root/radiance/ray/src/meta/meta2bmp.c
Revision: 1.2
Committed: Mon Sep 19 12:48:09 2005 UTC (19 years, 7 months ago) by schorsch
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad3R8, rad3R9, rad4R2P1
Added meta2bmp to SCons build and fixed a few compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.2 static const char RCSid[] = "$Id: meta2bmp.c,v 1.1 2005/05/04 23:43:19 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Program to convert meta-files to BMP 8-bit color-mapped format
6     */
7
8     #include "copyright.h"
9
10     #include "rtprocess.h"
11     #include "meta.h"
12     #include "plot.h"
13     #include "rast.h"
14     #include "bmpfile.h"
15 schorsch 1.2 #include "targa.h"
16 greg 1.1
17     #define MAXALLOC 30000
18     #define DXSIZE 400 /* default x resolution */
19     #define DYSIZE 400 /* default y resolution */
20     #define XCOM "pexpand +vOCImsp -DP %s | psort +y"
21
22
23     char *progname;
24
25     SCANBLOCK outblock;
26
27     int dxsize = DXSIZE, dysize = DYSIZE;
28
29     int maxalloc = MAXALLOC;
30
31     int ydown = 0;
32
33     static char outname[64];
34     static char *outtack = NULL;
35
36     static BMPWriter *bmpw = NULL;
37
38     static int lineno = 0;
39
40     static short condonly = FALSE,
41     conditioned = FALSE;
42
43
44
45
46     char *
47     findtack(s) /* find place to tack on suffix */
48     register char *s;
49     {
50     while (*s && *s != '.')
51     s++;
52     return(s);
53     }
54
55
56     int
57     main(
58     int argc,
59     char **argv
60     )
61
62     {
63     FILE *fp;
64     char comargs[200], command[300];
65
66     progname = *argv++;
67     argc--;
68
69     condonly = FALSE;
70     conditioned = FALSE;
71
72     while (argc && **argv == '-') {
73     switch (*(*argv+1)) {
74     case 'c':
75     condonly = TRUE;
76     break;
77     case 'r':
78     conditioned = TRUE;
79     break;
80     case 'm':
81     minwidth = atoi(*++argv);
82     argc--;
83     break;
84     case 'x':
85     dxsize = atoi(*++argv);
86     argc--;
87     break;
88     case 'y':
89     dysize = atoi(*++argv);
90     argc--;
91     break;
92     case 'o':
93     strcpy(outname, *++argv);
94     outtack = findtack(outname);
95     argc--;
96     break;
97     default:
98     error(WARNING, "unknown option");
99     break;
100     }
101     argv++;
102     argc--;
103     }
104
105     if (conditioned) {
106     if (argc)
107     while (argc) {
108     fp = efopen(*argv, "r");
109     plot(fp);
110     fclose(fp);
111     argv++;
112     argc--;
113     }
114     else
115     plot(stdin);
116     if (lineno)
117     nextpage();
118     } else {
119     comargs[0] = '\0';
120     while (argc) {
121     strcat(comargs, " ");
122     strcat(comargs, *argv);
123     argv++;
124     argc--;
125     }
126     sprintf(command, XCOM, comargs);
127     if (condonly)
128     return(system(command));
129     else {
130     if ((fp = popen(command, "r")) == NULL)
131     error(SYSTEM, "cannot execute input filter");
132     plot(fp);
133     pclose(fp);
134     if (lineno)
135     nextpage();
136     }
137     }
138
139     return(0);
140     }
141
142
143
144     void
145     thispage(void) /* rewind current file */
146     {
147     if (lineno)
148     error(USER, "cannot restart page in thispage");
149     }
150
151
152     void
153     initfile(void) /* initialize this file */
154     {
155     /*
156     static unsigned char cmap[24] = {255,255,255, 255,152,0, 0,188,0, 0,0,255,
157     179,179,0, 255,0,255, 0,200,200, 0,0,0};
158     */
159 schorsch 1.2 static const unsigned char cmap[8][3] = {{0,0,0}, {0,0,255}, {0,188,0},
160     {255,152,0}, {0,200,200}, {255,0,255}, {179,179,0}, {255,255,255}};
161 greg 1.1 static int filenum = 0;
162     BMPHeader *hp;
163     register int i;
164
165     hp = BMPmappedHeader(dxsize, dysize, 0, 256);
166     hp->compr = BI_RLE8;
167     if (hp == NULL)
168     error(USER, "Illegal image parameter(s)");
169     for (i = 0; i < 8; i++) {
170     hp->palette[i].r = cmap[i][2];
171     hp->palette[i].g = cmap[i][1];
172     hp->palette[i].b = cmap[i][0];
173     }
174     hp->impColors = 8;
175     if (outtack != NULL) {
176     sprintf(outtack, "%d.bmp", ++filenum);
177     bmpw = BMPopenOutputFile(outname, hp);
178     } else {
179     bmpw = BMPopenOutputStream(stdout, hp);
180     }
181     if (bmpw == NULL)
182     error(USER, "Cannot create output");
183     }
184
185
186
187     void
188     nextpage(void) /* advance to next page */
189
190     {
191
192     if (lineno == 0)
193     return;
194     if (bmpw != NULL) {
195     while (lineno < dysize) {
196     nextblock();
197     outputblock();
198     }
199     BMPcloseOutput(bmpw);
200     bmpw = NULL;
201     }
202     lineno = 0;
203
204     }
205
206
207
208     #define MINRUN 4
209
210     extern void
211     printblock(void) /* output scanline block to file */
212
213     {
214 schorsch 1.2 int i;
215 greg 1.1 register unsigned char *scanline;
216
217     if (lineno == 0)
218     initfile();
219     for (i = outblock.ybot; i <= outblock.ytop && i < dysize; i++) {
220     scanline = outblock.cols[i-outblock.ybot] + outblock.xleft;
221     memcpy((void *)bmpw->scanline, (void *)scanline,
222     sizeof(uint8)*(outblock.xright-outblock.xleft+1));
223     if (BMPwriteScanline(bmpw) != BIR_OK)
224     error(SYSTEM, "Error writing BMP file");
225     lineno++;
226     }
227
228     }
