1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Quadtree-specific set operations with unsorted sets. |
6 |
7 |
8 |
#include "standard.h" |
9 |
#include "sm_flag.h" |
10 |
#include "object.h" |
11 |
#include "sm_qtree.h" |
12 |
13 |
14 |
#define QTSETIBLK 2048 /* set index allocation block size */ |
15 |
#define QTELEMBLK 8 /* set element allocation block */ |
16 |
#define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */ |
17 |
18 |
#define QTONTHRESH(ne) (!QTELEMMOD((ne)+1)) |
19 |
#define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne)) |
20 |
21 |
OBJECT **qtsettab= NULL; /* quadtree leaf node table */ |
22 |
QUADTREE qtnumsets=0; /* number of used set indices */ |
23 |
static int qtfreesets = EMPTY; /* free set index list */ |
24 |
int4 *qtsetflag = NULL; |
25 |
static int qtallocsets =0; |
26 |
27 |
qtclearsetflags() |
28 |
29 |
30 |
if(!qtsetflag) |
31 |
return; |
32 |
33 |
bzero((char *)qtsetflag,FLAG_BYTES(qtallocsets)); |
34 |
35 |
36 |
37 |
QUADTREE |
38 |
qtnewleaf(oset) /* return new leaf node for object set */ |
39 |
OBJECT *oset; |
40 |
41 |
register QUADTREE osi; |
42 |
43 |
if (*oset <= 0) |
44 |
return(EMPTY); /* should be error? */ |
45 |
if (qtfreesets != EMPTY) { |
46 |
osi = qtfreesets; |
47 |
qtfreesets = (int)qtsettab[osi]; |
48 |
} else if ((osi = qtnumsets++) % QTSETIBLK == 0) { |
49 |
qtsettab = (OBJECT **)realloc((void *)qtsettab, |
50 |
(unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *)); |
51 |
if (qtsettab == NULL) |
52 |
goto memerr; |
53 |
qtsetflag = (int4 *)realloc((void *)qtsetflag, |
54 |
FLAG_BYTES(osi+ QTSETIBLK)); |
55 |
if (qtsetflag == NULL) |
56 |
goto memerr; |
57 |
if(qtallocsets) |
58 |
bzero((char *)((char *)(qtsetflag)+FLAG_BYTES(qtallocsets)), |
59 |
FLAG_BYTES(osi+QTSETIBLK)-FLAG_BYTES(qtallocsets)); |
60 |
else |
61 |
bzero((char *)(qtsetflag),FLAG_BYTES(osi +QTSETIBLK)); |
62 |
63 |
qtallocsets = osi + QTSETIBLK; |
64 |
65 |
qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT)); |
66 |
if (qtsettab[osi] == NULL) |
67 |
goto memerr; |
68 |
setcopy(qtsettab[osi], oset); |
69 |
return(QT_INDEX(osi)); |
70 |
memerr: |
71 |
error(SYSTEM, "out of memory in qtnewleaf\n"); |
72 |
73 |
74 |
75 |
deletuelem(os, obj) /* delete obj from unsorted os, no questions */ |
76 |
register OBJECT *os; |
77 |
OBJECT obj; |
78 |
79 |
register int i,j; |
80 |
OBJECT *optr; |
81 |
/* Take 2nd to last and put in position of obj: move last down: |
82 |
want to preserve last added |
83 |
84 |
i = (*os)--; |
85 |
#ifdef DEBUG |
86 |
if( i <= 0) |
87 |
error(CONSISTENCY,"deleteuelem():empty set\n"); |
88 |
#endif |
89 |
if(i < 3) |
90 |
91 |
if((i == 2) && (*(++os) == obj)) |
92 |
*os = *(os+1); |
93 |
return; |
94 |
95 |
optr = os + i; |
96 |
os++; |
97 |
while (i-- > 1 && *os != obj) |
98 |
os++; |
99 |
#ifdef DEBUG |
100 |
if( *os != obj) |
101 |
error(CONSISTENCY,"deleteuelem():id not found\n"); |
102 |
#endif |
103 |
*os = *(optr-1); |
104 |
*(optr-1) = *optr; |
105 |
106 |
107 |
QUADTREE |
108 |
