--- ray/src/meta/SConscript 2004/07/04 12:08:48 1.3 +++ ray/src/meta/SConscript 2005/09/19 12:48:09 1.5 @@ -19,18 +19,14 @@ mfio = env.Object(source='mfio.c') misc = env.Object(source='misc.c') primout = env.Object(source='primout.c') plot = env.Object(source='plot.c') +rplot = env.Object(source='rplot.c') palloc = env.Object(source='palloc.c') -mplot = env.Object(source='mplot.c') plotin = env.Object(source='plotin.c') -tgraph = env.Object(source='tgraph.c') mgvars = env.Object(source='mgvars.c') mgraph = env.Object(source='mgraph.c') cgraph = env.Object(source='cgraph.c') gcalc = env.Object(source='gcalc.c') # multiple output from same source -plotout = env.Object(source='plotout.c') -t4014 = env.Object(target="t4014", source='plotout.c', - CPPFLAGS=env.get('CPPFLAGS',[]) + ['-DFORTEK']) common = [mfio, misc, syscalls] @@ -39,7 +35,10 @@ libmeta = env.StaticLibrary(radlib('meta'), # standard targets PROGS = ( -('meta2tga', Split('meta2tga.c rplot.c') +[palloc, plot] + common, +('meta2bmp', Split('meta2bmp.c') +[rplot, palloc, plot] + common, + ['rtproc','rtpath','rtpic','rtio', # proc/path/rtio for win_popen() + 'rtcont','rtmem','rterror']), +('meta2tga', Split('meta2tga.c') +[rplot, palloc, plot] + common, ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen() 'rtcont','rtmem','rterror']), ('pexpand', Split('pexpand.c expand.c segment.c') +[palloc]+ common, @@ -75,50 +74,6 @@ for p in PROGS: env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)]) -lib4014srcs = Split('''arc.c box.c circle.c close.c dot.c erase.c label.c - line.c linemod.c move.c open.c point.c space.c subr.c''') -lib4014 = env.Library(os.path.join(env['RAD_BUILDLIB'], '4014'), - source=map(lambda s:os.path.join('lib4014', s), lib4014srcs)) - -plotsrc = [mplot, palloc, plot] - -SPECIAL = ( -('mt160l', Split('mt160l.c') + plotsrc + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('mt160', Split('mt160.c') + plotsrc + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('mtext', Split('mtext.c') +[primout]+ common, - ['rtcont','rtmem','rterror']), -('okimate', Split('okimate.c') + plotsrc + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('mx80', Split('mx80.c') + plotsrc + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('imagew', Split('imagew.c') + plotsrc + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('impress', Split('impress.c implot.c imPfuncs.c') +[plot]+ common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('aed5', Split('aed5.c') + common, - ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('tcurve', Split('tcurve.c') +[tgraph, primout]+ common, - ['rtcont','rtmem','rterror']), -('tscat', Split('tscat.c') +[tgraph, primout]+ common, - ['rtpath','rtcont','rtmem','rterror']), -('tbar', Split('tbar.c') +[tgraph, primout]+ common, - ['rtcont','rtmem','rterror']), -('plotout', [plotout] + common, - ['4014', 'rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -('t4014', [t4014] + common, - ['4014', 'rtproc','rtpath','rtio','rtcont','rtmem','rterror']), -) -sbin = [] -sinst = [] -for p in SPECIAL: - prog = env.Program(target=radbin(p[0]), source=p[1], - LIBS=p[2]+env['RAD_MLIB']) - sbin.append(prog) - sinst.append(env.Install(env['RAD_BINDIR'], prog)) -env.Alias('meta_special', sbin) -env.Alias('meta_special_install', sinst) # X11 targets if env.has_key('X11LIB'):
