root/radiance/ray/src/meta/SConscript
Revision: 1.8
Committed: Mon Jan 8 13:38:37 2018 UTC (7 years, 5 months ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad5R3, HEAD
1 from __future__ import division, print_function, unicode_literals
2
3 import os
4
5 Import ('env')
6
7 # compose paths
8 def radbin(name): return os.path.join(env['RAD_BUILDBIN'], name)
9 def radlib(name): return os.path.join(env['RAD_BUILDLIB'], name)
10
11 # extra flag
12 MDIRFLAGS = env.get('CPPFLAGS', []) + [
13 '-DMDIR=\\"%s\\"' % os.path.join(env['RAD_RLIBDIR'], 'meta')]
14 bgraph = env.Object(source='bgraph.c', CPPFLAGS=MDIRFLAGS)
15 igraph = env.Object(source='igraph.c', CPPFLAGS=MDIRFLAGS)
16 dgraph = env.Object(source='dgraph.c', CPPFLAGS=MDIRFLAGS)
17 gcomp = env.Object(source='gcomp.c', CPPFLAGS=MDIRFLAGS)
18 syscalls = env.Object(source='syscalls.c', CPPFLAGS=MDIRFLAGS)
19 # used by several targets
20 mfio = env.Object(source='mfio.c')
21 misc = env.Object(source='misc.c')
22 primout = env.Object(source='primout.c')
23 plot = env.Object(source='plot.c')
24 rplot = env.Object(source='rplot.c')
25 palloc = env.Object(source='palloc.c')
26 plotin = env.Object(source='plotin.c')
27 mgvars = env.Object(source='mgvars.c')
28 mgraph = env.Object(source='mgraph.c')
29 cgraph = env.Object(source='cgraph.c')
30 gcalc = env.Object(source='gcalc.c')
31 # multiple output from same source
32
33 common = [mfio, misc, syscalls]
34
35 libmeta = env.StaticLibrary(radlib('meta'),
36 Split ('metacalls.c progname.c') +[primout] + common)
37
38 # standard targets
39 PROGS = (
40 ('meta2bmp', Split('meta2bmp.c') +[rplot, palloc, plot] + common, ['rtrad']),
41 ('meta2tga', Split('meta2tga.c') +[rplot, palloc, plot] + common, ['rtrad']),
42 ('pexpand', Split('pexpand.c expand.c segment.c') +[palloc]+ common,['rtrad']),
43 ('psort', Split('psort.c sort.c') +[palloc]+ common, ['rtrad']),
44 ('cv', Split('cv.c cvhfio.c') + common, ['rtrad']),
45 ('psmeta', Split('psmeta.c psplot.c') + common, ['rtrad']),
46 ('plotin', [plotin, primout] + common, ['rtrad']),
47 ('bgraph', [bgraph, mgraph, mgvars], ['rtrad', 'meta']),
48 ('igraph', [igraph, gcalc, cgraph, mgraph, mgvars], ['rtrad', 'meta']),
49 ('dgraph', [dgraph, cgraph, mgvars], ['rtrad']),
50 ('gcomp', [gcomp, gcalc, mgvars], ['rtrad']),
51 ('plot4', Split('plot4.c') +[primout]+ common, ['rtrad']),
52 )
53 for p in PROGS:
54 prog = env.Program(target=radbin(p[0]), source=p[1],
55 LIBS=p[2]+env['RAD_MLIB'], )
56 Default(prog)
57 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], prog)])
58
59 # X11 targets
60 if env.has_key('X11LIB'):
61 x11meta = env.Program(radbin('x11meta'), [plotin, primout]+ common,
62 CPPPATH=env.get('CPPPATH',[])+[env['X11INCLUDE']],
63 LIBPATH=env.get('LIBPATH',[])+[env['X11LIB']],
64 LIBS=['rtrad', 'X11'] + env['RAD_MLIB'])
65 Default(x11meta)
66 env.Append(RAD_BININSTALL=[env.Install(env['RAD_BINDIR'], x11meta)])
67
68
69 # vim: set syntax=python:
70 # vi: set ts=4 sw=4 :
