--- ray/src/meta/igraph.c 2003/02/22 02:07:26 1.1 +++ ray/src/meta/igraph.c 2023/02/09 21:54:11 1.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: igraph.c,v 1.1 2003/02/22 02:07:26 greg Exp $"; +static const char RCSid[] = "$Id: igraph.c,v 1.5 2023/02/09 21:54:11 greg Exp $"; #endif /* * igraph.c - interactive graphing program. @@ -10,11 +10,13 @@ static const char RCSid[] = "$Id: igraph.c,v 1.1 2003/ */ #include - #include - #include +#include "rtprocess.h" +#include "rterror.h" +#include "meta.h" +#include "mgraph.h" #include "mgvars.h" typedef struct { @@ -67,9 +69,15 @@ static jmp_buf env; /* setjmp buffer */ static char curfile[64] = "temp.plt"; /* current file name */ -char *getfile(), *gets(), *strcpy(); +static void mainmenu(void); +static void uwait(void); +static void gcompute(void); +static void setvars(int nvar, VARIABLE vars[]); +static void plotout(void); +static void settype(void); +static char *getfile(void); - +int main(argc, argv) int argc; char *argv[]; @@ -90,18 +98,17 @@ char *argv[]; mainmenu(); quit(0); + return 0; /* pro forma return */ } - -eputs(msg) /* print error message */ -char *msg; +void +eputs(const char *msg) /* print error message */ { fputs(msg, stderr); } - -quit(code) /* recover or quit */ -int code; +void +quit(int code) /* recover or quit */ { if (code && recover--) longjmp(env, 1); @@ -109,7 +116,8 @@ int code; } -mainmenu() /* the main menu loop */ +static void +mainmenu(void) /* the main menu loop */ { char sbuf[128]; @@ -127,7 +135,7 @@ mainmenu() /* the main menu loop */ printf("\t10 Quit\n"); printf("\nChoice: "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); if (feof(stdin)) return; switch (atoi(sbuf)) { @@ -158,7 +166,7 @@ mainmenu() /* the main menu loop */ break; case 6: /* set curve variable */ printf("\nCurve (A-%c): ", MAXCUR-1+'A'); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); if (islower(sbuf[0])) sbuf[0] -= 'a'; else if (isupper(sbuf[0])) @@ -166,14 +174,14 @@ mainmenu() /* the main menu loop */ else break; if (sbuf[0] < MAXCUR) - setvars(NCVARS, cparam[sbuf[0]]); + setvars(NCVARS, cparam[(int)sbuf[0]]); break; case 7: /* output plot */ plotout(); break; case 8: /* escape command */ printf("\nCommand: "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); if (sbuf[0]) { system(sbuf); uwait(); @@ -189,13 +197,13 @@ mainmenu() /* the main menu loop */ } -char * -getfile() /* get file name from user */ +static char * +getfile(void) /* get file name from user */ { char sbuf[128]; printf("\nFile (%s): ", curfile); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); if (sbuf[0] == '-') return(NULL); if (sbuf[0]) @@ -203,8 +211,8 @@ getfile() /* get file name from user */ return(curfile); } - -settype() /* set plot type */ +static void +settype(void) /* set plot type */ { char sbuf[128]; int i; @@ -215,7 +223,7 @@ settype() /* set plot type */ printf("\t%d %s\n", i+1, typ[i].descrip); printf("\nChoice (0): "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); i = atoi(sbuf) - 1; if (i < 0 || i >= NTYP) return; @@ -224,11 +232,12 @@ settype() /* set plot type */ } -plotout() /* output our graph */ +static void +plotout(void) /* output our graph */ { - extern FILE *pout, *popen(); + extern FILE *pout; char sbuf[128]; - char *command; + char *command = NULL; int i; printf("\nOUTPUT PLOT\n"); @@ -239,7 +248,7 @@ plotout() /* output our graph */ printf("\t%d Other\n", NDEV+2); printf("\nChoice (0): "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); i = atoi(sbuf) - 1; if (i < 0 || i > NDEV+1) return; @@ -255,7 +264,7 @@ plotout() /* output our graph */ return; } else if (i == NDEV+1) { printf("\nDriver command: "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); if (!sbuf[0]) return; command = sbuf; @@ -276,9 +285,10 @@ plotout() /* output our graph */ } -setvars(nvar, vars) /* set variables */ -int nvar; -VARIABLE vars[]; +static void +setvars( /* set variables */ +int nvar, +VARIABLE vars[]) { char sbuf[128]; int i, j; @@ -291,7 +301,7 @@ VARIABLE vars[]; vars[i].name : vars[i].descrip); printf("\nChoice (0): "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); i = atoi(sbuf) - 1; if (i < 0 || i >= nvar) return; @@ -308,7 +318,7 @@ VARIABLE vars[]; else sprintf(sbuf, "%s=", vars[i].name); j = strlen(sbuf); - clearerr(stdin); gets(sbuf+j); + clearerr(stdin); fgets(sbuf+j, sizeof(sbuf)-j, stdin); if (sbuf[j]) { if (vars[i].type == DATA && sbuf[j] == '-') sbuf[j] = '\0'; @@ -324,7 +334,8 @@ VARIABLE vars[]; } -gcompute() /* do a computation */ +static void +gcompute(void) /* do a computation */ { char sbuf[64]; int i; @@ -335,7 +346,7 @@ gcompute() /* do a computation */ printf("\t%d %s\n", i+1, cal[i].descrip); printf("\nChoice (0): "); - clearerr(stdin); gets(sbuf); + clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin); i = atoi(sbuf) - 1; if (i < 0 || i >= NCAL) return; @@ -350,7 +361,8 @@ gcompute() /* do a computation */ } -uwait() /* wait for user after command, error */ +static void +uwait(void) /* wait for user after command, error */ { printf("Hit return to continue: "); while (getchar() != '\n')
