root/Development/ray/src/meta/Rmakefile
Sat Apr 26 15:59:38 2014 UTC (11 years, 7 months ago) by greg
Changes since 1.13: +2 -2 lines
Diff to previous 1.13 , to selected 1.1
Thu Feb 7 23:02:14 2008 UTC (17 years, 10 months ago) by greg
CVS Tags: rad3R9, rad4R0, rad4R1
Diff to previous 1.12 , to selected 1.1
Sat Nov 24 00:37:27 2007 UTC (18 years ago) by greg
Changes since 1.11: +10 -10 lines
Diff to previous 1.11 , to selected 1.1
Fri Mar 10 19:40:13 2006 UTC (19 years, 9 months ago) by schorsch
Changes since 1.10: +17 -17 lines
Diff to previous 1.10 , to selected 1.1
Wed May 4 23:43:19 2005 UTC (20 years, 7 months ago) by greg
Changes since 1.9: +12 -6 lines
Diff to previous 1.9 , to selected 1.1
Created meta2bmp file to generate BMP output from metafile graphics
Fri Nov 5 17:51:16 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.8: +4 -18 lines
Diff to previous 1.8 , to selected 1.1
Removed plotout and lib4014 it depends on
Fri Nov 5 03:31:37 2004 UTC (21 years, 1 month ago) by greg
Changes since 1.7: +9 -53 lines
Diff to previous 1.7 , to selected 1.1
Wed Oct 22 02:15:07 2003 UTC (22 years, 1 month ago) by greg
Changes since 1.6: +33 -32 lines
Diff to previous 1.6 , to selected 1.1
Fixed Rmakefile for FreeBSD version of make, which wasn't happy
Sat Aug 30 08:18:43 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 1.5 , to selected 1.1
Fixed special target selection.
Wed Aug 20 09:28:07 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 1.4: +88 -109 lines
Diff to previous 1.4 , to selected 1.1
Adapted Rmakefile to work the same way as the others.
Fri Aug 1 14:14:24 2003 UTC (22 years, 4 months ago) by schorsch
Diff to previous 1.3 , to selected 1.1
Eliminated CPM, MAC, and UNIX conditional compiles.
Mon Jul 14 16:07:41 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 1.1
Changed to relying on error() call in Radiance library
Thu Jun 26 00:49:15 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 1.1: +5 -5 lines
Compile fixes for "special" target on Linux.
Revision 1.1 - (view) (download) (annotate) - [selected]
Sat Feb 22 02:07:26 2003 UTC (22 years, 9 months ago) by greg
