| 1 |
import os
| 2 |
| 3 |
Import ('env')
| 4 |
| 5 |
# compose paths
| 6 |
def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
| 7 |
def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
| 8 |
| 9 |
# extra flag
| 10 |
MDIRFLAGS = env.get('CPPFLAGS', []) + [
| 11 |
'-DMDIR=\\"%s\\"' % os.path.join(env['RAD_RLIBDIR'], 'meta')]
| 12 |
bgraph = env.Object(source='bgraph.c', CPPFLAGS=MDIRFLAGS)
| 13 |
igraph = env.Object(source='igraph.c', CPPFLAGS=MDIRFLAGS)
| 14 |
dgraph = env.Object(source='dgraph.c', CPPFLAGS=MDIRFLAGS)
| 15 |
gcomp = env.Object(source='gcomp.c', CPPFLAGS=MDIRFLAGS)
| 16 |
syscalls = env.Object(source='syscalls.c', CPPFLAGS=MDIRFLAGS)
| 17 |
# used by several targets
| 18 |
mfio = env.Object(source='mfio.c')
| 19 |
misc = env.Object(source='misc.c')
| 20 |
primout = env.Object(source='primout.c')
| 21 |
plot = env.Object(source='plot.c')
| 22 |
palloc = env.Object(source='palloc.c')
| 23 |
plotin = env.Object(source='plotin.c')
| 24 |
mgvars = env.Object(source='mgvars.c')
| 25 |
mgraph = env.Object(source='mgraph.c')
| 26 |
cgraph = env.Object(source='cgraph.c')
| 27 |
gcalc = env.Object(source='gcalc.c')
| 28 |
# multiple output from same source
| 29 |
| 30 |
common = [mfio, misc, syscalls]
| 31 |
| 32 |
libmeta = env.StaticLibrary(radlib('meta'),
| 33 |
Split ('metacalls.c progname.c') +[primout] + common)
| 34 |
| 35 |
# standard targets
| 36 |
PROGS = (
| 37 |
('meta2tga', Split('meta2tga.c rplot.c') +[palloc, plot] + common,
| 38 |
['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
| 39 |
'rtcont','rtmem','rterror']),
| 40 |
('pexpand', Split('pexpand.c expand.c segment.c') +[palloc]+ common,
| 41 |
['rtcont','rtmem','rterror']),
| 42 |
('psort', Split('psort.c sort.c') +[palloc]+ common,
| 43 |
['rtpath','rtcont','rtmem','rterror']),
| 44 |
('cv', Split('cv.c cvhfio.c') + common,
| 45 |
| 46 |
('psmeta', Split('psmeta.c psplot.c') + common,
| 47 |
| 48 |
('plotin', [plotin, primout] + common,
| 49 |
| 50 |
('bgraph', [bgraph, mgraph, mgvars],
| 51 |
| 52 |
'rtfunc','rtcont','rtmem','meta','rterror']),
| 53 |
('igraph', [igraph, gcalc, cgraph, mgraph, mgvars],
| 54 |
| 55 |
| 56 |
('dgraph', [dgraph, cgraph, mgvars],
| 57 |
| 58 |
'rtfunc','rtcont','rtmem','rterror']),
| 59 |
('gcomp', [gcomp, gcalc, mgvars],
| 60 |
| 61 |
| 62 |
('plot4', Split('plot4.c') +[primout]+ common,
| 63 |
| 64 |
| 65 |
| 66 |
for p in PROGS:
| 67 |
prog = env.Program(target=radbin(p[0]), source=p[1],
| 68 |
LIBS=p[2]+env['RAD_MLIB'])
| 69 |
Default(prog)
| 70 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
| 71 |
| 72 |
| 73 |
| 74 |
# X11 targets
| 75 |
if env.has_key('X11LIB'):
| 76 |
x11meta = env.Program(radbin('x11meta'), [plotin, primout]+ common,
| 77 |
CPPPATH=env.get('CPPPATH',[])+[env['X11INCLUDE']],
| 78 |
LIBPATH=env.get('LIBPATH',[])+[env['X11LIB']],
| 79 |
LIBS=['rtcont','rtmem','rterror', 'X11'] + env['RAD_MLIB'])
| 80 |
Default(x11meta)
| 81 |
env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], x11meta)])
| 82 |
| 83 |
