1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: aed5.c,v 1.1 2003/02/22 02:07:26 greg Exp $"; |
3 |
#endif |
4 |
5 |
* aed.c - driver for AED 512 terminal. |
6 |
7 |
* 7/8/86 |
8 |
9 |
10 |
#include <fcntl.h> |
11 |
12 |
#include "meta.h" |
13 |
14 |
15 |
/* AED command characters */ |
16 |
17 |
#define AEDFMT "1888N" /* Format string to send to AED */ |
18 |
#define SCT 75 /* Set color lookup table */ |
19 |
#define SEC 67 /* Set color for vector drawing */ |
20 |
#define SBC 91 /* Set background color */ |
21 |
#define MOV 81 /* Set CAP (current access pointer) to x, y */ |
22 |
#define MVR 105 /* Set CAP relative */ |
23 |
#define DVA 65 /* Draw vector to new CAP x, y */ |
24 |
#define DVR 108 /* Draw vector relative */ |
25 |
#define WHR 92 /* Write horizontal runs */ |
26 |
#define OPT 40 /* Miscellaneous terminal control */ |
27 |
#define SEN 71 /* Set encoding types */ |
28 |
#define RST 48 /* Reset terminal */ |
29 |
#define FFD 12 /* Clear screen */ |
30 |
#define SCS 96 /* Set status */ |
31 |
#define DAI 114 /* Define area of interest */ |
32 |
#define EJC 85 /* Enable Joystick cursor positioning */ |
33 |
#define DJC 100 /* Disable Joystick cursor positioning */ |
34 |
#define SCC 99 /* Set Cursor Colors */ |
35 |
#define SCP 93 /* Set Cursor Parameters */ |
36 |
#define RCP 106 /* Read Cursor Position */ |
37 |
#define SAP 94 /* Set alphanumeric parameters */ |
38 |
#define SLS 49 /* Set Line Style */ |
39 |
#define DFR 111 /* Draw Filled Rectangle */ |
40 |
#define MAXRLEN 255 /* Maximum runlength for a span */ |
41 |
#define NUL 0 /* Null terminates run sequences */ |
42 |
#define ESC 27 /* Escape starts a command sequence */ |
43 |
#define END 1 /* Ctrl-A used to terminate command mode */ |
44 |
45 |
#define command(c) (putc(ESC, stdout), putc(c, stdout)) |
46 |
#define byte(b) putc(b, stdout) |
47 |
#define ascii(c) putc(c, stdout) |
48 |
49 |
#define BKGCOL 7 /* Background color (white) */ |
50 |
51 |
#define NROWS 512 /* # rows for output */ |
52 |
#define NCOLS 512 /* # columns for output */ |
53 |
54 |
#define xconv(x) CONV(x, NCOLS) |
55 |
#define yconv(y) CONV(y, NROWS) |
56 |
57 |
#define XCOM "pexpand +vOCIs -tpSUR %s" |
58 |
59 |
char *progname; |
60 |
61 |
static short newpage = TRUE; |
62 |
63 |
static int curx = -1, /* current position */ |
64 |
cury = -1; |
65 |
66 |
static int curcol = -1; /* current color */ |
67 |
68 |
static short curmod = -1; /* current line drawing mode */ |
69 |
70 |
static short cmode[4] = {0, 1, 2, 4}; /* color map */ |
71 |
72 |
static short lmode[4] = {255, 15, 85, 39}; /* line map */ |
73 |
74 |
static PRIMITIVE nextp; |
75 |
76 |
77 |
78 |
main(argc, argv) |
79 |
int argc; |
80 |
char **argv; |
81 |
82 |
FILE *fp, *popen(); |
83 |
char comargs[200], shcom[300]; |
84 |
short condonly = FALSE, conditioned = FALSE; |
85 |
86 |
progname = *argv++; |
87 |
argc--; |
88 |
89 |
while (argc && **argv == '-') { |
90 |
switch (*(*argv+1)) { |
91 |
case 'c': |
92 |
condonly = TRUE; |
93 |
break; |
94 |
case 'r': |
95 |
