1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Plotting routines for MacIntosh |
6 |
7 |
8 |
9 |
#include "meta.h" |
10 |
11 |
#include "macplot.h" |
12 |
13 |
14 |
#define NPATS 9 /* number of fill patterns */ |
15 |
16 |
17 |
int pati[4] = {0, 1, 2, 3}; /* pattern indices */ |
18 |
19 |
20 |
* Patterns are 8 X 8, ordered left column to right, one byte per column. |
21 |
22 |
23 |
Pattern macpat[NPATS+4] = { |
24 |
{0377,0377,0377,0377,0377,0377,0377,0377}, /* solid */ |
25 |
{0217,0307,0343,0361,0370,0174,076,037}, /* thick \\\ (dashed) */ |
26 |
{0231,0314,0146,063,0231,0314,0146,063}, /* thin \\\ (dotted) */ |
27 |
{0201,0300,0140,060,030,014,06,03}, /* sparse \\\ */ |
28 |
{037,076,0174,0370,0361,0343,0307,0217}, /* thick /// (dashed) */ |
29 |
{063,0146,0314,0231,063,0146,0314,0231}, /* thin /// (dotted) */ |
30 |
{03,06,014,030,060,0140,0300,0201}, /* sparse /// */ |
31 |
{0201,0102,044,030,030,044,0102,0201}, /* crisscross */ |
32 |
{0201,0101,041,021,011,05,03,0377} /* web */ |
33 |
34 |
35 |
static int context = 0; |
36 |
37 |
struct setting { |
38 |
int cnx; /* setting context */ |
39 |
char *val; /* attribute value */ |
40 |
struct setting *snext; /* next setting in list */ |
41 |
42 |
43 |
static struct setting *sets[0200]; |
44 |
45 |
46 |
47 |
48 |
set(attrib, value) /* set attribute to value */ |
49 |
50 |
int attrib; |
51 |
char *value; |
52 |
53 |
54 |
struct setting *newset; |
55 |
56 |
switch (attrib) { |
57 |
case SALL: |
58 |
context++; |
59 |
return; |
60 |
case SPAT0: |
61 |
case SPAT1: |
62 |
case SPAT2: |
63 |
case SPAT3: |
64 |
if (!spat(attrib, value)) { |
65 |
sprintf(errmsg, "Bad pattern set value: %s", value); |
66 |
error(WARNING, errmsg); |
67 |
return; |
68 |
69 |
break; |
70 |
default: |
71 |
sprintf(errmsg, "Can't set attribute: %o", attrib); |
72 |
73 |
return; |
74 |
75 |
newset = (struct setting *)malloc(sizeof(struct setting)); |
76 |
newset->cnx = context; |
77 |
newset->val = savestr(value); |
78 |
newset->snext = sets[attrib]; |
79 |
sets[attrib] = newset; |
80 |
81 |
82 |
83 |
84 |
85 |
unset(attrib) /* return attribute to previous setting */ |
86 |
87 |
int attrib; |
88 |
89 |
90 |
register int i; |
91 |
92 |
if (attrib == SALL) { |
93 |
if (context == 0) |
94 |
reset(SALL); |
95 |
else { |
96 |
context--; |
97 |
for (i = 0; i < 0200; i++) |
98 |
while (sets[i] != NULL && sets[i]->cnx > context) |
99 |
spop(i); |
100 |
101 |
return; |
102 |
103 |
spop(attrib); |
104 |
if (sets[attrib] == NULL) |
105 |
reset(attrib); |
106 |
107 |
switch (attrib) { |
108 |
case SPAT0: |
109 |
case SPAT1: |
110 |
case SPAT2: |
111 |
case SPAT3: |
112 |
spat(attrib, sets[attrib]->val); |
113 |
break; |
114 |
default: |
115 |
sprintf(errmsg, "Can't unset attribute: %o", attrib); |
116 |
117 |
return; |
118 |
119 |
120 |
121 |
122 |
123 |
124 |
125 |
reset(attrib) /* return attribute to default setting */ |
126 |
127 |
int attrib; |
128 |
129 |
130 |
switch (attrib) { |
131 |
case SALL: |
132 |
reset(SPAT0); |
133 |
reset(SPAT1); |
134 |
reset(SPAT2); |
135 |
reset(SPAT3); |
136 |
context = 0; |
137 |
return; |
138 |
case SPAT0: |
139 |
spat(SPAT0, "P0"); |
140 |
break; |
141 |
case SPAT1: |
142 |
spat(SPAT1, "P1"); |
143 |
break; |
144 |
case SPAT2: |
145 |
spat(SPAT2, "P2"); |
146 |
break; |
147 |
case SPAT3: |
148 |
spat(SPAT3, "P3"); |
149 |
break; |
150 |
default: |
151 |
sprintf(errmsg, "Can't reset attribute: %o", attrib); |
152 |
153 |
return; |
154 |
155 |
while (sets[attrib] != NULL) |
156 |
spop(attrib); |
157 |
158 |
159 |
160 |
161 |
162 |
static |
163 |
spop(attrib) /* pop top off attrib settings list */ |
164 |
165 |
int attrib; |
166 |
167 |
168 |
169 |
if (sets[attrib] != NULL) { |
170 |
if (sets[attrib]->val != NULL) |
171 |
free(sets[attrib]->val); |
172 |
free((char *)sets[attrib]); |
173 |
sets[attrib] = sets[attrib]->snext; |
174 |
175 |
176 |
177 |
178 |
179 |
180 |
181 |
static int |
182 |
spat(pat, patval) /* set a pattern */ |
183 |
184 |
int pat; |
185 |
char *patval; |
186 |
187 |
188 |
int n, v; |
189 |
char *nextscan(); |
190 |
register char *cp; |
191 |
register int j; |
192 |
193 |
if (patval == NULL) return(FALSE); |
194 |
195 |
if (patval[0] == 'P' || patval[0] == 'p') { |
196 |
if (nextscan(patval+1, "%d", &n) == NULL || n < 0 || n >= NPATS) |
197 |
return(FALSE); |
198 |
} else { |
199 |
n = NPATS + pat - SPAT0; |
200 |
cp = patval; |
201 |
for (j = 0; j < 8; j++) { |
202 |
if ((cp = nextscan(cp, "%o", &v)) == NULL || v < 0 || v > 0377) |
203 |
return(FALSE); |
204 |
macpat[n][j] = v; |
205 |
206 |
207 |
pati[pat-SPAT0] = n; |
208 |
return(TRUE); |
209 |
