root/Development/ray/src/meta/meta2bmp.c
Revision: 1.5
Committed: Wed May 13 00:27:03 2020 UTC (5 years, 7 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changes since 1.4: +7 -18 lines
Minor code cleanup
2 static const char RCSid[] = "$Id: meta2bmp.c,v 1.4 2019/11/18 22:12:32 greg Exp $";
5 * Program to convert meta-files to BMP 8-bit color-mapped format
6 */
7
8 #include "copyright.h"
9
10 #include "rtprocess.h"
11 #include "meta.h"
12 #include "plot.h"
13 #include "rast.h"
14 #include "bmpfile.h"
15 #include "targa.h"
16
17 #define MAXALLOC 100000
18 #define DXSIZE 400 /* default x resolution */
19 #define DYSIZE 400 /* default y resolution */
20 #define XCOM "pexpand +vOCImsp -DP %s | psort +y"
21
22
23 char *progname;
24
25 SCANBLOCK outblock;
26
27 int dxsiz = DXSIZE, dysiz = DYSIZE;
28
29 int maxalloc = MAXALLOC;
30
31 int ydown = 0;
32
33 static char outname[64];
34 static char *outtack = NULL;
35
36 static BMPWriter *bmpw = NULL;
37
38 static int lineno = 0;
39
40 static short condonly = FALSE,
41 conditioned = FALSE;
42
43
44
45
46 char *
47 findtack(char *s) /* find place to tack on suffix */
48 {
49 while (*s && *s != '.')
50 s++;
51 return(s);
52 }
53
54
55 int
56 main(
57 int argc,
58 char **argv
59 )
60 {
61 FILE *fp;
62 char comargs[200], command[300];
63
64 progname = *argv++;
65 argc--;
66
67 condonly = FALSE;
68 conditioned = FALSE;
69
70 while (argc && **argv == '-') {
71 switch (*(*argv+1)) {
72 case 'c':
73 condonly = TRUE;
74 break;
75 case 'r':
76 conditioned = TRUE;
77 break;
78 case 'm':
79 minwidth = atoi(*++argv);
80 argc--;
81 break;
82 case 'x':
83 dxsiz = atoi(*++argv);
84 argc--;
85 break;
86 case 'y':
87 dysiz = atoi(*++argv);
88 argc--;
89 break;
90 case 'o':
91 strcpy(outname, *++argv);
92 outtack = findtack(outname);
93 argc--;
94 break;
95 default:
96 error(WARNING, "unknown option");
97 break;
98 }
99 argv++;
100 argc--;
101 }
102
103 if (conditioned) {
104 if (argc)
105 while (argc) {
106 fp = efopen(*argv, "r");
107 plot(fp);
108 fclose(fp);
109 argv++;
110 argc--;
111 }
112 else
113 plot(stdin);
114 if (lineno)
115 nextpage();
116 } else {
117 comargs[0] = '\0';
118 while (argc) {
119 strcat(comargs, " ");
120 strcat(comargs, *argv);
121 argv++;
122 argc--;
123 }
124 sprintf(command, XCOM, comargs);
125 if (condonly)
126 return(system(command));
127 else {
128 if ((fp = popen(command, "r")) == NULL)
129 error(SYSTEM, "cannot execute input filter");
130 plot(fp);
131 pclose(fp);
132 if (lineno)
133 nextpage();
134 }
135 }
136
137 return(0);
138 }
139
140
141 void
142 thispage(void) /* rewind current file */
143 {
144 if (lineno)
145 error(USER, "cannot restart page in thispage");
146 }
147
148
149 void
150 initfile(void) /* initialize this file */
151 {
152 static const unsigned char cmap[8][3] = {{0,0,0}, {0,0,255}, {0,188,0},
153 {255,152,0}, {0,200,200}, {255,0,255}, {179,179,0}, {255,255,255}};
154 static int filenum = 0;
155 BMPHeader *hp;
156 int i;
157
158 hp = BMPmappedHeader(dxsiz, dysiz, 0, 256);
159 if (hp == NULL)
160 error(USER, "Illegal image parameter(s)");
161 hp->compr = BI_RLE8;
162 for (i = 0; i < 8; i++) {
163 hp->palette[i].r = cmap[i][2];
164 hp->palette[i].g = cmap[i][1];
165 hp->palette[i].b = cmap[i][0];
166 }
167 hp->impColors = 8;
168 if (outtack != NULL) {
169 sprintf(outtack, "%d.bmp", ++filenum);
170 bmpw = BMPopenOutputFile(outname, hp);
171 } else {
172 bmpw = BMPopenOutputStream(stdout, hp);
173 }
174 if (bmpw == NULL)
175 error(USER, "Cannot create output");
176 }
177
178
179 void
180 nextpage(void) /* advance to next page */
181 {
182
183 if (lineno == 0)
184 return;
185 if (bmpw != NULL) {
186 while (lineno < dysiz) {
187 nextblock();
188 outputblock();
189 }
190 BMPcloseOutput(bmpw);
191 bmpw = NULL;
192 }
193 lineno = 0;
194
195 }
196
197
198 #define MINRUN 4
199
200 void
201 printblock(void) /* output scanline block to file */
202 {
203 int i;
204 unsigned char *scanline;
205
206 if (lineno == 0)
207 initfile();
208 for (i = outblock.ybot; i <= outblock.ytop && i < dysiz; i++) {
209 scanline = outblock.cols[i-outblock.ybot] + outblock.xleft;
210 memcpy((void *)bmpw->scanline, (void *)scanline,
211 sizeof(uint8)*(outblock.xright-outblock.xleft+1));
212 if (BMPwriteScanline(bmpw) != BIR_OK)
213 error(SYSTEM, "Error writing BMP file");
214 lineno++;
215 }
216
217 }
