root/radiance/ray/src/meta/lib4014/lib4014.h
Revision: 1.1
Committed: Sat Nov 15 02:13:37 2003 UTC (21 years, 7 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Continued ANSIfication, and reduced other compile warnings.
1 /* RCSid: $Id: random.h,v 1.2 2003/07/14 22:24:00 schorsch Exp $ */
2 /*
3 * random.h - header file for random(3) function.
4 *
5 * 10/1/85
6 */
7 #ifndef _RAD_LIB4014_H_
8 #define _RAD_LIB4014_H_
9
10 #include <stdlib.h>
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 extern void openvt(void);
17 extern void openpl(void);
18 extern void closevt(void);
19 extern void closepl(void);
20
21 extern void step(int d);
22 extern void arc(int x, int y, int x0, int y0, int x1, int y1);
23 extern int quad(int x, int y, int xp, int yp);
24 extern int abs_(int a);
25 extern void box(int x0, int y0, int x1, int y1);
26 extern void circle(int x, int y, int r);
27 extern void dot(void);
28 extern void erase(void);
29 extern void label(char *s);
30 extern void line(int x0, int y0, int x1, int y1);
31 extern void linemod(char *s);
32 extern void move(int xi, int yi);
33 extern void point(int xi, int yi);
34 extern void scale(char i, float x, float y);
35 extern void space(int x0, int y0, int x1, int y1);
36 extern void cont(int x, int y);
37 extern void putch(int c);
38
39
40
41 #ifdef __cplusplus
42 }
43 #endif
44 #endif /* _RAD_LIB4014_H_ */
45
