1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: igraph.c,v 1.2 2003/10/27 10:28:59 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* igraph.c - interactive graphing program. |
6 |
7 |
* 6/30/86 |
8 |
9 |
* Greg Ward Larson |
10 |
11 |
12 |
#include <stdio.h> |
13 |
#include <ctype.h> |
14 |
#include <setjmp.h> |
15 |
16 |
#include "rtprocess.h" |
17 |
#include "rterror.h" |
18 |
#include "mgvars.h" |
19 |
20 |
typedef struct { |
21 |
char *descrip; /* description */ |
22 |
char *value; /* value */ |
23 |
} SMAP; |
24 |
25 |
#define NDEV 10 /* number of devices */ |
26 |
27 |
SMAP dev[NDEV] = { |
28 |
{ "Tektronix 4014", "t4014" }, |
29 |
{ "AED 512", "output aed5" }, |
30 |
{ "X10 Window System", "xmeta" }, |
31 |
{ "X11 Window System", "x11meta" }, |
32 |
{ "Epson Printer", "output mx80" }, |
33 |
{ "Mannesman-Tally Printer", "output mt160" }, |
34 |
{ "Mannesman-Tally High Density", "output mt160l" }, |
35 |
{ "Apple Imagewriter", "output imagew" }, |
36 |
{ "Imagen Printer", "impress | ipr" }, |
37 |
{ "Postscript Printer", "psmeta | lpr" }, |
38 |
39 |
40 |
#define NTYP 7 /* number of plot types */ |
41 |
42 |
SMAP typ[NTYP] = { |
43 |
{ "Cartesian Plot", "cartesian.plt" }, |
44 |
{ "Polar Plot (degrees)", "polar.plt" }, |
45 |
{ "Curve Plot (symbols & lines)", "curve.plt" }, |
46 |
{ "Scatter Plot (symbols only)", "scatter.plt" }, |
47 |
{ "Line Plot (lines only)", "line.plt" }, |
48 |
{ "Function Plot (lines)", "function.plt" }, |
49 |
{ "Box and Whisker Plot", "boxw.plt" }, |
50 |
51 |
52 |
#define NCAL 3 /* number of calculation types */ |
53 |
54 |
SMAP cal[NCAL] = { |
55 |
{ "Extrema, Average", "nma" }, |
56 |
{ "Integral", "ni" }, |
57 |
{ "Linear Regression", "nl" }, |
58 |
59 |
60 |
char *progname; |
61 |
62 |
char *libpath[4]; |
63 |
64 |
static int recover = 0; /* try to recover? */ |
65 |
66 |
static jmp_buf env; /* setjmp buffer */ |
67 |
68 |
static char curfile[64] = "temp.plt"; /* current file name */ |
69 |
70 |
static void mainmenu(void); |
71 |
static void uwait(void); |
72 |
static void gcompute(void); |
73 |
static void setvars(int nvar, VARIABLE vars[]); |
74 |
static void plotout(void); |
75 |
static void settype(void); |
76 |
static char *getfile(void); |
77 |
78 |
int |
79 |
main(argc, argv) |
80 |
int argc; |
81 |
char *argv[]; |
82 |
83 |
char *getenv(); |
84 |
int i; |
85 |
86 |
progname = argv[0]; |
87 |
libpath[0] = "./"; |
88 |
if ((libpath[i=1] = getenv("MDIR")) != NULL) |
89 |
i++; |
90 |
libpath[i++] = MDIR; |
91 |
libpath[i] = NULL; |
92 |
93 |
for (i = 1; i < argc; i++) |
94 |
mgload(strcpy(curfile, argv[i])); |
95 |
96 |
mainmenu(); |
97 |
98 |
quit(0); |
99 |
100 |
101 |
extern void |
102 |
eputs(msg) /* print error message */ |
103 |
char *msg; |
104 |
105 |
fputs(msg, stderr); |
106 |
107 |
108 |
extern void |
109 |
quit(code) /* recover or quit */ |
110 |
int code; |