conditioned = TRUE; |
96 |
break; |
97 |
default: |
98 |
error(WARNING, "unknown option"); |
99 |
break; |
100 |
101 |
argv++; |
102 |
argc--; |
103 |
104 |
105 |
if (conditioned) { |
106 |
init(); |
107 |
if (argc) |
108 |
while (argc) { |
109 |
fp = efopen(*argv, "r"); |
110 |
plot(fp); |
111 |
fclose(fp); |
112 |
argv++; |
113 |
argc--; |
114 |
115 |
else |
116 |
plot(stdin); |
117 |
} else { |
118 |
comargs[0] = '\0'; |
119 |
while (argc) { |
120 |
strcat(comargs, " "); |
121 |
strcat(comargs, *argv); |
122 |
argv++; |
123 |
argc--; |
124 |
125 |
sprintf(shcom, XCOM, comargs); |
126 |
if (condonly) |
127 |
return(system(shcom)); |
128 |
else { |
129 |
init(); |
130 |
if ((fp = popen(shcom, "r")) == NULL) |
131 |
error(SYSTEM, "cannot execute input filter"); |
132 |
plot(fp); |
133 |
return(pclose(fp)); |
134 |
135 |
136 |
return(0); |
137 |
138 |
139 |
140 |
141 |
142 |
143 |
plot(infp) /* plot meta-file */ |
144 |
145 |
FILE *infp; |
146 |
147 |
148 |
149 |
do { |
150 |
readp(&nextp, infp); |
151 |
while (isprim(nextp.com)) { |
152 |
doprim(&nextp); |
153 |
fargs(&nextp); |
154 |
155 |
156 |
doglobal(&nextp); |
157 |
fargs(&nextp); |
158 |
159 |
while (nextp.com != PEOF); |
160 |
161 |
162 |
163 |
164 |
165 |
166 |
167 |
doglobal(g) /* execute a global command */ |
168 |
169 |
PRIMITIVE *g; |
170 |
171 |
172 |
int tty; |
173 |
char c; |
174 |
175 |
switch (g->com) { |
176 |
177 |
case PEOF: |
178 |
break; |
179 |
180 |
case PDRAW: |
181 |
fflush(stdout); |
182 |
break; |
183 |
184 |
case PEOP: |
185 |
newpage = TRUE; |
186 |
if (!isatty(fileno(stdout))) |
187 |
break; |
188 |
/* fall through */ |
189 |
190 |
case PPAUS: |
191 |
fflush(stdout); |
192 |
tty = open(TTY, O_RDWR); |
193 |
if (g->args != NULL) { |
194 |
write(tty, g->args, strlen(g->args)); |
195 |
write(tty, " - (hit return to continue)", 27); |
196 |
197 |
else |
198 |
write(tty, "\007", 1); |
199 |
do { |
200 |
c = '\n'; |
201 |
read(tty, &c, 1); |
202 |
203 |
while (c != '\n' && c != '\r'); |
204 |
close(tty); |
205 |
break; |
206 |
207 |
default: |
208 |
sprintf(errmsg, "unknown command '%c' in doglobal", g->com); |
209 |
error(WARNING, errmsg); |
210 |
break; |
211 |
212 |
213 |
214 |
215 |
216 |
217 |
218 |
doprim(p) /* plot primitive */ |
219 |
220 |
register PRIMITIVE *p; |
221 |
222 |
223 |
224 |
if (newpage) { /* clear screen */ |
225 |
command(FFD); |
226 |
shortwait(50); |
227 |
newpage = FALSE; |
228 |
229 |
230 |
switch (p->com) { |
231 |
232 |
case PLSEG: |
233 |
plotlseg(p); |
234 |
break; |
235 |
236 |
case PMSTR: |
237 |
printstr(p); |
238 |
break; |
239 |
240 |
case PRFILL: |
241 |
fillrect(p); |
242 |
break; |
243 |
244 |
default: |
245 |
sprintf(errmsg, "unknown command '%c' in doprim", p->com); |
246 |
247 |
return; |
248 |
249 |
250 |
251 |
252 |
253 |
254 |
255 |
256 |
257 |
printstr(p) /* output a string */ |
258 |
259 |
260 |
261 |
262 |
static int hsp[4] = {6, 5, 4, 3}; |
263 |
char font, size; |
264 |
int hspace, vspace = 18; |
265 |
266 |
hspace = hsp[(p->arg0 >> 4) & 03]; |
267 |
268 |
