root/radiance/ray/src/meta/gcalc.c
Revision: 1.5
Committed: Fri Jan 12 00:58:45 2018 UTC (6 years, 4 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
Error occurred while calculating annotation data.
Changed linear fit formatting to permit smaller value reporting
2 static const char RCSid[] = "$Id: gcalc.c,v 1.4 2011/12/01 18:47:35 greg Exp $";
5 * gcalc.c - routines to do calculations on graph files.
6 *
7 * 7/7/86
8 * Greg Ward Larson
9 */
10
11 #include <stdio.h>
12 #include <string.h>
13
14 #include "mgvars.h"
15
16
17 static double xsum, xxsum, ysum, yysum, xysum;
18 static double xmin, xmax, ymin, ymax;
19 static double lastx, lasty, rsum;
20 static int npts;
21
22 static void gcheader(char *types);
23 static void calcpoint(int c, double x, double y);
24 static void gcvalue(int c, char *types);
25
26 void
27 gcalc( /* do a calculation */
28 char *types
29 )
30 {
31 int i;
32
33 if (strchr(types, 'h') == NULL)
34 gcheader(types);
35
36 xmin = gparam[XMIN].flags & DEFINED ?
37 varvalue(gparam[XMIN].name) :
38 -1e10;
39 xmax = gparam[XMAX].flags & DEFINED ?
40 varvalue(gparam[XMAX].name) :
41 1e10;
42
43 for (i = 0; i < MAXCUR; i++) {
44 xsum = xxsum = ysum = yysum = xysum = 0.0;
45 rsum = 0.0;
46 npts = 0;
47 mgcurve(i, calcpoint);
48 gcvalue(i, types);
49 }
50 }
51
52
53 void
54 gcheader( /* print header */
55 register char *types
56 )
57 {
58 printf("__");
59 while (*types)
60 switch (*types++) {
61 case 'n':
62 printf("|_Label___________");
63 break;
64 case 'a':
65 printf("|____Mean______S.D._");
66 break;
67 case 'm':
68 printf("|_____Min_______Max_");
69 break;
70 case 'i':
71 printf("|___Integ_");
72 break;
73 case 'l':
74 printf("|____Slope_______Intcp____Corr_");
75 break;
76 default:
77 break;
78 }
79 printf("\n");
80 }
81
82
83 void
84 gcvalue( /* print the values for the curve */
85 int c,
86 register char *types
87 )
88 {
89 double d1, d2, d3, sqrt();
90
91 if (npts < 1)
92 return;
93
94 printf("%c:", c+'A');
95 while (*types)
96 switch (*types++) {
97 case 'n':
98 printf(" %-16s", cparam[c][CLABEL].flags & DEFINED ?
99 cparam[c][CLABEL].v.s : "");
100 break;
101 case 'a':
102 d1 = sqrt((yysum - ysum*ysum/npts)/(npts-1));
103 printf(" %9.2f %9.3f", ysum/npts, d1);
104 break;
105 case 'm':
106 printf(" %9.2f %9.2f", ymin, ymax);
107 break;
108 case 'i':
109 printf(" %9.2f", rsum);
110 break;
111 case 'l':
112 d3 = xxsum - xsum*xsum/npts;
113 d1 = (xysum - xsum*ysum/npts)/d3;
114 d2 = (ysum - d1*xsum)/npts;
115 d3 = d1*sqrt(d3/(yysum - ysum*ysum/npts));
116 printf(" %11.4e %11.4e %6.3f", d1, d2, d3);
117 break;
118 default:
119 break;
120 }
121 printf("\n");
122 }
123
124
125 void
126 calcpoint( /* add a point to our calculation */
127 int c,
128 double x,
129 double y
130 )
131 {
132 if (x < xmin || x > xmax)
133 return;
134
135 xsum += x;
136 xxsum += x*x;
137 ysum += y;
138 yysum += y*y;
139 xysum += x*y;
140
141 if (npts) {
142 if (y < ymin)
143 ymin = y;
144 else if (y > ymax)
145 ymax = y;
146 } else
147 ymin = ymax = y;
148
149 if (npts)
150 rsum += ( y + lasty )*( x - lastx )/2.0;
151 lastx = x;
152 lasty = y;
153
154 npts++;
155 }
