root/Development/ray/src/hd/sm_usets.c
Revision: 3.6
Committed: Fri Nov 5 03:31:37 2004 UTC (21 years, 2 months ago) by greg
Changes since 3.5: +1 -1 lines
State: FILE REMOVED
2 static const char RCSid[] = "$Id: sm_usets.c,v 3.5 2003/06/30 14:59:12 schorsch Exp $";
5 * Quadtree-specific set operations with unsorted sets.
6 */
7
8 #include <string.h>
9
10 #include "standard.h"
11 #include "sm_flag.h"
12 #include "object.h"
13 #include "sm_qtree.h"
14
15
16 #define QTSETIBLK 2048 /* set index allocation block size */
17 #define QTELEMBLK 8 /* set element allocation block */
18 #define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */
19
20 #define QTONTHRESH(ne) (!QTELEMMOD((ne)+1))
21 #define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne))
22
23 OBJECT **qtsettab= NULL; /* quadtree leaf node table */
24 QUADTREE qtnumsets=0; /* number of used set indices */
25 static int qtfreesets = EMPTY; /* free set index list */
26 int32 *qtsetflag = NULL;
27 static int qtallocsets =0;
28
29 qtclearsetflags()
30 {
31
32 if(!qtsetflag)
33 return;
34
35 memset((char *)qtsetflag, '\0', FLAG_BYTES(qtallocsets));
36 }
37
38
39 QUADTREE
40 qtnewleaf(oset) /* return new leaf node for object set */
41 OBJECT *oset;
42 {
43 register QUADTREE osi;
44
45 if (*oset <= 0)
46 return(EMPTY); /* should be error? */
47 if (qtfreesets != EMPTY) {
48 osi = qtfreesets;
49 qtfreesets = (int)qtsettab[osi];
50 } else if ((osi = qtnumsets++) % QTSETIBLK == 0) {
51 qtsettab = (OBJECT **)realloc((void *)qtsettab,
52 (unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *));
53 if (qtsettab == NULL)
54 goto memerr;
55 qtsetflag = (int32 *)realloc((void *)qtsetflag,
56 FLAG_BYTES(osi+ QTSETIBLK));
57 if (qtsetflag == NULL)
58 goto memerr;
59 if(qtallocsets)
60 memset((char *)((char *)(qtsetflag)+FLAG_BYTES(qtallocsets)), '\0',
61 FLAG_BYTES(osi+QTSETIBLK)-FLAG_BYTES(qtallocsets));
62 else
63 memset((char *)(qtsetflag), '\0', FLAG_BYTES(osi +QTSETIBLK));
64
65 qtallocsets = osi + QTSETIBLK;
66 }
67 qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT));
68 if (qtsettab[osi] == NULL)
69 goto memerr;
70 setcopy(qtsettab[osi], oset);
71 return(QT_INDEX(osi));
72 memerr:
73 error(SYSTEM, "out of memory in qtnewleaf\n");
74 }
75
76
77 deletuelem(os, obj) /* delete obj from unsorted os, no questions */
78 register OBJECT *os;
79 OBJECT obj;
80 {
81 register int i,j;
82 OBJECT *optr;
83 /* Take 2nd to last and put in position of obj: move last down:
84 want to preserve last added
85 */
86 i = (*os)--;
87 #ifdef DEBUG
88 if( i <= 0)
89 error(CONSISTENCY,"deleteuelem():empty set\n");
90 #endif
91 if(i < 3)
92 {
93 if((i == 2) && (*(++os) == obj))
94 *os = *(os+1);
95 return;
96 }
97 optr = os + i;
98 os++;
99 while (i-- > 1 && *os != obj)
100 os++;
101 #ifdef DEBUG
102 if( *os != obj)
103 error(CONSISTENCY,"deleteuelem():id not found\n");
104 #endif
105 *os = *(optr-1);
106 *(optr-1) = *optr;
107 }
108
109 QUADTREE
110 qtdeletuelem(qt, id) /* delete element from unsorted leaf node */
111 QUADTREE qt;
112 OBJECT id;
113 {
114 register QUADTREE lf;
115 #ifdef DEBUG
116 if(id < 0)
117 eputs("qtdeletuelem():Invalid triangle id\n");
118 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
