root/radiance/ray/src/meta/igraph.c
Revision: 1.1
Committed: Sat Feb 22 02:07:26 2003 UTC (22 years, 1 month ago) by greg
5 * igraph.c - interactive graphing program.
6 *
7 * 6/30/86
8 *
9 * Greg Ward Larson
10 */
11
12 #include <stdio.h>
13
14 #include <ctype.h>
15
16 #include <setjmp.h>
17
18 #include "mgvars.h"
19
20 typedef struct {
21 char *descrip; /* description */
22 char *value; /* value */
23 } SMAP;
24
25 #define NDEV 10 /* number of devices */
26
27 SMAP dev[NDEV] = {
28 { "Tektronix 4014", "t4014" },
29 { "AED 512", "output aed5" },
30 { "X10 Window System", "xmeta" },
31 { "X11 Window System", "x11meta" },
32 { "Epson Printer", "output mx80" },
33 { "Mannesman-Tally Printer", "output mt160" },
34 { "Mannesman-Tally High Density", "output mt160l" },
35 { "Apple Imagewriter", "output imagew" },
36 { "Imagen Printer", "impress | ipr" },
37 { "Postscript Printer", "psmeta | lpr" },
38 };
39
40 #define NTYP 7 /* number of plot types */
41
42 SMAP typ[NTYP] = {
43 { "Cartesian Plot", "cartesian.plt" },
44 { "Polar Plot (degrees)", "polar.plt" },
45 { "Curve Plot (symbols & lines)", "curve.plt" },
46 { "Scatter Plot (symbols only)", "scatter.plt" },
47 { "Line Plot (lines only)", "line.plt" },
48 { "Function Plot (lines)", "function.plt" },
49 { "Box and Whisker Plot", "boxw.plt" },
50 };
51
52 #define NCAL 3 /* number of calculation types */
53
54 SMAP cal[NCAL] = {
55 { "Extrema, Average", "nma" },
56 { "Integral", "ni" },
57 { "Linear Regression", "nl" },
58 };
59
60 char *progname;
61
62 char *libpath[4];
63
64 static int recover = 0; /* try to recover? */
65
66 static jmp_buf env; /* setjmp buffer */
67
68 static char curfile[64] = "temp.plt"; /* current file name */
69
70 char *getfile(), *gets(), *strcpy();
71
72
73 main(argc, argv)
74 int argc;
75 char *argv[];
76 {
77 char *getenv();
78 int i;
79
80 progname = argv[0];
81 libpath[0] = "./";
82 if ((libpath[i=1] = getenv("MDIR")) != NULL)
83 i++;
84 libpath[i++] = MDIR;
85 libpath[i] = NULL;
86
87 for (i = 1; i < argc; i++)
88 mgload(strcpy(curfile, argv[i]));
89
90 mainmenu();
91
92 quit(0);
93 }
94
95
96 eputs(msg) /* print error message */
97 char *msg;
98 {
99 fputs(msg, stderr);
100 }
101
102
103 quit(code) /* recover or quit */
104 int code;
105 {
106 if (code && recover--)
107 longjmp(env, 1);
108 exit(code);
109 }
110
111
112 mainmenu() /* the main menu loop */
113 {
114 char sbuf[128];
115
116 for ( ; ; ) {
117 printf("\nGRAPH MENU\n");
118 printf("\t1 New Plot\n");
119 printf("\t2 Set Plot Type\n");
120 printf("\t3 Load Plot File\n");
121 printf("\t4 Save Plot File\n");
122 printf("\t5 Change Plot Variable\n");
123 printf("\t6 Change Curve Variable\n");
124 printf("\t7 Output Plot\n");
125 printf("\t8 Escape Command\n");
126 printf("\t9 Computation\n");
127 printf("\t10 Quit\n");
128
129 printf("\nChoice: ");
130 clearerr(stdin); gets(sbuf);
131 if (feof(stdin))
132 return;
133 switch (atoi(sbuf)) {
134 case 1: /* new plot */
135 mgclearall();
136 break;
137 case 2: /* set plot type */
138 settype();
139 break;
140 case 3: /* load plot file */
141 if (setjmp(env) == 0) {
142 recover = 1;
143 mgload(getfile());
144 recover = 0;
145 } else
146 uwait();
147 break;
148 case 4: /* save plot file */
149 if (setjmp(env) == 0) {
150 recover = 1;
151 mgsave(getfile());
152 recover = 0;
153 } else
154 uwait();
155 break;
156 case 5: /* set plot variable */
157 setvars(NVARS, gparam);
158 break;
159 case 6: /* set curve variable */
160 printf("\nCurve (A-%c): ", MAXCUR-1+'A');
161 clearerr(stdin); gets(sbuf);
162 if (islower(sbuf[0]))
163 sbuf[0] -= 'a';
164 else if (isupper(sbuf[0]))
165 sbuf[0] -= 'A';
166 else
167 break;
168 if (sbuf[0] < MAXCUR)
169 setvars(NCVARS, cparam[sbuf[0]]);
170 break;
171 case 7: /* output plot */
