1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Program to convert meta-files to BMP 8-bit color-mapped format |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "rtprocess.h" |
11 |
#include "meta.h" |
12 |
#include "plot.h" |
13 |
#include "rast.h" |
14 |
#include "bmpfile.h" |
15 |
16 |
#define MAXALLOC 30000 |
17 |
#define DXSIZE 400 /* default x resolution */ |
18 |
#define DYSIZE 400 /* default y resolution */ |
19 |
#define XCOM "pexpand +vOCImsp -DP %s | psort +y" |
20 |
21 |
22 |
char *progname; |
23 |
24 |
SCANBLOCK outblock; |
25 |
26 |
int dxsize = DXSIZE, dysize = DYSIZE; |
27 |
28 |
int maxalloc = MAXALLOC; |
29 |
30 |
int ydown = 0; |
31 |
32 |
static char outname[64]; |
33 |
static char *outtack = NULL; |
34 |
35 |
static BMPWriter *bmpw = NULL; |
36 |
37 |
static int lineno = 0; |
38 |
39 |
static short condonly = FALSE, |
40 |
conditioned = FALSE; |
41 |
42 |
static int putthead(struct hdStruct *hp, char *ip, FILE *fp); |
43 |
44 |
45 |
46 |
char * |
47 |
findtack(s) /* find place to tack on suffix */ |
48 |
register char *s; |
49 |
50 |
while (*s && *s != '.') |
51 |
s++; |
52 |
return(s); |
53 |
54 |
55 |
56 |
int |
57 |
main( |
58 |
int argc, |
59 |
char **argv |
60 |
61 |
62 |
63 |
FILE *fp; |
64 |
char comargs[200], command[300]; |
65 |
66 |
progname = *argv++; |
67 |
argc--; |
68 |
69 |
condonly = FALSE; |
70 |
71 |
72 |
while (argc && **argv == '-') { |
73 |
switch (*(*argv+1)) { |
74 |
case 'c': |
75 |
condonly = TRUE; |
76 |
break; |
77 |
case 'r': |
78 |
conditioned = TRUE; |
79 |
break; |
80 |
case 'm': |
81 |
minwidth = atoi(*++argv); |
82 |
argc--; |
83 |
break; |
84 |
case 'x': |
85 |
dxsize = atoi(*++argv); |
86 |
argc--; |
87 |
break; |
88 |
case 'y': |
89 |
dysize = atoi(*++argv); |
90 |
argc--; |
91 |
break; |
92 |
case 'o': |
93 |
strcpy(outname, *++argv); |
94 |
outtack = findtack(outname); |
95 |
argc--; |
96 |
break; |
97 |
default: |
98 |
error(WARNING, "unknown option"); |
99 |
break; |
100 |
101 |
argv++; |
102 |
argc--; |
103 |
104 |
105 |
if (conditioned) { |
106 |
if (argc) |
107 |
while (argc) { |
108 |
fp = efopen(*argv, "r"); |
109 |
plot(fp); |
110 |
fclose(fp); |
111 |
argv++; |
112 |
argc--; |
113 |
114 |
else |
115 |
plot(stdin); |
116 |
if (lineno) |
117 |
nextpage(); |
118 |
} else { |
119 |
comargs[0] = '\0'; |
120 |
while (argc) { |
121 |
strcat(comargs, " "); |
122 |
strcat(comargs, *argv); |
123 |
argv++; |
124 |
argc--; |
125 |
126 |
sprintf(command, XCOM, comargs); |
127 |
if (condonly) |
128 |
return(system(command)); |
129 |
else { |
130 |
if ((fp = popen(command, "r")) == NULL) |
131 |
error(SYSTEM, "cannot execute input filter"); |
132 |
plot(fp); |
133 |
pclose(fp); |
134 |
if (lineno) |
135 |
nextpage(); |
136 |
137 |
138 |
139 |
return(0); |
140 |
141 |
142 |
143 |
144 |
void |
145 |
thispage(void) /* rewind current file */ |
146 |
147 |
if (lineno) |
148 |
error(USER, "cannot restart page in thispage"); |
149 |
150 |
151 |
152 |
void |
153 |
initfile(void) /* initialize this file */ |
154 |
155 |
156 |
static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255, |
157 |
179,179,0, 255,0,255, 0,200,200, 0,0,0}; |
158 |
159 |
static const unsigned char cmap[8][3] = {0,0,0, 0,0,255, 0,188,0, 255,152,0, |
160 |
0,200,200, 255,0,255, 179,179,0, 255,255,255}; |
161 |
static int filenum = 0; |
162 |
BMPHeader *hp; |
163 |
register int i; |
164 |
165 |
hp = BMPmappedHeader(dxsize, dysize, 0, 256); |
166 |
hp->compr = BI_RLE8; |
167 |
if (hp == NULL) |
168 |
error(USER, "Illegal image parameter(s)"); |
169 |
for (i = 0; i < 8; i++) { |
170 |
hp->palette[i].r = cmap[i][2]; |
171 |
hp->palette[i].g = cmap[i][1]; |
172 |
hp->palette[i].b = cmap[i][0]; |
173 |
174 |
hp->impColors = 8; |
175 |
if (outtack != NULL) { |
176 |
sprintf(outtack, "%d.bmp", ++filenum); |
177 |
bmpw = BMPopenOutputFile(outname, hp); |
178 |
} else { |
179 |
bmpw = BMPopenOutputStream(stdout, hp); |
180 |
181 |
if (bmpw == NULL) |
182 |
error(USER, "Cannot create output"); |
183 |
184 |
185 |
186 |
187 |
void |
188 |
nextpage(void) /* advance to next page */ |
189 |
190 |
191 |
192 |
if (lineno == 0) |
193 |
return; |
194 |
if (bmpw != NULL) { |
195 |
while (lineno < dysize) { |
196 |
nextblock(); |
197 |
outputblock(); |
198 |
199 |
BMPcloseOutput(bmpw); |
200 |
bmpw = NULL; |
201 |
202 |
lineno = 0; |
203 |
204 |
205 |
206 |
207 |
208 |
#define MINRUN 4 |
209 |
210 |
extern void |
211 |
printblock(void) /* output scanline block to file */ |
212 |
213 |
214 |
int i, c2; |
215 |
register unsigned char *scanline; |
216 |
register int j, beg, cnt = 0; |
217 |
218 |
if (lineno == 0) |
219 |
initfile(); |
220 |
for (i = outblock.ybot; i <= outblock.ytop && i < dysize; i++) { |
221 |
scanline = outblock.cols[i-outblock.ybot] + outblock.xleft; |
222 |
memcpy((void *)bmpw->scanline, (void *)scanline, |
223 |
sizeof(uint8)*(outblock.xright-outblock.xleft+1)); |
224 |
if (BMPwriteScanline(bmpw) != BIR_OK) |
225 |
error(SYSTEM, "Error writing BMP file"); |
226 |
lineno++; |
227 |
228 |
229 |
