root/radiance/ray/src/meta/igraph.c
Revision: 1.4
Committed: Sat Nov 15 02:13:37 2003 UTC (21 years, 7 months ago) by schorsch
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3
Changes since 1.3: +6 -3 lines
Continued ANSIfication, and reduced other compile warnings.
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 1.4 static const char RCSid[] = "$Id: igraph.c,v 1.3 2003/11/14 00:14:40 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * igraph.c - interactive graphing program.
6     *
7     * 6/30/86
8     *
9     * Greg Ward Larson
10     */
11
12     #include <stdio.h>
13     #include <ctype.h>
14     #include <setjmp.h>
15
16 schorsch 1.2 #include "rtprocess.h"
17 schorsch 1.3 #include "rterror.h"
18 schorsch 1.4 #include "meta.h"
19     #include "mgraph.h"
20 greg 1.1 #include "mgvars.h"
21
22     typedef struct {
23     char *descrip; /* description */
24     char *value; /* value */
25     } SMAP;
26
27     #define NDEV 10 /* number of devices */
28
29     SMAP dev[NDEV] = {
30     { "Tektronix 4014", "t4014" },
31     { "AED 512", "output aed5" },
32     { "X10 Window System", "xmeta" },
33     { "X11 Window System", "x11meta" },
34     { "Epson Printer", "output mx80" },
35     { "Mannesman-Tally Printer", "output mt160" },
36     { "Mannesman-Tally High Density", "output mt160l" },
37     { "Apple Imagewriter", "output imagew" },
38     { "Imagen Printer", "impress | ipr" },
39     { "Postscript Printer", "psmeta | lpr" },
40     };
41
42     #define NTYP 7 /* number of plot types */
43
44     SMAP typ[NTYP] = {
45     { "Cartesian Plot", "cartesian.plt" },
46     { "Polar Plot (degrees)", "polar.plt" },
47     { "Curve Plot (symbols & lines)", "curve.plt" },
48     { "Scatter Plot (symbols only)", "scatter.plt" },
49     { "Line Plot (lines only)", "line.plt" },
50     { "Function Plot (lines)", "function.plt" },
51     { "Box and Whisker Plot", "boxw.plt" },
52     };
53
54     #define NCAL 3 /* number of calculation types */
55
56     SMAP cal[NCAL] = {
57     { "Extrema, Average", "nma" },
58     { "Integral", "ni" },
59     { "Linear Regression", "nl" },
60     };
61
62     char *progname;
63
64     char *libpath[4];
65
66     static int recover = 0; /* try to recover? */
67
68     static jmp_buf env; /* setjmp buffer */
69
70     static char curfile[64] = "temp.plt"; /* current file name */
71
72 schorsch 1.3 static void mainmenu(void);
73     static void uwait(void);
74     static void gcompute(void);
75     static void setvars(int nvar, VARIABLE vars[]);
76     static void plotout(void);
77     static void settype(void);
78     static char *getfile(void);
79 greg 1.1
80 schorsch 1.3 int
81 greg 1.1 main(argc, argv)
82     int argc;
83     char *argv[];
84     {
85     char *getenv();
86     int i;
87
88     progname = argv[0];
89     libpath[0] = "./";
90     if ((libpath[i=1] = getenv("MDIR")) != NULL)
91     i++;
92     libpath[i++] = MDIR;
93     libpath[i] = NULL;
94
95     for (i = 1; i < argc; i++)
96     mgload(strcpy(curfile, argv[i]));
97
98     mainmenu();
99
100     quit(0);
101 schorsch 1.4 return 0; /* pro forma return */
102 greg 1.1 }
103
104 schorsch 1.3 extern void
105 greg 1.1 eputs(msg) /* print error message */
106     char *msg;
107     {
108     fputs(msg, stderr);
109     }
110
111 schorsch 1.3 extern void
112 greg 1.1 quit(code) /* recover or quit */
