStruct thead;
| 164 |
register int i;
| 165 |
| 166 |
if (outtack != NULL) {
| 167 |
sprintf(outtack, "%d.tga", ++filenum);
| 168 |
fout = efopen(outname, "w");
| 169 |
| 170 |
if (fout == NULL)
| 171 |
error(USER, "no output file");
| 172 |
thead.mapType = CM_HASMAP;
| 173 |
thead.dataType = IM_CCMAP;
| 174 |
thead.mapOrig = 0;
| 175 |
thead.mapLength = 256;
| 176 |
thead.CMapBits = 24;
| 177 |
thead.XOffset = 0;
| 178 |
thead.YOffset = 0;
| 179 |
thead.x = dxsize;
| 180 |
thead.y = dysize;
| 181 |
thead.dataBits = 8;
| 182 |
thead.imType = 0;
| 183 |
putthead(&thead, NULL, fout);
| 184 |
for (i = 0; i < 8*3; i++)
| 185 |
putc(cmap[i], fout);
| 186 |
while (i++ < 256*3)
| 187 |
putc(0, fout);
| 188 |
| 189 |
| 190 |
| 191 |
| 192 |
void
| 193 |
nextpage(void) /* advance to next page */
| 194 |
| 195 |
| 196 |
| 197 |
if (lineno == 0)
| 198 |
return;
| 199 |
if (fout != NULL) {
| 200 |
while (lineno < dysize) {
| 201 |
nextblock();
| 202 |
outputblock();
| 203 |
| 204 |
fclose(fout);
| 205 |
fout = NULL;
| 206 |
| 207 |
lineno = 0;
| 208 |
| 209 |
| 210 |
| 211 |
| 212 |
| 213 |
#define MINRUN 4
| 214 |
| 215 |
extern void
| 216 |
printblock(void) /* output scanline block to file */
| 217 |
| 218 |
| 219 |
int i, c2;
| 220 |
register unsigned char *scanline;
| 221 |
register int j, beg, cnt = 0;
| 222 |
| 223 |
if (lineno == 0)
| 224 |
initfile();
| 225 |
for (i = outblock.ybot; i <= outblock.ytop && i < dysize; i++) {
| 226 |
scanline = outblock.cols[i-outblock.ybot];
| 227 |
for (j = outblock.xleft; j <= outblock.xright; j += cnt) {
| 228 |
for (beg = j; beg <= outblock.xright; beg += cnt) {
| 229 |
for (cnt = 1; cnt < 128 && beg+cnt <= outblock.xright &&
| 230 |
scanline[beg+cnt] == scanline[beg]; cnt++)
| 231 |
| 232 |
if (cnt >= MINRUN)
| 233 |
break; /* long enough */
| 234 |
| 235 |
while (j < beg) { /* write out non-run */
| 236 |
if ((c2 = beg-j) > 128) c2 = 128;
| 237 |
putc(c2-1, fout);
| 238 |
while (c2--)
| 239 |
putc(scanline[j++], fout);
| 240 |
| 241 |
if (cnt >= MINRUN) { /* write out run */
| 242 |
putc(127+cnt, fout);
| 243 |
putc(scanline[beg], fout);
| 244 |
} else
| 245 |
cnt = 0;
| 246 |
| 247 |
lineno++;
| 248 |
| 249 |
| 250 |
| 251 |
| 252 |
| 253 |
void
| 254 |
putint2( /* put a 2-byte positive integer */
| 255 |
register int i,
| 256 |
register FILE *fp
| 257 |
| 258 |
| 259 |
putc(i&0xff, fp);
| 260 |
putc(i>>8&0xff, fp);
| 261 |
| 262 |
| 263 |
| 264 |
int
| 265 |
putthead( /* write header to output */
| 266 |
| 267 |
char *ip,
| 268 |
register FILE *fp
| 269 |
| 270 |
| 271 |
if (ip != NULL)
| 272 |
putc(strlen(ip), fp);
| 273 |
else
| 274 |
putc(0, fp);
| 275 |
putc(hp->mapType, fp);
| 276 |
putc(hp->dataType, fp);
| 277 |
putint2(hp->mapOrig, fp);
| 278 |
putint2(hp->mapLength, fp);
| 279 |
putc(hp->CMapBits, fp);
| 280 |
putint2(hp->XOffset, fp);
| 281 |
putint2(hp->YOffset, fp);
| 282 |
putint2(hp->x, fp);
| 283 |
putint2(hp->y, fp);
| 284 |
putc(hp->dataBits, fp);
| 285 |
putc(hp->imType, fp);
| 286 |
| 287 |
if (ip != NULL)
| 288 |
fputs(ip, fp);
| 289 |
| 290 |
return(ferror(fp) ? -1 : 0);
| 291 |
