root/radiance/ray/src/meta/imPfuncs.c
Revision: 1.2
Committed: Sat Nov 15 02:13:37 2003 UTC (20 years, 6 months ago) by schorsch
Changes since 1.1: +54 -32 lines
Continued ANSIfication, and reduced other compile warnings.
2 static const char RCSid[] = "$Id: imPfuncs.c,v 1.1 2003/02/22 02:07:26 greg Exp $";
5 * imPfuncs - functional interface to imPress, support for imPfuncs.h
6 *
7 * Written by William LeFebvre, LCSE, Rice University
8 *
9 * This program can be freely redistributed to anyone, with the following
10 * provisions: that this comment remain intact, and that no money is
11 * charged or collected for that redistribution.
12 */
13
14 #include <stdio.h>
15 #include <varargs.h>
16 #include "imPcodes.h"
17 #include "imPfuncs.h"
18
19 /* commands with byte operands */
20
21 /* im_b(code, b) is defined in imPfuncs.h */
22
23 /* commands with word operands: */
24
25
26 void
27 im_w(
28 int code,
29 unsigned int w
30 )
31
32 {
33 putc(code, imout);
34 im_putword(w);
35 }
36
37
38 void
39 im_www(
40 int code,
41 unsigned int wa,
42 unsigned int wb,
43 unsigned int wc
44 )
45
46 {
47 putc(code, imout);
48 im_putword(wa);
49 im_putword(wb);
50 im_putword(wc);
51 }
52
53
54 void
55 im_wwwww(
56 int code,
57 unsigned int wa,
58 unsigned int wb,
59 unsigned int wc,
60 unsigned int wd,
61 unsigned int we
62 )
63
64 {
65 putc(code, imout);
66 im_putword(wa);
67 im_putword(wb);
68 im_putword(wc);
69 im_putword(wd);
70 im_putword(we);
71 }
72
73 /* commands with bit operands: */
74
75 void
76 im_21( /* pads 5 bits on left */
77 int code,
78 unsigned int b2,
79 unsigned int b1
80 )
81
82 {
83 putc(code, imout);
84 im_putbyte((b2 << 1) | b1);
85 }
86
87
88 void
89 im_223( /* pads 1 bit on left */
90 int code,
91 unsigned int b2a,
92 unsigned int b2b,
93 unsigned int b3
94 )
95
96 {
97 putc(code, imout);
98 im_putbyte((b2a << 5) | (b2b << 3) | b3);
99 }
100
101
102 void
103 im_77( /* pads 2 bits on left */
104 int code,
105 unsigned int b7a,
106 unsigned int b7b
107 )
108
109 {
110 putc(code, imout);
111 im_putword((b7a << 7) | b7b);
112 }
113
114
115 void
116 im_putstring(
117 char *string
118 )
119
120 {
121 fputs(string, imout);
122 im_putbyte(0);
123 }
124
125
126 void
127 imCreateFamilyTable(va_alist)
128
129 va_dcl
130
131 {
132 va_list vars;
133 unsigned int family;
134 unsigned int pairs;
135 unsigned int map_name;
136 char *font_name;
137
138 va_start(vars);
139
140 /* first arguments are: family, pairs */
141 family = va_arg(vars, unsigned int);
142 pairs = va_arg(vars, unsigned int);
143
144 /* write the first part of the command */
145 putc(imP_CREATE_FAMILY_TABLE, imout);
146 im_putbyte(family);
147 im_putbyte(pairs);
148
149 /* write each map_name, font_name pair */
150 while (pairs-- > 0)
151 {
152 map_name = va_arg(vars, unsigned int);
153 im_putbyte(map_name);
154 font_name = va_arg(vars, char *);
155 im_putstring(font_name);
156 }
157
158 va_end(vars);
159 }
160
161
162 void
163 imCreatePath(va_alist)
164
165 va_dcl
166
167 {
168 va_list vars;
169 int count;
170 int h;
171 int v;
172
173 va_start(vars);
174
175 /* first argument is vertex-count */
176 count = va_arg(vars, int);
177
178 /* write the first part of the command */
179 putc(imP_CREATE_PATH, imout);
180 im_putword(count);
181
182 /* write each vertex pair */
183 while (count-- > 0)
184 {
185 h = va_arg(vars, int);
186 im_putword(h);
187 v = va_arg(vars, int);
188 im_putword(v);
189 }
190 }
191
192
193 void
194 imCreatePathV(
195 unsigned int count,
196 unsigned int *vec
197 )
198
199 {
200 /* write the first part of the command */
201 putc(imP_CREATE_PATH, imout);
202 im_putword(count);
203
204 /* write each vertex pair */
205 while (count-- > 0)
206 {
207 im_putword(*vec); /* these are macros... */
208 vec++; /* so im_putword(*vec++) won't always work */
209 im_putword(*vec);
210 vec++;
211 }
212 }
213
214 #ifdef notyet
215 /* stuff we still have to do: */
216 imBitmap(...)
217 #endif