113     int code;
114     {
115     if (code && recover--)
116     longjmp(env, 1);
117     exit(code);
118     }
119
120
121 schorsch 1.3 static void
122     mainmenu(void) /* the main menu loop */
123 greg 1.1 {
124     char sbuf[128];
125
126     for ( ; ; ) {
127     printf("\nGRAPH MENU\n");
128     printf("\t1 New Plot\n");
129     printf("\t2 Set Plot Type\n");
130     printf("\t3 Load Plot File\n");
131     printf("\t4 Save Plot File\n");
132     printf("\t5 Change Plot Variable\n");
133     printf("\t6 Change Curve Variable\n");
134     printf("\t7 Output Plot\n");
135     printf("\t8 Escape Command\n");
136     printf("\t9 Computation\n");
137     printf("\t10 Quit\n");
138
139     printf("\nChoice: ");
140 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
141 greg 1.1 if (feof(stdin))
142     return;
143     switch (atoi(sbuf)) {
144     case 1: /* new plot */
145     mgclearall();
146     break;
147     case 2: /* set plot type */
148     settype();
149     break;
150     case 3: /* load plot file */
151     if (setjmp(env) == 0) {
152     recover = 1;
153     mgload(getfile());
154     recover = 0;
155     } else
156     uwait();
157     break;
158     case 4: /* save plot file */
159     if (setjmp(env) == 0) {
160     recover = 1;
161     mgsave(getfile());
162     recover = 0;
163     } else
164     uwait();
165     break;
166     case 5: /* set plot variable */
167     setvars(NVARS, gparam);
168     break;
169     case 6: /* set curve variable */
170     printf("\nCurve (A-%c): ", MAXCUR-1+'A');
171 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
172 greg 1.1 if (islower(sbuf[0]))
173     sbuf[0] -= 'a';
174     else if (isupper(sbuf[0]))
175     sbuf[0] -= 'A';
176     else
177     break;
178     if (sbuf[0] < MAXCUR)
179 schorsch 1.4 setvars(NCVARS, cparam[(int)sbuf[0]]);
180 greg 1.1 break;
181     case 7: /* output plot */
182     plotout();
183     break;
184     case 8: /* escape command */
185     printf("\nCommand: ");
186 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
187 greg 1.1 if (sbuf[0]) {
188     system(sbuf);
189     uwait();
190     }
191     break;
192     case 9: /* computation */
193     gcompute();
194     break;
195     case 10: /* quit */
196     return;
197     }
198     }
199     }
200
201
202 schorsch 1.3 static char *
203     getfile(void) /* get file name from user */
204 greg 1.1 {
205     char sbuf[128];
206
207     printf("\nFile (%s): ", curfile);
208 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
209 greg 1.1 if (sbuf[0] == '-')
210     return(NULL);
211     if (sbuf[0])
212     strcpy(curfile, sbuf);
213     return(curfile);
214     }
215
216 schorsch 1.3 static void
217     settype(void) /* set plot type */
218 greg 1.1 {
219     char sbuf[128];
220     int i;
221
222     printf("\nPLOT TYPE\n");
223
224     for (i = 0; i < NTYP; i++)
225     printf("\t%d %s\n", i+1, typ[i].descrip);
226
227     printf("\nChoice (0): ");
228 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
229 greg 1.1 i = atoi(sbuf) - 1;
230     if (i < 0 || i >= NTYP)
231     return;
232     sprintf(sbuf, "include=%s", typ[i].value);
233     setmgvar("plot type", stdin, sbuf);
234     }
235
236
237 schorsch 1.3 static void
238     plotout(void) /* output our graph */
239 greg 1.1 {
240 schorsch 1.2 extern FILE *pout;
241 greg 1.1 char sbuf[128];
