--- ray/src/meta/meta.h 2003/07/01 21:21:40 1.4 +++ ray/src/meta/meta.h 2003/08/01 14:14:24 1.7 @@ -1,21 +1,22 @@ -/* RCSid: $Id: meta.h,v 1.4 2003/07/01 21:21:40 greg Exp $ */ +/* RCSid: $Id: meta.h,v 1.7 2003/08/01 14:14:24 schorsch Exp $ */ /* * Standard meta-file definitions and limits */ #ifndef _RAD_META_H_ #define _RAD_META_H_ -#ifdef __cplusplus -extern "C" { -#endif #include "copyright.h" #include #include - #include +#include "rterror.h" +#ifdef __cplusplus +extern "C" { +#endif + #define TRUE 1 #define FALSE 0 @@ -53,34 +54,18 @@ extern "C" { #define SPAT2 06 /* set pattern 2 */ #define SPAT3 07 /* set pattern 3 */ -#define SYSTEM 0 /* system error, internal, fatal */ -#define USER 1 /* user error, fatal */ -#define WARNING 2 /* user error, not fatal */ -#ifdef UNIX +#ifdef _WIN32 /* XXX */ +#define MDIR "c\\tmp\\" /* XXX we just need something to compile for now */ +#define TTY "CON:" /* XXX this probably doesn't work */ +#else /* XXX */ + #define TDIR "/tmp/" /* directory for temporary files */ #ifndef MDIR #define MDIR "/usr/local/lib/meta/" /* directory for metafiles */ #endif #define TTY "/dev/tty" /* console name */ #endif - -#ifdef MAC -#define TDIR "5:tmp/" /* directory for temporary files */ -#define MDIR "/meta/" /* directory for metafiles */ -#define TTY ".con" /* console name */ -#endif - -#ifdef CPM -#define TDIR "0/" /* directory for temporary files */ -#define MDIR "0/" /* directory for metafiles */ -#define TTY "CON:" /* console name */ -#endif - -#ifdef _WIN32 /* XXX */ -#define MDIR "c\\tmp\\" /* XXX we just need something to compile for now */ -#define TTY "CON:" /* XXX this probably doesn't work */ -#endif /* XXX */ #define MAXFNAME 64 /* maximum file name length */