172 plotout();
173 break;
174 case 8: /* escape command */
175 printf("\nCommand: ");
176 clearerr(stdin); gets(sbuf);
177 if (sbuf[0]) {
178 system(sbuf);
179 uwait();
180 }
181 break;
182 case 9: /* computation */
183 gcompute();
184 break;
185 case 10: /* quit */
186 return;
187 }
188 }
189 }
190
191
192 char *
193 getfile() /* get file name from user */
194 {
195 char sbuf[128];
196
197 printf("\nFile (%s): ", curfile);
198 clearerr(stdin); gets(sbuf);
199 if (sbuf[0] == '-')
200 return(NULL);
201 if (sbuf[0])
202 strcpy(curfile, sbuf);
203 return(curfile);
204 }
205
206
207 settype() /* set plot type */
208 {
209 char sbuf[128];
210 int i;
211
212 printf("\nPLOT TYPE\n");
213
214 for (i = 0; i < NTYP; i++)
215 printf("\t%d %s\n", i+1, typ[i].descrip);
216
217 printf("\nChoice (0): ");
218 clearerr(stdin); gets(sbuf);
219 i = atoi(sbuf) - 1;
220 if (i < 0 || i >= NTYP)
221 return;
222 sprintf(sbuf, "include=%s", typ[i].value);
223 setmgvar("plot type", stdin, sbuf);
224 }
225
226
227 plotout() /* output our graph */
228 {
229 extern FILE *pout, *popen();
230 char sbuf[128];
231 char *command;
232 int i;
233
234 printf("\nOUTPUT PLOT\n");
235
236 for (i = 0; i < NDEV; i++)
237 printf("\t%d %s\n", i+1, dev[i].descrip);
238 printf("\t%d Dumb Terminal\n", NDEV+1);
239 printf("\t%d Other\n", NDEV+2);
240
241 printf("\nChoice (0): ");
242 clearerr(stdin); gets(sbuf);
243 i = atoi(sbuf) - 1;
244 if (i < 0 || i > NDEV+1)
245 return;
246 if (i < NDEV)
247 command = dev[i].value;
248 else if (i == NDEV) {
249 if (setjmp(env) == 0) {
250 recover = 1;
251 cgraph(79, 22);
252 recover = 0;
253 }
254 uwait();
255 return;
256 } else if (i == NDEV+1) {
257 printf("\nDriver command: ");
258 clearerr(stdin); gets(sbuf);
259 if (!sbuf[0])
260 return;
261 command = sbuf;
262 }
263 if ((pout = popen(command, "w")) == NULL) {
264 fprintf(stderr, "%s: cannot execute device driver: %s\n",
265 progname, dev[i].value);
266 quit(1);
267 }
268 if (setjmp(env) == 0) {
269 recover = 1;
270 mgraph();
271 recover = 0;
272 } else
273 uwait();
274 mdone();
275 pclose(pout);
276 }
277
278
279 setvars(nvar, vars) /* set variables */
280 int nvar;
281 VARIABLE vars[];
282 {
283 char sbuf[128];
284 int i, j;
285
286 for ( ; ; ) {
287 printf("\nVARIABLES\n");
288
289 for (i = 0; i < nvar; i++)
290 printf("\t%d %s\n", i+1, vars[i].descrip == NULL ?
291 vars[i].name : vars[i].descrip);
292
293 printf("\nChoice (0): ");
294 clearerr(stdin); gets(sbuf);
295 i = atoi(sbuf) - 1;
296 if (i < 0 || i >= nvar)
297 return;
298 printf("\n%s", vars[i].name);
299 if (vars[i].type == FUNCTION)
300 printf("(x)");
301 if (vars[i].flags & DEFINED) {
302 mgtoa(sbuf, &vars[i]);
303 printf(" (%s)", sbuf);
304 }
305 printf(": ");
306 if (vars[i].type == FUNCTION)
307 sprintf(sbuf, "%s(x)=", vars[i].name);
308 else
309 sprintf(sbuf, "%s=", vars[i].name);
310 j = strlen(sbuf);
311 clearerr(stdin); gets(sbuf+j);
312 if (sbuf[j]) {
313 if (vars[i].type == DATA && sbuf[j] == '-')
314 sbuf[j] = '\0';
315
316 if (setjmp(env) == 0) {
317 recover = 1;
318 setmgvar("variable set", stdin, sbuf);
319 recover = 0;
320 } else
321 uwait();
322 }
323 }
324 }
325
326
327 gcompute() /* do a computation */
328 {
329 char sbuf[64];
330 int i;
331
332 printf("\nCOMPUTE\n");
333
334 for (i = 0; i < NCAL; i++)
335 printf("\t%d %s\n", i+1, cal[i].descrip);
336
337 printf("\nChoice (0): ");
338 clearerr(stdin); gets(sbuf);
339 i = atoi(sbuf) - 1;
340 if (i < 0 || i >= NCAL)
341 return;
342 printf("\n");
343 if (setjmp(env) == 0) {
344 recover = 1;
345 gcalc(cal[i].value);
346 recover = 0;
347 }
348 printf("\n");
349 uwait();
350 }
351
352
353 uwait() /* wait for user after command, error */
354 {
355 printf("Hit return to continue: ");
356 while (getchar() != '\n')
357 ;
358 }