119 error(CONSISTENCY, "empty/bad node in qtdelelem");
120 #else
121 lf = QT_SET_INDEX(qt);
122 #endif
123 if (qtsettab[lf][0] <= 1) { /* blow leaf away */
124 free((void *)qtsettab[lf]);
125 qtsettab[lf] = (OBJECT *)qtfreesets;
126 qtfreesets = lf;
127 return(EMPTY);
128 }
129 deletuelem(qtsettab[lf], id);
130 if (QTONTHRESH(qtsettab[lf][0]))
131 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
132 QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT));
133 return(qt);
134 }
135
136 QUADTREE
137 qtdelelem(qt, id) /* delete element from leaf node */
138 QUADTREE qt;
139 OBJECT id;
140 {
141 register QUADTREE lf;
142 #ifdef DEBUG
143 if(id < 0)
144 eputs("qtdelelem():Invalid triangle id\n");
145 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
146 error(CONSISTENCY, "empty/bad node in qtdelelem");
147 #else
148 lf = QT_SET_INDEX(qt);
149 #endif
150
151 if (!inset(qtsettab[lf], id))
152 {
153 #ifdef DEBUG
154 eputs("id not in leaf in qtdelelem\n");
155 #endif
156 return(qt);
157 }
158 if (qtsettab[lf][0] <= 1) { /* blow leaf away */
159 free((void *)qtsettab[lf]);
160 qtsettab[lf] = (OBJECT *)qtfreesets;
161 qtfreesets = lf;
162 return(EMPTY);
163 }
164 deletelem(qtsettab[lf], id);
165 if (QTONTHRESH(qtsettab[lf][0]))
166 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
167 QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT));
168 return(qt);
169 }
170
171
172 QUADTREE
173 qtaddelem(qt, id) /* add element to leaf node */
174 QUADTREE qt;
175 OBJECT id;
176 {
177 OBJECT newset[2];
178 register QUADTREE lf;
179
180 #ifdef DEBUG
181 if(id < 0)
182 eputs("qtaddelem():Invalid triangle id\n");
183 #endif
184 if (QT_IS_EMPTY(qt)) { /* create new leaf */
185 newset[0] = 1; newset[1] = id;
186 return(qtnewleaf(newset));
187 } /* else add element */
188 #ifdef DEBUG
189 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
190 error(CONSISTENCY, "bad node in qtaddelem");
191 #else
192 lf = QT_SET_INDEX(qt);
193 #endif
194
195 if (inset(qtsettab[lf], id))
196 {
197 #ifdef DEBUG
198 eputs("id already in leaf in qtaddelem\n");
199 #endif
200 return(qt);
201 }
202 if (QTONTHRESH(qtsettab[lf][0])) {
203 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
204 QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT));
205 if (qtsettab[lf] == NULL)
206 error(SYSTEM, "out of memory in qtaddelem");
207 }
208 insertelem(qtsettab[lf], id);
209 return(qt);
210 }
211
212 #define insertuelem(os,id) ((os)[++((os)[0])] = (id))
213
214 int
215 qtcompressuelem(qt,compress_set)
216 QUADTREE qt;
217 int (*compress_set)();
218 {
219 register QUADTREE lf;
220 int i,j,osize;
221 OBJECT *os;
222
223 if(QT_IS_EMPTY(qt))
224 return(qt);
225 #ifdef DEBUG
226 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
227 error(CONSISTENCY, "bad node in qtaddelem");
228 #else
229 lf = QT_SET_INDEX(qt);
230 #endif
231 os = qtsettab[lf];
232 osize = os[0];
233 if((i=compress_set(os)) < osize)
234 {
235 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
236 QTNODESIZ(i+1)*sizeof(OBJECT));
237 if (qtsettab[lf] == NULL)
238 error(SYSTEM, "out of memory in qtaddelem");
239 }
240 return(qt);
241 }
242
243
244 QUADTREE
245 qtadduelem(qt, id) /* add element to unsorted leaf node */
246 QUADTREE qt;