qtdeletuelem(qt, id) /* delete element from unsorted leaf node */ |
109 |
QUADTREE qt; |
110 |
OBJECT id; |
111 |
112 |
register QUADTREE lf; |
113 |
#ifdef DEBUG |
114 |
if(id < 0) |
115 |
eputs("qtdeletuelem():Invalid triangle id\n"); |
116 |
if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets) |
117 |
error(CONSISTENCY, "empty/bad node in qtdelelem"); |
118 |
#else |
119 |
lf = QT_SET_INDEX(qt); |
120 |
#endif |
121 |
if (qtsettab[lf][0] <= 1) { /* blow leaf away */ |
122 |
free((void *)qtsettab[lf]); |
123 |
qtsettab[lf] = (OBJECT *)qtfreesets; |
124 |
qtfreesets = lf; |
125 |
return(EMPTY); |
126 |
127 |
deletuelem(qtsettab[lf], id); |
128 |
if (QTONTHRESH(qtsettab[lf][0])) |
129 |
qtsettab[lf] = (OBJECT *)realloc((void *)qtsettab[lf], |
130 |
QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT)); |
131 |
return(qt); |
132 |
133 |
134 |
QUADTREE |
135 |
qtdelelem(qt, id) /* delete element from leaf node */ |
136 |
QUADTREE qt; |
137 |
OBJECT id; |
138 |
139 |
140 |
#ifdef DEBUG |
141 |
if(id < 0) |
142 |
eputs("qtdelelem():Invalid triangle id\n"); |
143 |
144 |
145 |
#else |
146 |
147 |
#endif |
148 |
149 |
if (!inset(qtsettab[lf], id)) |
150 |
151 |
#ifdef DEBUG |
152 |
eputs("id not in leaf in qtdelelem\n"); |
153 |
#endif |
154 |
return(qt); |
155 |
156 |
157 |
158 |
159 |
qtfreesets = lf; |
160 |
return(EMPTY); |
161 |
162 |
deletelem(qtsettab[lf], id); |
163 |
164 |
165 |
166 |
return(qt); |
167 |
168 |
169 |
170 |
QUADTREE |
171 |
qtaddelem(qt, id) /* add element to leaf node */ |
172 |
QUADTREE qt; |
173 |
OBJECT id; |
174 |
175 |
OBJECT newset[2]; |
176 |
177 |
178 |
#ifdef DEBUG |
179 |
if(id < 0) |
180 |
eputs("qtaddelem():Invalid triangle id\n"); |
181 |
#endif |
182 |
if (QT_IS_EMPTY(qt)) { /* create new leaf */ |
183 |
newset[0] = 1; newset[1] = id; |
184 |
return(qtnewleaf(newset)); |
185 |
} /* else add element */ |
186 |
#ifdef DEBUG |
187 |
188 |
error(CONSISTENCY, "bad node in qtaddelem"); |
189 |
#else |
190 |
191 |
#endif |
192 |
193 |
if (inset(qtsettab[lf], id)) |
194 |
195 |
#ifdef DEBUG |
196 |
eputs("id already in leaf in qtaddelem\n"); |
197 |
#endif |
198 |
return(qt); |
199 |
200 |
if (QTONTHRESH(qtsettab[lf][0])) { |
201 |
202 |
QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT)); |
203 |
if (qtsettab[lf] == NULL) |
204 |
error(SYSTEM, "out of memory in qtaddelem"); |
205 |
206 |
insertelem(qtsettab[lf], id); |
207 |
return(qt); |
208 |
209 |
210 |
#define insertuelem(os,id) ((os)[++((os)[0])] = (id)) |
211 |
212 |
int |
213 |
qtcompressuelem(qt,compress_set) |
214 |
QUADTREE qt; |
215 |
int (*compress_set)(); |
216 |
217 |
218 |
int i,j,osize; |
219 |
OBJECT *os; |
220 |
221 |
if(QT_IS_EMPTY(qt)) |
222 |
return(qt); |
223 |
#ifdef DEBUG |
224 |
225 |
226 |
#else |
227 |
228 |
#endif |
229 |
os = qtsettab[lf]; |
230 |
osize = os[0]; |
231 |
if((i=compress_set(os)) < osize) |
232 |
233 |
234 |
QTNODESIZ(i+1)*sizeof(OBJECT)); |
235 |
236 |
237 |
238 |
return(qt); |
239 |
240 |
241 |
242 |
QUADTREE |
243 |
qtadduelem(qt, id) /* add element to unsorted leaf node */ |
