root/radiance/ray/src/meta/implot.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (20 years, 7 months ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Changes since 1.1: +47 -43 lines
Continued ANSIfication, and reduced other compile warnings.
2 static const char RCSid[] = "$Id: implot.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * Impress plotting functions
6 *
7 * 1/2/86
8 */
9
10
11 #include "meta.h"
12
13 #include "plot.h"
14
15 #include "imPfuncs.h"
16
17 #include "imPcodes.h"
18
19 #include <ctype.h>
20
21
22 #define mapx(x) CONV(x,dxsize)
23 #define mapy(y) CONV(y,dysize)
24
25 #define DPI 296 /* dots per inch for imagen */
26
27 #define TexFamily 90 /* family for texture glyphs */
28
29 /* operation codes for graphics */
30 #define whiteOp 0
31 #define shadeOp 3
32 #define orOp 7
33 #define blackOp 15
34
35 /* imagen resident fonts */
36 static struct {
37 char *name; /* font name */
38 int iwspace; /* interword spacing */
39 short loaded; /* boolean true if font loaded */
40 } font[] = {
41 {"cour07", 21, FALSE},
42 {"cour08", 24, FALSE},
43 {"cour10", 30, FALSE},
44 {"cour12", 36, FALSE},
45 {"cour14", 42, FALSE},
46 {"zurm20", 60, FALSE}
47 };
48
49 /* map from our matrix string types */
50 static int fontmap[16] = {3,4,4,5,2,4,4,5,1,2,2,3,0,2,2,3};
51
52 int dxsize, dysize; /* page size */
53
54 static void settex(int pp);
55 static void setpen(register int ps);
56
57
58
59 void
60 imInit(void) /* initialize imagen */
61 {
62
63 imout = stdout;
64
65 fputs("@document(language imPress)", imout);
66 fputs("@document(pagereversal off)", imout);
67
68 imSetPum(0); /* new path deletes old one */
69 dxsize = dysize = 8 * DPI; /* square on 8.5 X 11 in. paper */
70 imSetAbsH(DPI/4); /* .25 in. on left and right */
71 imSetAbsV(dysize);
72 imSetHVSystem(3, 3, 4); /* conventional orientation */
73
74 }
75
76
77 void
78 printstr( /* output a string */
79 register PRIMITIVE *p
80 )
81
82 {
83 static int curfont = -1;
84 int fn;
85 register char *cp;
86
87 fn = fontmap[(p->arg0 >> 2) & 017]; /* get font number */
88 /* set font */
89 if (fn != curfont) {
90 imSetFamily(fn);
91 if (!font[fn].loaded) {
92 imCreateFamilyTable(fn, 1, 0, font[fn].name);
93 font[fn].loaded = TRUE;
94 }
95 imSetSp(font[fn].iwspace);
96 curfont = fn;
97 }
98
99 imSetAbsH(mapx(p->xy[XMN])); /* set page position */
100 imSetAbsV(mapy(p->xy[YMN]));
101
102 for (cp = p->args; *cp; cp++) /* write out the string */
103 if (isspace(*cp))
104 imSp();
105 else
106 im_putbyte(*cp);
107
108 }
109
110
111
112
113 void
114 plotlseg( /* plot a line segment */
115 register PRIMITIVE *p
116 )
117
118 {
119 int x1, x2, y1, y2;
120 short pp;
121
122 pp = (p->arg0 >> 4) & 03;
123 if (p->arg0 & 0100 && pp != 0)
124 pp += 03;
125 settex(pp);
126
127 setpen((p->arg0 >> 2) & 03);
128
129 x1 = mapx(p->xy[XMN]);
130 x2 = mapx(p->xy[XMX]);
131
132 if (p->arg0 & 0100) {
133 y1 = mapy(p->xy[YMX]);
134 y2 = mapy(p->xy[YMN]);
135 } else {
136 y1 = mapy(p->xy[YMN]);
137 y2 = mapy(p->xy[YMX]);
138 }
139
140 imCreatePath(2, x1, y1, x2, y2);
141 imDrawPath(orOp);
142
143 }
144
145
146
147 void
148 setfill( /* set filling mode */
149 register int a0
150 )
151
152 {
153
154 settex(pati[(a0 >> 2) & 03]);
155
156 }
157
158
159 void
160 setpen( /* set pen size to ps */
161 register int ps
162 )
163
164 {
165 static int curpsiz = -1; /* current pen size */
166
167 if (ps == curpsiz)
168 return;
169
170 curpsiz = ps;
171 ps = WIDTH(ps);
172 ps = CONV(ps, dxsize);
173 if (ps < 2)
174 ps = 2;
175 else if (ps > 20)
176 ps = 20;
177 imSetPen(ps);
178
179 }
180
181
182 void
183 settex( /* set texture pattern to pp */
184 int pp
185 )
186
187 {
