root/radiance/ray/src/meta/SConscript
Revision: 1.3
Committed: Sun Jul 4 12:08:48 2004 UTC (20 years, 10 months ago) by schorsch
1 import os
2
3 Import ('env')
4
5 # compose paths
6 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
7 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
8
9 # extra flag
10 MDIRFLAGS = env.get('CPPFLAGS', []) + [
11 '-DMDIR=\\"%s\\"' % os.path.join(env['RAD_RLIBDIR'], 'meta')]
12 bgraph = env.Object(source='bgraph.c', CPPFLAGS=MDIRFLAGS)
13 igraph = env.Object(source='igraph.c', CPPFLAGS=MDIRFLAGS)
14 dgraph = env.Object(source='dgraph.c', CPPFLAGS=MDIRFLAGS)
15 gcomp = env.Object(source='gcomp.c', CPPFLAGS=MDIRFLAGS)
16 syscalls = env.Object(source='syscalls.c', CPPFLAGS=MDIRFLAGS)
17 # used by several targets
18 mfio = env.Object(source='mfio.c')
19 misc = env.Object(source='misc.c')
20 primout = env.Object(source='primout.c')
21 plot = env.Object(source='plot.c')
22 palloc = env.Object(source='palloc.c')
23 mplot = env.Object(source='mplot.c')
24 plotin = env.Object(source='plotin.c')
25 tgraph = env.Object(source='tgraph.c')
26 mgvars = env.Object(source='mgvars.c')
27 mgraph = env.Object(source='mgraph.c')
28 cgraph = env.Object(source='cgraph.c')
29 gcalc = env.Object(source='gcalc.c')
30 # multiple output from same source
31 plotout = env.Object(source='plotout.c')
32 t4014 = env.Object(target="t4014", source='plotout.c',
33 CPPFLAGS=env.get('CPPFLAGS',[]) + ['-DFORTEK'])
34
35 common = [mfio, misc, syscalls]
36
37 libmeta = env.StaticLibrary(radlib('meta'),
38 Split ('metacalls.c progname.c') +[primout] + common)
39
40 # standard targets
41 PROGS = (
42 ('meta2tga', Split('meta2tga.c rplot.c') +[palloc, plot] + common,
43 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
44 'rtcont','rtmem','rterror']),
45 ('pexpand', Split('pexpand.c expand.c segment.c') +[palloc]+ common,
46 ['rtcont','rtmem','rterror']),
47 ('psort', Split('psort.c sort.c') +[palloc]+ common,
48 ['rtpath','rtcont','rtmem','rterror']),
49 ('cv', Split('cv.c cvhfio.c') + common,
50 ['rtcont','rtmem','rterror']),
51 ('psmeta', Split('psmeta.c psplot.c') + common,
52 ['rtcont','rtmem','rterror']),
53 ('plotin', [plotin, primout] + common,
54 ['rtcont','rtmem','rterror']),
55 ('bgraph', [bgraph, mgraph, mgvars],
56 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
57 'rtfunc','rtcont','rtmem','meta','rterror']),
58 ('igraph', [igraph, gcalc, cgraph, mgraph, mgvars],
59 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
60 'rtfunc','rtcont','rtmem','meta','rterror']),
61 ('dgraph', [dgraph, cgraph, mgvars],
62 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
63 'rtfunc','rtcont','rtmem','rterror']),
64 ('gcomp', [gcomp, gcalc, mgvars],
65 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
66 'rtfunc','rtcont','rtmem','rterror']),
67 ('plot4', Split('plot4.c') +[primout]+ common,
68 ['rtproc','rtpath','rtio', # proc/path/rtio for win_popen()
69 'rtcont','rtmem','rterror']),
70 )
71 for p in PROGS:
72 prog = env.Program(target=radbin(p[0]), source=p[1],
73 LIBS=p[2]+env['RAD_MLIB'])
74 Default(prog)
75 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
76
77
78 lib4014srcs = Split('''arc.c box.c circle.c close.c dot.c erase.c label.c
79 line.c linemod.c move.c open.c point.c space.c subr.c''')
80 lib4014 = env.Library(os.path.join(env['RAD_BUILDLIB'], '4014'),
81 source=map(lambda s:os.path.join('lib4014', s), lib4014srcs))
82
83 plotsrc = [mplot, palloc, plot]
84
85 SPECIAL = (
86 ('mt160l', Split('mt160l.c') + plotsrc + common,
87 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
88 ('mt160', Split('mt160.c') + plotsrc + common,
89 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
90 ('mtext', Split('mtext.c') +[primout]+ common,
91 ['rtcont','rtmem','rterror']),
92 ('okimate', Split('okimate.c') + plotsrc + common,
93 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
94 ('mx80', Split('mx80.c') + plotsrc + common,
95 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
96 ('imagew', Split('imagew.c') + plotsrc + common,
97 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
98 ('impress', Split('impress.c implot.c imPfuncs.c') +[plot]+ common,
99 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
100 ('aed5', Split('aed5.c') + common,
101 ['rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
102 ('tcurve', Split('tcurve.c') +[tgraph, primout]+ common,
103 ['rtcont','rtmem','rterror']),
104 ('tscat', Split('tscat.c') +[tgraph, primout]+ common,
105 ['rtpath','rtcont','rtmem','rterror']),
106 ('tbar', Split('tbar.c') +[tgraph, primout]+ common,
107 ['rtcont','rtmem','rterror']),
108 ('plotout', [plotout] + common,
109 ['4014', 'rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
110 ('t4014', [t4014] + common,
111 ['4014', 'rtproc','rtpath','rtio','rtcont','rtmem','rterror']),
112 )
113 sbin = []
114 sinst = []
115 for p in SPECIAL:
116 prog = env.Program(target=radbin(p[0]), source=p[1],
117 LIBS=p[2]+env['RAD_MLIB'])
118 sbin.append(prog)
119 sinst.append(env.Install(env['RAD_BINDIR'], prog))
120 env.Alias('meta_special', sbin)
121 env.Alias('meta_special_install', sinst)
122
123 # X11 targets
124 if env.has_key('X11LIB'):
125 x11meta = env.Program(radbin('x11meta'), [plotin, primout]+ common,
126 CPPPATH=env.get('CPPPATH',[])+[env['X11INCLUDE']],
127 LIBPATH=env.get('LIBPATH',[])+[env['X11LIB']],
128 LIBS=['rtcont','rtmem','rterror', 'X11'] + env['RAD_MLIB'])
129 Default(x11meta)
130 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], x11meta)])
131
132
