root/radiance/ray/src/meta/meta.h
Mon Mar 22 02:24:23 2004 UTC (21 years, 1 month ago) by greg
Diff to previous 1.9
Increased MAXARGS from 512 to 2048 & undid previous change to metacalls.c
Sat Nov 15 02:13:37 2003 UTC (21 years, 5 months ago) by schorsch
Changes since 1.8: +29 -3 lines
Diff to previous 1.8
Continued ANSIfication, and reduced other compile warnings.
Mon Oct 27 10:28:59 2003 UTC (21 years, 6 months ago) by schorsch
Changes since 1.7: +3 -2 lines
Diff to previous 1.7
Various compatibility fixes.
Fri Aug 1 14:14:24 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 1.6: +7 -19 lines
Diff to previous 1.6
Eliminated CPM, MAC, and UNIX conditional compiles.
Mon Jul 14 22:24:00 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 1.5: +4 -4 lines
Diff to previous 1.5
Mon Jul 14 16:05:45 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.4: +3 -6 lines
Diff to previous 1.4
Changed to relying on error() call in Radiance library
Tue Jul 1 21:21:40 2003 UTC (21 years, 10 months ago) by greg
Diff to previous 1.3
Compile fixes for gcc 3.3
Mon Jun 16 14:54:54 2003 UTC (21 years, 10 months ago) by greg
Changes since 1.2: +2 -3 lines
Diff to previous 1.2
Removed malloc.h includes and renamed mergesort() to pmergesort()
Sun Jun 8 12:03:10 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 1.1: +56 -5 lines
Diff to previous 1.1
Sat Feb 22 02:07:26 2003 UTC (22 years, 2 months ago) by greg
