root/Development/ray/src/meta/lib4014/arc.c
Revision: 1.3
Committed: Sat Nov 15 02:13:37 2003 UTC (22 years, 1 month ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 1.2: +34 -8 lines
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.3 static const char RCSid[] = "$Id: arc.c,v 1.2 2003/10/27 10:28:59 schorsch Exp $";
3 greg 1.1 #endif
4 schorsch 1.3
5     #include "local4014.h"
6     #include "lib4014.h"
7 greg 1.1
8     int del = 20;
9 schorsch 1.3
10     extern void
11     step(int d)
12     {
13 greg 1.1 del = d;
14     }
15 schorsch 1.3
16     extern void
17     arc(
18     int x,
19     int y,
20     int x0,
21     int y0,
22     int x1,
23     int y1
24     )
25     {
26 greg 1.1 double pc;
27     double sqrt();
28     int flg,m,xc,yc,xs,ys,qs,qf;
29     float dx,dy,r;
30     char use;
31     dx = x-x0;
32     dy = y-y0;
33     r = dx*dx+dy*dy;
34     pc = r;
35     pc = sqrt(pc);
36     flg = pc/4;
37     if(flg == 0)step(1);
38     else if(flg < del)step(flg);
39     xc = xs = x0;
40     yc = ys = y0;
41     move(xs,ys);
42     if(x0 == x1 && y0 == y1)flg=0;
43     else flg=1;
44     qs = quad(x,y,x0,y0);
45     qf = quad(x,y,x1,y1);
46 schorsch 1.2 if(abs_(x-x1) < abs_(y-y1)){
47 greg 1.1 use = 'x';
48     if(qs == 2 || qs ==3)m = -1;
49     else m=1;
50     }
51     else {
52     use = 'y';
53     if(qs > 2)m= -1;
54     else m= 1;
55     }
56     while(1){
57     switch(use){
58     case 'x':
59     if(qs == 2 || qs == 3)yc -= del;
60     else yc += del;
61     dy = yc-y;
62     pc = r-dy*dy;
63     xc = m*sqrt(pc)+x;
64     if((x < xs && x >= xc) || ( x > xs && x <= xc) ||
65     (y < ys && y >= yc) || ( y > ys && y <= yc) )
66     {
67     if(++qs > 4)qs=1;
68     if(qs == 2 || qs == 3)m= -1;
69     else m=1;
70     flg=1;
71     }
72     cont(xc,yc);
73     xs = xc;
74     ys = yc;
75     if(qs == qf && flg == 1)
76     switch(qf){
77     case 3:
78     case 4:
79     if(xs >= x1)return;
80     continue;
81     case 1:
82     case 2:
83     if(xs <= x1)return;
84     }
85     continue;
86     case 'y':
87     if(qs > 2)xc += del;
88     else xc -= del;
89     dx = xc-x;
90     pc = r-dx*dx;
91     yc = m*sqrt(pc)+y;
92     if((x < xs && x >= xc) || ( x > xs && x <= xc ) ||
93     (y < ys && y >= yc) || (y > ys && y <= yc) )
94     {
95     if(++qs > 4)qs=1;
96     if(qs > 2)m = -1;
97     else m = 1;
98     flg=1;
99     }
100     cont(xc,yc);
101     xs = xc;
102     ys = yc;
103     if(qs == qf && flg == 1)
104     switch(qs){
105     case 1:
106     case 4:
107     if(ys >= y1)return;
108     continue;
109     case 2:
110     case 3:
111     if(ys <= y1)return;
112     }
113     }
114     }
115     }
116 schorsch 1.3
117     extern int
118     quad(
119     int x,
120     int y,
121     int xp,
122     int yp
123     )
124     {
125 greg 1.1 if(x < xp)
126     if(y <= yp)return(1);
127     else return(4);
128     else if(x > xp)
129     if(y < yp)return(2);
130     else return(3);
131     else if(y < yp)return(2);
132     else return(4);
133     }
134 schorsch 1.3
135     extern int
136     abs_( /* Windows complains that abs() is an "internal function" */
137     int a
138     )
139     {
140 greg 1.1 if(a < 0)return(-a);
141     return(a);
142     }