188 static int curtex = -1; /* current texture */
189 static short ploaded[NPATS]; /* booleans for loaded patterns */
190 char span[4];
191 int i, k;
192 register int j;
193
194 if (pp == curtex) /* already set */
195 return;
196
197 if (pp == 0) { /* all black */
198 imSetTexture(0, 0); /* special case */
199 curtex = 0;
200 return;
201 }
202
203 if (pp >= NPATS || !ploaded[pp]) { /* download texture glyph */
204 im_77(imP_BGLY, TexFamily, pp); /* family and member */
205 im_putword(32); /* advance-width */
206 im_putword(32); /* width */
207 im_putword(0); /* left-offset */
208 im_putword(32); /* height */
209 im_putword(0); /* top-offset */
210 for (i = PATSIZE-1; i >= 0; i--) {
211 for (j = 0; j < 4; j++)
212 span[j] = 0;
213 for (j = 0; j < 32; j++)
214 span[j>>3] |= ((pattern[pp][i>>3][j/(32/PATSIZE)]
215 >> (i&07)) & 01) << (7-(j&07));
216 for (k = 0; k < 32/PATSIZE; k++)
217 for (j = 0; j < 4; j++)
218 im_putbyte(span[j]);
219 }
220 if (pp < NPATS)
221 ploaded[pp]++;
222 }
223 imSetTexture(TexFamily, pp);
224 curtex = pp;
225
226 }
227
228
229 void
230 fillrect( /* fill a rectangle */
231 register PRIMITIVE *p
232 )
233
234 {
235 int left, right, top, bottom;
236
237 left = mapx(p->xy[XMN]);
238 right = mapx(p->xy[XMX]);
239 top = mapy(p->xy[YMX]);
240 bottom = mapy(p->xy[YMN]);
241
242 setfill(p->arg0);
243 imCreatePath(4, left, bottom, right, bottom, right, top, left, top);
244 imFillPath(orOp);
245
246 }
247
248
249 void
250 filltri( /* fill a triangle */
251 register PRIMITIVE *p
252 )
253
254 {
255 int left, right, top, bottom;
256
257 left = mapx(p->xy[XMN]);
258 right = mapx(p->xy[XMX]);
259 top = mapy(p->xy[YMX]);
260 bottom = mapy(p->xy[YMN]);
261
262 setfill(p->arg0);
263
264 switch (p->arg0 & 060) {
265 case 0: /* right (& down) */
266 imCreatePath(3, left, bottom, right, bottom, right, top);
267 break;
268 case 020: /* up */
269 imCreatePath(3, right, bottom, right, top, left, top);
270 break;
271 case 040: /* left */
272 imCreatePath(3, right, top, left, top, left, bottom);
273 break;
274 case 060: /* down */
275 imCreatePath(3, left, top, left, bottom, right, bottom);
276 break;
277 }
278
279 imFillPath(orOp);
280
281 }
282
283
284
285 void
286 xform( /* transform a point according to p */
287 register int *xp,
288 register int *yp,
289 register PRIMITIVE *p
290 )
291
292 {
293 int x = 0, y = 0;
294
295 switch (p->arg0 & 060) {
296 case 0: /* right */
297 x = *xp;
298 y = *yp;
299 break;
300 case 020: /* up */
301 x = (XYSIZE-1) - *yp;
302 y = *xp;
303 break;
304 case 040: /* left */
305 x = (XYSIZE-1) - *xp;
306 y = (XYSIZE-1) - *yp;
307 break;
308 case 060: /* down */
309 x = *yp;
310 y = (XYSIZE-1) - *xp;
311 break;
312 }
313
314 *xp = CONV(x, p->xy[XMX] - p->xy[XMN]) + p->xy[XMN];
315 *yp = CONV(y, p->xy[YMX] - p->xy[YMN]) + p->xy[YMN];
316
317 }
318
319
320 void
321 fillpoly( /* fill a polygon */
322 register PRIMITIVE *p
323 )
324
325 {
326 int points[128];
327 register int *pp;
328 register char *s;
329
330 pp = points;
331
332 if ((s = nextscan(nextscan(p->args,"%d",(char*)pp),"%d",(char*)pp+1))==NULL)
333 error(USER, "illegal polygon spec in fillpoly");
334
335 xform(pp, pp+1, p);
336 pp[0] = mapx(pp[0]); pp[1] = mapy(pp[1]);
337 pp += 2;
338
339 while ((s = nextscan(nextscan(s,"%d",(char*)pp),"%d",(char*)pp+1))!=NULL) {
340 xform(pp, pp+1, p);
341 pp[0] = mapx(pp[0]); pp[1] = mapy(pp[1]);
342 pp += 2;
343 }
344 pp[0] = points[0]; pp[1] = points[1];
345 pp += 2;
346
347 settex(p->arg0 & 077);
348 imCreatePathV((pp-points)/2, points);
349 imFillPath(orOp);
350
351 if (p->arg0 & 0100) { /* draw border */
352 settex(0);
353 setpen(0);
354 imDrawPath(orOp);
355 }
356
357 }