244 |
QUADTREE qt; |
245 |
OBJECT id; |
246 |
247 |
OBJECT newset[2]; |
248 |
249 |
250 |
#ifdef DEBUG |
251 |
if(id < 0) |
252 |
eputs("qtadduelem():Invalid sample id\n"); |
253 |
#endif |
254 |
255 |
256 |
257 |
258 |
#ifdef DEBUG |
259 |
260 |
261 |
#else |
262 |
263 |
#endif |
264 |
265 |
266 |
267 |
268 |
269 |
270 |
insertuelem(qtsettab[lf], id); |
271 |
return(qt); |
272 |
273 |
274 |
275 |
#ifdef DEBUG |
276 |
OBJECT * |
277 |
qtqueryset(qt) /* return object set for leaf node */ |
278 |
QUADTREE qt; |
279 |
280 |
281 |
282 |
283 |
error(CONSISTENCY, "bad node in qtqueryset"); |
284 |
return(qtsettab[lf]); |
285 |
286 |
#endif |
287 |
288 |
int |
289 |
qtinuset(qt,id) |
290 |
QUADTREE qt; |
291 |
OBJECT id; |
292 |
293 |
OBJECT *os; |
294 |
int i; |
295 |
296 |
os = qtqueryset(qt); |
297 |
for(i=os[0],os++; i > 0; i--,os++) |
298 |
if(*os==id) |
299 |
return(1); |
300 |
301 |
return(0); |
302 |
303 |
304 |
305 |
qtfreeleaf(qt) /* free set and leaf node */ |
306 |
QUADTREE qt; |
307 |
308 |
309 |
310 |
if (!QT_IS_LEAF(qt)) |
311 |
return; |
312 |
osi = QT_SET_INDEX(qt); |
313 |
if (osi >= qtnumsets) |
314 |
return; |
315 |
free((void *)qtsettab[osi]); |
316 |
qtsettab[osi] = (OBJECT *)qtfreesets; |
317 |
qtfreesets = osi; |
318 |
319 |
320 |
321 |
322 |
qtfreeleaves() /* free ALL sets and leaf nodes */ |
323 |
324 |
register int i; |
325 |
326 |
while ((i = qtfreesets) != EMPTY) { |
327 |
qtfreesets = (int)qtsettab[i]; |
328 |
qtsettab[i] = NULL; |
329 |
330 |
for (i = qtnumsets; i--; ) |
331 |
if (qtsettab[i] != NULL) |
332 |
free((void *)qtsettab[i]); |
333 |
free((void *)qtsettab); |
334 |
qtsettab = NULL; |
335 |
if(qtsetflag) |
336 |
337 |
free((void *)qtsetflag); |
338 |
qtsetflag=0; |
339 |
340 |
qtnumsets = 0; |
341 |
342 |
343 |
344 |
/* no bounds on os csptr. This routine is conservative: the result returned |
345 |
in os is the set intersection, and therefore is bounded by the size of os. |
346 |
cs is bound to be <= QT_MAXCSET |
347 |
348 |
check_set_large(os, cs) /* modify checked set and set to check */ |
349 |
register OBJECT *os; /* os' = os - cs */ |
350 |
register OBJECT *cs; /* cs' = cs + os */ |
351 |
352 |
OBJECT cset[QT_MAXCSET+1]; |
353 |
register int i, j; |
354 |
int k; |
355 |
/* copy os in place, cset <- cs */ |
356 |
357 |
cset[0] = 0; |
358 |
k = 0; |
359 |
for (i = j = 1; i <= os[0]; i++) { |
360 |
while (j <= cs[0] && cs[j] < os[i]) |
361 |
if(cset[0] < QT_MAXCSET) |
362 |
cset[++cset[0]] = cs[j++]; |
363 |
else |
364 |
j++; |
365 |
if (j > cs[0] || os[i] != cs[j]) { /* object to check */ |
366 |
os[++k] = os[i]; |
367 |
368 |
cset[++cset[0]] = os[i]; |
369 |
370 |
371 |
if (!(os[0] = k)) /* new "to check" set size */ |
372 |
return; /* special case */ |
373 |
374 |
while (j <= cs[0]) /* get the rest of cs */ |
375 |
if(cset[0] == QT_MAXCSET) |
376 |
break; |
377 |
else |
378 |
379 |
380 |
os = cset; /* copy cset back to cs */ |
381 |
for (i = os[0]; i-- >= 0; ) |
382 |
*cs++ = *os++; |
383 |
384 |
385 |
386 |
387 |
388 |
