| 1 |
/* RCSid: $Id$ */
| 2 |
| 3 |
* Standard meta-file definitions and limits
| 4 |
| 5 |
| 6 |
| 7 |
#include <stdio.h>
| 8 |
| 9 |
#include <ctype.h>
| 10 |
| 11 |
| 12 |
#define TRUE 1
| 13 |
#define FALSE 0
| 14 |
| 15 |
#define PEOF 'F' /* end of file global */
| 16 |
#define PEOP 'E' /* end of page global */
| 17 |
#define PPAUSE 'P' /* pause global */
| 18 |
#define PDRAW 'D' /* draw global */
| 19 |
#define POPEN 'O' /* open segment */
| 20 |
#define PCLOSE 'C' /* close segment */
| 21 |
#define PSET 'S' /* set global */
| 22 |
#define PUNSET 'U' /* unset global */
| 23 |
#define PRESET 'R' /* reset global to default */
| 24 |
#define PINCL 'I' /* include file */
| 25 |
| 26 |
#define PLSEG 'l' /* line segment command */
| 27 |
#define PRFILL 'r' /* rectangle fill command */
| 28 |
#define PTFILL 't' /* triangle fill command */
| 29 |
#define PMSTR 'm' /* matrix string command */
| 30 |
#define PVSTR 'v' /* vector string command */
| 31 |
#define PSEG 's' /* print segment command */
| 32 |
#define PPFILL 'p' /* polygon fill command */
| 33 |
| 34 |
#define NCOMMANDS 17 /* number of commands */
| 35 |
| 36 |
#define COML "lrtmsvpOCESURPDIF" /* command letters */
| 37 |
| 38 |
#define ADELIM '`' /* additional argument delimiter */
| 39 |
#define CDELIM '#' /* comment delimiter */
| 40 |
| 41 |
#define MAXARGS 512 /* maximum # of arguments for primitive */
| 42 |
| 43 |
#define SALL 0 /* set all */
| 44 |
#define SPAT0 04 /* set pattern 0 */
| 45 |
#define SPAT1 05 /* set pattern 1 */
| 46 |
#define SPAT2 06 /* set pattern 2 */
| 47 |
#define SPAT3 07 /* set pattern 3 */
| 48 |
| 49 |
#define SYSTEM 0 /* system error, internal, fatal */
| 50 |
#define USER 1 /* user error, fatal */
| 51 |
#define WARNING 2 /* user error, not fatal */
| 52 |
| 53 |
#ifdef UNIX
| 54 |
#define TDIR "/tmp/" /* directory for temporary files */
| 55 |
#ifndef MDIR
| 56 |
#define MDIR "/usr/local/lib/meta/" /* directory for metafiles */
| 57 |
#endif
| 58 |
#define TTY "/dev/tty" /* console name */
| 59 |
#endif
| 60 |
| 61 |
#ifdef MAC
| 62 |
#define TDIR "5:tmp/" /* directory for temporary files */
| 63 |
#define MDIR "/meta/" /* directory for metafiles */
| 64 |
#define TTY ".con" /* console name */
| 65 |
#endif
| 66 |
| 67 |
#ifdef CPM
| 68 |
#define TDIR "0/" /* directory for temporary files */
| 69 |
#define MDIR "0/" /* directory for metafiles */
| 70 |
#define TTY "CON:" /* console name */
| 71 |
#endif
| 72 |
| 73 |
#define MAXFNAME 64 /* maximum file name length */
| 74 |
| 75 |
#define XYSIZE (1<<14) /* metafile coordinate size */
| 76 |
| 77 |
#define max(x, y) ((x) > (y) ? (x) : (y))
| 78 |
#define min(x, y) ((x) < (y) ? (x) : (y))
| 79 |
| 80 |
#define abs(x) ((x) < 0 ? -(x) : (x))
| 81 |
| 82 |
#define iscom(c) (comndx(c) != -1)
| 83 |
#define isglob(c) isupper(c)
| 84 |
#define isprim(c) islower(c)
| 85 |
| 86 |
#define WIDTH(wspec) ((wspec)==0 ? 0 : 12*(1<<(wspec)))
| 87 |
#define CONV(coord, size) ((int)(((long)(coord)*(size))>>14))
| 88 |
#define ICONV(dcoord, size) ((int)(((long)(dcoord)<<14)/(size)))
| 89 |
| 90 |
#define XMN 0 /* index in xy array for xmin */
| 91 |
#define YMN 1 /* index in xy array for ymin */
| 92 |
#define XMX 2 /* index in xy array for xmax */
| 93 |
#define YMX 3 /* index in xy array for ymax */
| 94 |
| 95 |
| 96 |
| 97 |
* Structure definitions for primitives
| 98 |
| 99 |
| 100 |
struct primitive { /* output primitive */
| 101 |
short com, /* command (0 - 127) */
| 102 |
arg0; /* first argument (1 byte) */
| 103 |
int xy[4]; /* extent=(xmin,ymin,xmax,ymax) */
| 104 |
char *args; /* additional arguments */
| 105 |
struct primitive *pnext; /* next primitive */
| 106 |
| 107 |
| 108 |
typedef struct primitive PRIMITIVE;
| 109 |
| 110 |
struct plist { /* list of primitives */
| 111 |
PRIMITIVE *ptop, *pbot;
| 112 |
| 113 |
| 114 |
typedef struct plist PLIST;
| 115 |
| 116 |
| 117 |
| 118 |
* External declarations
| 119 |
| 120 |
| 121 |
char *malloc(), *savestr();
| 122 |
| 123 |
PRIMITIVE *palloc(), *pop();
| 124 |
| 125 |
FILE *efopen(), *mfopen();
| 126 |
| 127 |
extern char coms[];
| 128 |
| 129 |
extern char errmsg[];
| 130 |
| 131 |
extern char *progname;
