root/Development/ray/src/meta/SConscript
Revision: 1.1
Committed: Tue Oct 21 19:27:29 2003 UTC (22 years, 2 months ago) by schorsch
1 import os
2
3 Import ('env')
4
5 # make a modified local copy
6 meta = env.Copy(LIBS=['rt'] + env['RAD_MLIB'])
7
8 # compose paths
9 def radbin(name): return os.path.join(meta['RAD_BUILDBIN'], name)
10 def radlib(name): return os.path.join(meta['RAD_BUILDLIB'], name)
11
12 #meta.Append(CPPFLAGS = ' -DMDIR=\\"' + meta['RAD_RLIBDIR'] + '\\"')
13
14 # some files need an extra flag
15 MDIRFLAGS = meta.get('CPPFLAGS', []) + [
16 '-DMDIR=\\"%s\\"' % os.path.join(meta['RAD_RLIBDIR'], 'meta')]
17 bgraph = meta.Object(source='bgraph.c', CPPFLAGS=MDIRFLAGS)
18 igraph = meta.Object(source='igraph.c', CPPFLAGS=MDIRFLAGS)
19 dgraph = meta.Object(source='dgraph.c', CPPFLAGS=MDIRFLAGS)
20 gcomp = meta.Object(source='gcomp.c', CPPFLAGS=MDIRFLAGS)
21 syscalls = meta.Object(source='syscalls.c', CPPFLAGS=MDIRFLAGS)
22
23 common = Split('mfio.c misc.c') + [syscalls]
24
25 libmeta = meta.StaticLibrary(radlib('meta'),
26 Split ('metacalls.c primout.c progname.c') + common)
27
28 # standard targets
29 PROGS = (
30 ('meta2tga', Split('meta2tga.c rplot.c plot.c palloc.c') + common),
31 ('pexpand', Split('pexpand.c expand.c segment.c palloc.c') + common),
32 ('psort', Split('psort.c sort.c palloc.c') + common),
33 ('cv', Split('cv.c cvhfio.c') + common),
34 ('psmeta', Split('psmeta.c psplot.c') + common),
35 ('plotin', Split('plotin.c primout.c') + common),
36 ('bgraph', Split('mgvars.c mgraph.c') + [bgraph, libmeta]),
37 ('igraph', Split('mgvars.c mgraph.c gcalc.c cgraph.c') + [igraph, libmeta]),
38 ('dgraph', Split('cgraph.c mgvars.c') + [dgraph]),
39 ('gcomp', Split('gcalc.c mgvars.c') + [gcomp]),
40 ('plot4', Split('plot4.c primout.c') + common),
41 )
42 for p in PROGS:
43 prog = meta.Program(target=radbin(p[0]),
44 source=p[1])
45 Default(prog)
46 env.Append(RAD_BININSTALL=[meta.Install(meta['RAD_BINDIR'], prog)])
47
48
49 lib4014srcs = Split('''arc.c box.c circle.c close.c dot.c erase.c label.c
50 line.c linemod.c move.c open.c point.c space.c subr.c''')
51 lib4014 = env.Library(os.path.join(env['RAD_BUILDLIB'], '4014'),
52 source=map(lambda s:os.path.join('lib4014', s), lib4014srcs))
53
54 plotsrc = Split('mplot.c plot.c palloc.c')
55
56 SPECIAL = (
57 ('mt160l', Split('mt160l.c') + plotsrc + common), # rt
58 ('mt160', Split('mt160.c') + plotsrc + common), # rt m
59 ('mtext', Split('mtext.c primout.c') + common), # rt
60 ('okimate', Split('okimate.c') + plotsrc + common), # rt
61 ('mx80', Split('mx80.c') + plotsrc + common), # rt m
62 ('imagew', Split('imagew.c') + plotsrc + common), # rt m
63 ('impress', Split('impress.c implot.c imPfuncs.c plot.c') + common), # rt m
64 ('aed5', Split('aed5.c') + common), # rt m
65 ('tcurve', Split('tcurve.c tgraph.c primout.c') + common), # m
66 ('tscat', Split('tscat.c tgraph.c primout.c') + common), # rt m
67 ('tbar', Split('tbar.c tgraph.c primout.c') + common), # rt m
68 )
69 sbin = []
70 sinst = []
71 for p in SPECIAL:
72 prog = meta.Program(target=radbin(p[0]), source=p[1])
73 sbin.append(prog)
74 sinst.append(meta.Install(meta['RAD_BINDIR'], prog))
75 #plotout = meta.Program(target=radbin('plotout'), source=['plotout.c'] + common,
76 # LIBS=['plot', '4014', 'rt', 'm'])
77 #t4014 = meta.Program(target=radbin('t4014'), source=['plotout.c'] + common,
78 # LIBS=['4014', 'rt', 'm'], CPPFLAGS=meta.get('CPPFLAGS',[]) + ['-DFORTEK'])
79 meta.Alias('meta_special', sbin)# + [plotout, t4014])
80 meta.Alias('meta_special_install', sinst)
81
82 # X11 targets
83 if meta.has_key('X11LIB'):
84 meta.Append(CPPPATH=meta['X11INCLUDE'])
85 meta.Append(LIBS='X11')
86 meta.Append(LIBPATH=meta['X11LIB'])
87 x11meta = meta.Program(radbin('x11meta'),
88 Split('plotin.c primout.c') + common)
89 Default(x11meta)
90 env.Append(RAD_BININSTALL=[meta.Install(meta['RAD_BINDIR'], x11meta)])
91
92