111 |
112 |
if (code && recover--) |
113 |
longjmp(env, 1); |
114 |
exit(code); |
115 |
116 |
117 |
118 |
static void |
119 |
mainmenu(void) /* the main menu loop */ |
120 |
121 |
char sbuf[128]; |
122 |
123 |
for ( ; ; ) { |
124 |
printf("\nGRAPH MENU\n"); |
125 |
printf("\t1 New Plot\n"); |
126 |
printf("\t2 Set Plot Type\n"); |
127 |
printf("\t3 Load Plot File\n"); |
128 |
printf("\t4 Save Plot File\n"); |
129 |
printf("\t5 Change Plot Variable\n"); |
130 |
printf("\t6 Change Curve Variable\n"); |
131 |
printf("\t7 Output Plot\n"); |
132 |
printf("\t8 Escape Command\n"); |
133 |
printf("\t9 Computation\n"); |
134 |
printf("\t10 Quit\n"); |
135 |
136 |
printf("\nChoice: "); |
137 |
clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); |
138 |
if (feof(stdin)) |
139 |
return; |
140 |
switch (atoi(sbuf)) { |
141 |
case 1: /* new plot */ |
142 |
mgclearall(); |
143 |
break; |
144 |
case 2: /* set plot type */ |
145 |
settype(); |
146 |
break; |
147 |
case 3: /* load plot file */ |
148 |
if (setjmp(env) == 0) { |
149 |
recover = 1; |
150 |
mgload(getfile()); |
151 |
recover = 0; |
152 |
} else |
153 |
uwait(); |
154 |
break; |
155 |
case 4: /* save plot file */ |
156 |
157 |
recover = 1; |
158 |
mgsave(getfile()); |
159 |
recover = 0; |
160 |
} else |
161 |
uwait(); |
162 |
break; |
163 |
case 5: /* set plot variable */ |
164 |
setvars(NVARS, gparam); |
165 |
break; |
166 |
case 6: /* set curve variable */ |
167 |
printf("\nCurve (A-%c): ", MAXCUR-1+'A'); |
168 |
169 |
if (islower(sbuf[0])) |
170 |
sbuf[0] -= 'a'; |
171 |
else if (isupper(sbuf[0])) |
172 |
sbuf[0] -= 'A'; |
173 |
else |
174 |
break; |
175 |
if (sbuf[0] < MAXCUR) |
176 |
setvars(NCVARS, cparam[sbuf[0]]); |
177 |
break; |
178 |
case 7: /* output plot */ |
179 |
plotout(); |
180 |
break; |
181 |
case 8: /* escape command */ |
182 |
printf("\nCommand: "); |
183 |
184 |
if (sbuf[0]) { |
185 |
system(sbuf); |
186 |
uwait(); |
187 |
188 |
break; |
189 |
case 9: /* computation */ |
190 |
gcompute(); |
191 |
break; |
192 |
case 10: /* quit */ |
193 |
return; |
194 |
195 |
196 |
197 |
198 |
199 |
static char * |
200 |
getfile(void) /* get file name from user */ |
201 |
202 |
char sbuf[128]; |
203 |
204 |
printf("\nFile (%s): ", curfile); |
205 |
206 |
if (sbuf[0] == '-') |
207 |
return(NULL); |
208 |
if (sbuf[0]) |
209 |
strcpy(curfile, sbuf); |
210 |
return(curfile); |
211 |
212 |
213 |
static void |
214 |
settype(void) /* set plot type */ |
215 |
216 |
char sbuf[128]; |
217 |
int i; |
218 |
219 |
printf("\nPLOT TYPE\n"); |
220 |
221 |
for (i = 0; i < NTYP; i++) |
222 |
printf("\t%d %s\n", i+1, typ[i].descrip); |
223 |
224 |
printf("\nChoice (0): "); |
225 |
226 |
i = atoi(sbuf) - 1; |
227 |
if (i < 0 || i >= NTYP) |
228 |
return; |
229 |
sprintf(sbuf, "include=%s", typ[i].value); |
230 |
setmgvar("plot type", stdin, sbuf); |
231 |
232 |
233 |
234 |