242 schorsch 1.4 char *command = NULL;
243 greg 1.1 int i;
244
245     printf("\nOUTPUT PLOT\n");
246
247     for (i = 0; i < NDEV; i++)
248     printf("\t%d %s\n", i+1, dev[i].descrip);
249     printf("\t%d Dumb Terminal\n", NDEV+1);
250     printf("\t%d Other\n", NDEV+2);
251
252     printf("\nChoice (0): ");
253 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
254 greg 1.1 i = atoi(sbuf) - 1;
255     if (i < 0 || i > NDEV+1)
256     return;
257     if (i < NDEV)
258     command = dev[i].value;
259     else if (i == NDEV) {
260     if (setjmp(env) == 0) {
261     recover = 1;
262     cgraph(79, 22);
263     recover = 0;
264     }
265     uwait();
266     return;
267     } else if (i == NDEV+1) {
268     printf("\nDriver command: ");
269 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
270 greg 1.1 if (!sbuf[0])
271     return;
272     command = sbuf;
273     }
274     if ((pout = popen(command, "w")) == NULL) {
275     fprintf(stderr, "%s: cannot execute device driver: %s\n",
276     progname, dev[i].value);
277     quit(1);
278     }
279     if (setjmp(env) == 0) {
280     recover = 1;
281     mgraph();
282     recover = 0;
283     } else
284     uwait();
285     mdone();
286     pclose(pout);
287     }
288
289
290 schorsch 1.3 static void
291     setvars( /* set variables */
292     int nvar,
293     VARIABLE vars[])
294 greg 1.1 {
295     char sbuf[128];
296     int i, j;
297
298     for ( ; ; ) {
299     printf("\nVARIABLES\n");
300
301     for (i = 0; i < nvar; i++)
302     printf("\t%d %s\n", i+1, vars[i].descrip == NULL ?
303     vars[i].name : vars[i].descrip);
304
305     printf("\nChoice (0): ");
306 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
307 greg 1.1 i = atoi(sbuf) - 1;
308     if (i < 0 || i >= nvar)
309     return;
310     printf("\n%s", vars[i].name);
311     if (vars[i].type == FUNCTION)
312     printf("(x)");
313     if (vars[i].flags & DEFINED) {
314     mgtoa(sbuf, &vars[i]);
315     printf(" (%s)", sbuf);
316     }
317     printf(": ");
318     if (vars[i].type == FUNCTION)
319     sprintf(sbuf, "%s(x)=", vars[i].name);
320     else
321     sprintf(sbuf, "%s=", vars[i].name);
322     j = strlen(sbuf);
323 schorsch 1.3 clearerr(stdin); fgets(sbuf+j, sizeof(sbuf)-j, stdin);
324 greg 1.1 if (sbuf[j]) {
325     if (vars[i].type == DATA && sbuf[j] == '-')
326     sbuf[j] = '\0';
327
328     if (setjmp(env) == 0) {
329     recover = 1;
330     setmgvar("variable set", stdin, sbuf);
331     recover = 0;
332     } else
333     uwait();
334     }
335     }
336     }
337
338
339 schorsch 1.3 static void
340     gcompute(void) /* do a computation */
341 greg 1.1 {
342     char sbuf[64];
343     int i;
344
345     printf("\nCOMPUTE\n");
346
347     for (i = 0; i < NCAL; i++)
348     printf("\t%d %s\n", i+1, cal[i].descrip);
349
350     printf("\nChoice (0): ");
351 schorsch 1.3 clearerr(stdin); fgets(sbuf, sizeof(sbuf), stdin);
352 greg 1.1 i = atoi(sbuf) - 1;
353     if (i < 0 || i >= NCAL)
354     return;
355     printf("\n");
356     if (setjmp(env) == 0) {
357     recover = 1;
358     gcalc(cal[i].value);
359     recover = 0;
360     }
361     printf("\n");
362     uwait();
363     }
364
365
366 schorsch 1.3 static void
367     uwait(void) /* wait for user after command, error */
368 greg 1.1 {
369     printf("Hit return to continue: ");
370     while (getchar() != '\n')
371     ;
372     }