247 OBJECT id;
248 {
249 OBJECT newset[2];
250 register QUADTREE lf;
251
252 #ifdef DEBUG
253 if(id < 0)
254 eputs("qtadduelem():Invalid sample id\n");
255 #endif
256 if (QT_IS_EMPTY(qt)) { /* create new leaf */
257 newset[0] = 1; newset[1] = id;
258 return(qtnewleaf(newset));
259 } /* else add element */
260 #ifdef DEBUG
261 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
262 error(CONSISTENCY, "bad node in qtaddelem");
263 #else
264 lf = QT_SET_INDEX(qt);
265 #endif
266 if (QTONTHRESH(qtsettab[lf][0])) {
267 qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf],
268 QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT));
269 if (qtsettab[lf] == NULL)
270 error(SYSTEM, "out of memory in qtaddelem");
271 }
272 insertuelem(qtsettab[lf], id);
273 return(qt);
274 }
275
276
277 #ifdef DEBUG
278 OBJECT *
279 qtqueryset(qt) /* return object set for leaf node */
280 QUADTREE qt;
281 {
282 register QUADTREE lf;
283
284 if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets)
285 error(CONSISTENCY, "bad node in qtqueryset");
286 return(qtsettab[lf]);
287 }
288 #endif
289
290 int
291 qtinuset(qt,id)
292 QUADTREE qt;
293 OBJECT id;
294 {
295 OBJECT *os;
296 int i;
297
298 os = qtqueryset(qt);
299 for(i=os[0],os++; i > 0; i--,os++)
300 if(*os==id)
301 return(1);
302
303 return(0);
304 }
305
306
307 qtfreeleaf(qt) /* free set and leaf node */
308 QUADTREE qt;
309 {
310 register QUADTREE osi;
311
312 if (!QT_IS_LEAF(qt))
313 return;
314 osi = QT_SET_INDEX(qt);
315 if (osi >= qtnumsets)
316 return;
317 free((void *)qtsettab[osi]);
318 qtsettab[osi] = (OBJECT *)qtfreesets;
319 qtfreesets = osi;
320 }
321
322
323
324 qtfreeleaves() /* free ALL sets and leaf nodes */
325 {
326 register int i;
327
328 while ((i = qtfreesets) != EMPTY) {
329 qtfreesets = (int)qtsettab[i];
330 qtsettab[i] = NULL;
331 }
332 for (i = qtnumsets; i--; )
333 if (qtsettab[i] != NULL)
334 free((void *)qtsettab[i]);
335 free((void *)qtsettab);
336 qtsettab = NULL;
337 if(qtsetflag)
338 {
339 free((void *)qtsetflag);
340 qtsetflag=0;
341 }
342 qtnumsets = 0;
343 }
344
345
346 /* no bounds on os csptr. This routine is conservative: the result returned
347 in os is the set intersection, and therefore is bounded by the size of os.
348 cs is bound to be <= QT_MAXCSET
349 */
350 check_set_large(os, cs) /* modify checked set and set to check */
351 register OBJECT *os; /* os' = os - cs */
352 register OBJECT *cs; /* cs' = cs + os */
353 {
354 OBJECT cset[QT_MAXCSET+1];
355 register int i, j;
356 int k;
357 /* copy os in place, cset <- cs */
358
359 cset[0] = 0;
360 k = 0;
361 for (i = j = 1; i <= os[0]; i++) {
362 while (j <= cs[0] && cs[j] < os[i])
363 if(cset[0] < QT_MAXCSET)
364 cset[++cset[0]] = cs[j++];
365 else
366 j++;
367 if (j > cs[0] || os[i] != cs[j]) { /* object to check */
368 os[++k] = os[i];
369 if(cset[0] < QT_MAXCSET)
370 cset[++cset[0]] = os[i];
371 }
372 }
373 if (!(os[0] = k)) /* new "to check" set size */
374 return; /* special case */
375
376 while (j <= cs[0]) /* get the rest of cs */
377 if(cset[0] == QT_MAXCSET)
378 break;
379 else
380 cset[++cset[0]] = cs[j++];
381
382 os = cset; /* copy cset back to cs */
383 for (i = os[0]; i-- >= 0; )
384 *cs++ = *os++;
385
386 }
387
388
389
390