if (p->arg0 & 04) |
269 |
hspace *= 2; |
270 |
271 |
if (hspace > 16) { |
272 |
font = '7'; size = '2'; |
273 |
} else if (hspace > 12) { |
274 |
font = '5'; size = '2'; |
275 |
} else if (hspace > 8) { |
276 |
font = '7'; size = '1'; |
277 |
} else { |
278 |
font = '5'; size = '1'; |
279 |
280 |
281 |
command(SAP); |
282 |
ascii(size); ascii(font); |
283 |
byte(hspace); byte(vspace); |
284 |
ascii('L'); |
285 |
286 |
setcolor(p->arg0 & 03); |
287 |
288 |
move(p->xy[XMN], p->xy[YMX]); |
289 |
290 |
putc(END, stdout); |
291 |
fputs(p->args, stdout); |
292 |
293 |
curx = -1; |
294 |
cury = -1; |
295 |
296 |
297 |
298 |
299 |
300 |
301 |
plotlseg(p) /* plot a line segment */ |
302 |
303 |
304 |
305 |
306 |
static short right = FALSE; |
307 |
int y1, y2; |
308 |
short lm = (p->arg0 >> 4) & 03; |
309 |
310 |
if (p->arg0 & 0100) { |
311 |
y1 = p->xy[YMX]; |
312 |
y2 = p->xy[YMN]; |
313 |
314 |
else { |
315 |
y1 = p->xy[YMN]; |
316 |
y2 = p->xy[YMX]; |
317 |
318 |
319 |
320 |
321 |
if (lm != curmod) { |
322 |
command(SLS); |
323 |
byte(lmode[lm]); byte(85); |
324 |
curmod = lm; |
325 |
326 |
327 |
if (p->xy[XMN] == curx && y1 == cury) |
328 |
draw(p->xy[XMX], y2); |
329 |
else if (p->xy[XMX] == curx && y2 == cury) |
330 |
draw(p->xy[XMN], y1); |
331 |
else if (right = !right) { |
332 |
move(p->xy[XMN], y1); |
333 |
334 |
} else { |
335 |
move(p->xy[XMX], y2); |
336 |
337 |
338 |
339 |
340 |
341 |
fillrect(p) |
342 |
343 |
344 |
345 |
346 |
347 |
348 |
move(p->xy[XMN], p->xy[YMN]); |
349 |
curx = xconv(p->xy[XMX]); |
350 |
cury = yconv(p->xy[YMX]); |
351 |
command(DFR); |
352 |
aedcoord(curx, cury); |
353 |
354 |
355 |
356 |
init() /* initialize terminal */ |
357 |
358 |
/* Reset AED and tell it the data format */ |
359 |
command(RST); |
360 |
longwait(2); |
361 |
command(OPT); |
362 |
byte(6); byte(1); /* AED command set */ |
363 |
command(SEN); fputs(AEDFMT, stdout); |
364 |
command(SBC); byte(BKGCOL); |
365 |
366 |
367 |
368 |
setcolor(cn) /* set color */ |
369 |
int cn; |
370 |
371 |
if (cn != curcol) { |
372 |
command(SEC); |
373 |
byte(cmode[cn]); |
374 |
curcol = cn; |
375 |
376 |
377 |
378 |
379 |
move(x, y) /* move to coordinate (x,y) */ |
380 |
int x, y; |
381 |
382 |
command(MOV); |
383 |
aedcoord(xconv(x), yconv(y)); |
384 |
curx = x; |
385 |
cury = y; |
386 |
387 |
388 |
389 |
draw(x, y) /* draw vector from CAP to (x,y) */ |
390 |
int x, y; |
391 |
392 |
command(DVA); |
393 |
394 |
curx = x; |
395 |
cury = y; |
396 |
397 |
398 |
399 |
400 |
* aedcoord - puts out an (x, y) coordinate in AED 8 bit format. |
401 |
402 |
403 |
aedcoord(x, y) |
404 |
register int x, y; |
405 |
406 |
putc(((x >> 4) & 0x30) | ((y >> 8) & 0x3), stdout); |
407 |
putc(x & 0xff, stdout); |
408 |
putc(y & 0xff, stdout); |
409 |
410 |
411 |
412 |
longwait(t) /* longer wait */ |
413 |
int t; |
414 |
415 |
fflush(stdout); |
416 |
sleep(t); |
417 |
418 |
419 |
420 |
shortwait(t) /* shorter wait */ |
421 |
int t; |
422 |
423 |
register long l = t*1000; |
424 |
425 |
fflush(stdout); |
426 |
while (l--) |
427 |
428 |
