root/radiance/ray/src/meta/meta2bmp.c
Wed May 13 00:27:03 2020 UTC (4 years ago) by greg
Changes since 1.4: +7 -18 lines
Diff to previous 1.4
Minor code cleanup
Mon Nov 18 22:12:32 2019 UTC (4 years, 6 months ago) by greg
Changes since 1.3: +7 -7 lines
Diff to previous 1.3
Renamed "dysize" to avoid Linux library conflict
Tue Mar 19 19:34:41 2019 UTC (5 years, 2 months ago) by greg
Diff to previous 1.2
Increased maximum primitive allocation
Mon Sep 19 12:48:09 2005 UTC (18 years, 8 months ago) by schorsch
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2
Diff to previous 1.1
Added meta2bmp to SCons build and fixed a few compile warnings.
Wed May 4 23:43:19 2005 UTC (19 years ago) by greg
Created meta2bmp file to generate BMP output from metafile graphics
