root/radiance/ray/src/meta/imPfuncs.h
Revision: 1.4
Committed: Sun Mar 28 20:33:13 2004 UTC (21 years, 3 months ago) by schorsch
CVS Tags: rad3R7P1, rad3R7P2, rad3R6, rad3R8, rad3R6P1
Changes since 1.3: +3 -3 lines
# User Rev Content
1 schorsch 1.4 /* RCSid: $Id: imPfuncs.h,v 1.3 2003/11/15 02:13:37 schorsch Exp $ */
2 greg 1.1 /*
3     * imPfuncs - imPress functions
4     *
5     * Written by William LeFebvre, LCSE, Rice University
6     *
7     * This program can be freely redistributed to anyone, with the following
8     * provisions: that this comment remain intact, and that no money is
9     * charged or collected for that redistribution.
10     */
11
12     /*
13     * These functions are part of the imPress functional interface routines.
14     */
15 schorsch 1.2 #ifndef _RAD_IMPFUNCS_H_
16     #define _RAD_IMPFUNCS_H_
17
18 schorsch 1.3 #include <varargs.h>
19
20 schorsch 1.2 #ifdef __cplusplus
21     extern "C" {
22     #endif
23 greg 1.1
24     #define im_putbyte(c) putc((c) & 0377, imout)
25     #define im_putword(w) (im_putbyte((w) >> 8), im_putbyte(w))
26
27     #define im_b(code, b) (putc(code, imout), im_putbyte(b))
28
29     /* function definitions for imPress commands */
30
31     #define imBrule(wa, wb, wc) im_www(imP_BRULE, wa, wb, wc)
32     #define imCircArc(wa, wb, wc) im_www(imP_CIRC_ARC, wa, wb, wc)
33     #define imCircSegm(wa, wb, wc, wd, we) \
34     im_wwwww(imP_CIRC_SEGM, wa, wb, wc, wd, we)
35     #define imCrLf() putc(imP_CRLF, imout)
36     #define imDrawPath(b) im_b(imP_DRAW_PATH, b)
37     #define imEllipseArc(wa, wb, wc, wd, we) \
38     im_wwwww(imP_ELLIPSE_ARC, wa, wb, wc, wd, we)
39     #define imEndPage() putc(imP_ENDPAGE, imout)
40     #define imEof() putc(imP_EOF, imout)
41     #define imFillPath(b) im_b(imP_FILL_PATH, b)
42     #define imMminus() putc(imP_MMINUS, imout)
43     #define imMmove(w) im_w(imP_MMOVE, w)
44     #define imMplus() putc(imP_MPLUS, imout)
45     #define imMplus() putc(imP_MPLUS, imout)
46     #define imNoOp() putc(imP_NO_OP, imout)
47     #define imPage() putc(imP_PAGE, imout)
48     #define imPop() putc(imP_POP, imout)
49     #define imPush() putc(imP_PUSH, imout)
50     #define imSetAbsH(w) im_w(imP_SET_ABS_H, w)
51     #define imSetAbsV(w) im_w(imP_SET_ABS_V, w)
52     #define imSetAdvDirs(b2, b1) im_21(imP_SET_ADV_DIRS, b2, b1)
53     #define imSetBol(w) im_w(imP_SET_BOL, w)
54     #define imSetFamily(b) im_b(imP_SET_FAMILY, b)
55     #define imSetHVSystem(b2o, b2a, b3) im_223(imP_SET_HV_SYSTEM, b2o, b2a, b3)
56     #define imSetIl(w) im_w(imP_SET_IL, w)
57     #define imSetMagnification(b) im_b(imP_SET_MAGN, b)
58     #define imSetPen(b) im_b(imP_SET_PEN, b)
59     #define imSetPum(b1) im_b(imP_SET_PUM, b1)
60     #define imSetPushMask(w) im_w(imP_SET_PUSH_MASK, w)
61     #define imSetRelH(w) im_w(imP_SET_REL_H, w)
62     #define imSetRelV(w) im_w(imP_SET_REL_V, w)
63     #define imSetSp(w) im_w(imP_SET_SP, w)
64     #define imSetTexture(b7a, b7b) im_77(imP_SET_TEXTURE, b7a, b7b)
65     #define imSmove(w) im_w(imP_SMOVE, w)
66     #define imSp() putc(imP_SP, imout)
67     #define imSp1() putc(imP_SP1, imout)
68
69     /* Push mask defines: */
70
71     #define imPM_PEN_TEXTURE 0x100
72     #define imPM_SP 0x080
73     #define imPM_IL 0x040
74     #define imPM_BOL 0x020
75     #define imPM_FAMILY 0x010
76     #define imPM_HV_POS 0x008
77     #define imPM_ADV_DIRS 0x004
78     #define imPM_ORIGIN 0x002
79     #define imPM_ORIENTATION 0x001
80
81     extern FILE *imout;
82 schorsch 1.3
83     extern void im_w(int code, unsigned int w);
84     extern void im_223(int code,unsigned int b2a,unsigned int b2b,unsigned int b3);
85     extern void im_77(int code, unsigned int b7a, unsigned int b7b);
86 schorsch 1.4 /* extern void imCreateFamilyTable(char *s, ...); */ /* XXX */
87     /* extern void imCreatePath(char *s, ...); */ /* XXX */
88 schorsch 1.3 extern void imCreatePathV(unsigned int count, unsigned int *vec);
89     extern void imInit(void);
90 schorsch 1.2
91     #ifdef __cplusplus
92     }
93     #endif
94     #endif /* _RAD_IMPFUNCS_H_ */
95
