1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: imPfuncs.c,v 1.3 2004/03/28 20:33:13 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* imPfuncs - functional interface to imPress, support for imPfuncs.h |
6 |
7 |
* Written by William LeFebvre, LCSE, Rice University |
8 |
9 |
* This program can be freely redistributed to anyone, with the following |
10 |
* provisions: that this comment remain intact, and that no money is |
11 |
* charged or collected for that redistribution. |
12 |
13 |
14 |
#include <stdio.h> |
15 |
#include <varargs.h> |
16 |
#include "imPcodes.h" |
17 |
#include "imPfuncs.h" |
18 |
19 |
/* commands with byte operands */ |
20 |
21 |
/* im_b(code, b) is defined in imPfuncs.h */ |
22 |
23 |
/* commands with word operands: */ |
24 |
25 |
26 |
void |
27 |
im_w( |
28 |
int code, |
29 |
unsigned int w |
30 |
31 |
32 |
33 |
putc(code, imout); |
34 |
im_putword(w); |
35 |
36 |
37 |
38 |
void |
39 |
im_www( |
40 |
int code, |
41 |
unsigned int wa, |
42 |
unsigned int wb, |
43 |
unsigned int wc |
44 |
45 |
46 |
47 |
48 |
im_putword(wa); |
49 |
im_putword(wb); |
50 |
im_putword(wc); |
51 |
52 |
53 |
54 |
void |
55 |
im_wwwww( |
56 |
int code, |
57 |
unsigned int wa, |
58 |
unsigned int wb, |
59 |
unsigned int wc, |
60 |
unsigned int wd, |
61 |
unsigned int we |
62 |
63 |
64 |
65 |
66 |
im_putword(wa); |
67 |
im_putword(wb); |
68 |
im_putword(wc); |
69 |
im_putword(wd); |
70 |
im_putword(we); |
71 |
72 |
73 |
/* commands with bit operands: */ |
74 |
75 |
void |
76 |
im_21( /* pads 5 bits on left */ |
77 |
int code, |
78 |
unsigned int b2, |
79 |
unsigned int b1 |
80 |
81 |
82 |
83 |
84 |
im_putbyte((b2 << 1) | b1); |
85 |
86 |
87 |
88 |
void |
89 |
im_223( /* pads 1 bit on left */ |
90 |
int code, |
91 |
unsigned int b2a, |
92 |
unsigned int b2b, |
93 |
unsigned int b3 |
94 |
95 |
96 |
97 |
98 |
im_putbyte((b2a << 5) | (b2b << 3) | b3); |
99 |
100 |
101 |
102 |
void |
103 |
im_77( /* pads 2 bits on left */ |
104 |
int code, |
105 |
unsigned int b7a, |
106 |
unsigned int b7b |
107 |
108 |
109 |
110 |
111 |
im_putword((b7a << 7) | b7b); |
112 |
113 |
114 |
115 |
void |
116 |
im_putstring( |
117 |
char *string |
118 |
119 |
120 |
121 |
fputs(string, imout); |
122 |
im_putbyte(0); |
123 |
124 |
125 |
126 |
extern void |
127 |
imCreateFamilyTable(va_alist) |
128 |
129 |
va_dcl |
130 |
131 |
132 |
va_list vars; |
133 |
unsigned int family; |
134 |
unsigned int pairs; |
135 |
unsigned int map_name; |
136 |
char *font_name; |
137 |
138 |
va_start(vars); |
139 |
140 |
/* first arguments are: family, pairs */ |
141 |
family = va_arg(vars, unsigned int); |
142 |
pairs = va_arg(vars, unsigned int); |
143 |
144 |
/* write the first part of the command */ |
145 |
putc(imP_CREATE_FAMILY_TABLE, imout); |
146 |
im_putbyte(family); |
147 |
im_putbyte(pairs); |
148 |
149 |
/* write each map_name, font_name pair */ |
150 |
while (pairs-- > 0) |
151 |
152 |
map_name = va_arg(vars, unsigned int); |
153 |
im_putbyte(map_name); |
154 |
font_name = va_arg(vars, char *); |
155 |
im_putstring(font_name); |
156 |
157 |
158 |
va_end(vars); |
159 |
160 |
161 |
162 |
extern void |
163 |
imCreatePath(va_alist) |
164 |
165 |
va_dcl |
166 |
167 |
168 |
va_list vars; |
169 |
int count; |
170 |
int h; |
171 |
int v; |
172 |
173 |
va_start(vars); |
174 |
175 |
/* first argument is vertex-count */ |
176 |
count = va_arg(vars, int); |
177 |
178 |
179 |
putc(imP_CREATE_PATH, imout); |
180 |
im_putword(count); |
181 |
182 |
/* write each vertex pair */ |
183 |
while (count-- > 0) |
184 |
185 |
h = va_arg(vars, int); |
186 |
im_putword(h); |
187 |
v = va_arg(vars, int); |
188 |
im_putword(v); |
189 |
190 |
191 |
192 |
193 |
void |
194 |
imCreatePathV( |
195 |
unsigned int count, |
196 |
unsigned int *vec |
197 |
198 |
199 |
200 |
201 |
202 |
203 |
204 |
205 |
206 |
207 |
im_putword(*vec); /* these are macros... */ |
208 |
vec++; /* so im_putword(*vec++) won't always work */ |
209 |
im_putword(*vec); |
210 |
vec++; |
211 |
212 |
213 |
214 |
#ifdef notyet |
215 |
/* stuff we still have to do: */ |
216 |
imBitmap(...) |
217 |
#endif |