static void |
235 |
plotout(void) /* output our graph */ |
236 |
237 |
extern FILE *pout; |
238 |
char sbuf[128]; |
239 |
char *command; |
240 |
int i; |
241 |
242 |
printf("\nOUTPUT PLOT\n"); |
243 |
244 |
for (i = 0; i < NDEV; i++) |
245 |
printf("\t%d %s\n", i+1, dev[i].descrip); |
246 |
printf("\t%d Dumb Terminal\n", NDEV+1); |
247 |
printf("\t%d Other\n", NDEV+2); |
248 |
249 |
250 |
251 |
252 |
if (i < 0 || i > NDEV+1) |
253 |
return; |
254 |
if (i < NDEV) |
255 |
command = dev[i].value; |
256 |
else if (i == NDEV) { |
257 |
258 |
recover = 1; |
259 |
cgraph(79, 22); |
260 |
recover = 0; |
261 |
262 |
uwait(); |
263 |
return; |
264 |
} else if (i == NDEV+1) { |
265 |
printf("\nDriver command: "); |
266 |
267 |
if (!sbuf[0]) |
268 |
return; |
269 |
command = sbuf; |
270 |
271 |
if ((pout = popen(command, "w")) == NULL) { |
272 |
fprintf(stderr, "%s: cannot execute device driver: %s\n", |
273 |
progname, dev[i].value); |
274 |
quit(1); |
275 |
276 |
277 |
recover = 1; |
278 |
mgraph(); |
279 |
recover = 0; |
280 |
} else |
281 |
uwait(); |
282 |
mdone(); |
283 |
pclose(pout); |
284 |
285 |
286 |
287 |
static void |
288 |
setvars( /* set variables */ |
289 |
int nvar, |
290 |
VARIABLE vars[]) |
291 |
292 |
char sbuf[128]; |
293 |
int i, j; |
294 |
295 |
for ( ; ; ) { |
296 |
printf("\nVARIABLES\n"); |
297 |
298 |
for (i = 0; i < nvar; i++) |
299 |
printf("\t%d %s\n", i+1, vars[i].descrip == NULL ? |
300 |
vars[i].name : vars[i].descrip); |
301 |
302 |
303 |
304 |
305 |
if (i < 0 || i >= nvar) |
306 |
return; |
307 |
printf("\n%s", vars[i].name); |
308 |
if (vars[i].type == FUNCTION) |
309 |
printf("(x)"); |
310 |
if (vars[i].flags & DEFINED) { |
311 |
mgtoa(sbuf, &vars[i]); |
312 |
printf(" (%s)", sbuf); |
313 |
314 |
printf(": "); |
315 |
316 |
sprintf(sbuf, "%s(x)=", vars[i].name); |
317 |
else |
318 |
sprintf(sbuf, "%s=", vars[i].name); |
319 |
j = strlen(sbuf); |
320 |
clearerr(stdin); fgets(sbuf+j, sizeof(sbuf)-j, stdin); |
321 |
if (sbuf[j]) { |
322 |
if (vars[i].type == DATA && sbuf[j] == '-') |
323 |
sbuf[j] = '\0'; |
324 |
325 |
326 |
recover = 1; |
327 |
setmgvar("variable set", stdin, sbuf); |
328 |
recover = 0; |
329 |
} else |
330 |
uwait(); |
331 |
332 |
333 |
334 |
335 |
336 |
static void |
337 |
gcompute(void) /* do a computation */ |
338 |
339 |
char sbuf[64]; |
340 |
int i; |
341 |
342 |
printf("\nCOMPUTE\n"); |
343 |
344 |
for (i = 0; i < NCAL; i++) |
345 |
printf("\t%d %s\n", i+1, cal[i].descrip); |
346 |
347 |
348 |
349 |
350 |
if (i < 0 || i >= NCAL) |
351 |
return; |
352 |
printf("\n"); |
353 |
354 |
recover = 1; |
355 |
gcalc(cal[i].value); |
356 |
recover = 0; |
357 |
358 |
printf("\n"); |
359 |
uwait(); |
360 |
361 |
362 |
363 |
static void |
364 |
uwait(void) /* wait for user after command, error */ |
365 |
366 |
printf("Hit return to continue: "); |
367 |
while (getchar() != '\n') |
368 |
369 |
