1 |
/* Copyright (c) 1998 Silicon Graphics, Inc. */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ SGI"; |
5 |
#endif |
6 |
7 |
8 |
* Quadtree-specific set operations with unsorted sets. |
9 |
10 |
11 |
#include "standard.h" |
12 |
#include "sm_flag.h" |
13 |
#include "sm_qtree.h" |
14 |
15 |
16 |
#define QTSETIBLK 2048 /* set index allocation block size */ |
17 |
#define QTELEMBLK 8 /* set element allocation block */ |
18 |
#define QTELEMMOD(ne) ((ne)&7) /* (ne) % QTELEMBLK */ |
19 |
20 |
#define QTONTHRESH(ne) (!QTELEMMOD((ne)+1)) |
21 |
#define QTNODESIZ(ne) ((ne) + QTELEMBLK - QTELEMMOD(ne)) |
22 |
23 |
OBJECT **qtsettab= NULL; /* quadtree leaf node table */ |
24 |
QUADTREE qtnumsets=0; /* number of used set indices */ |
25 |
static int qtfreesets = EMPTY; /* free set index list */ |
26 |
int4 *qtsetflag = NULL; |
27 |
static int qtallocsets =0; |
28 |
29 |
qtclearsetflags() |
30 |
31 |
32 |
if(!qtsetflag) |
33 |
return; |
34 |
35 |
bzero((char *)qtsetflag,FLAG_BYTES(qtallocsets)); |
36 |
37 |
38 |
39 |
QUADTREE |
40 |
qtnewleaf(oset) /* return new leaf node for object set */ |
41 |
OBJECT *oset; |
42 |
43 |
register QUADTREE osi; |
44 |
45 |
if (*oset <= 0) |
46 |
return(EMPTY); /* should be error? */ |
47 |
if (qtfreesets != EMPTY) { |
48 |
osi = qtfreesets; |
49 |
qtfreesets = (int)qtsettab[osi]; |
50 |
} else if ((osi = qtnumsets++) % QTSETIBLK == 0) { |
51 |
qtsettab = (OBJECT **)realloc((char *)qtsettab, |
52 |
(unsigned)(osi+QTSETIBLK)*sizeof(OBJECT *)); |
53 |
if (qtsettab == NULL) |
54 |
goto memerr; |
55 |
qtsetflag = (int4 *)realloc((char *)qtsetflag, |
56 |
FLAG_BYTES(osi+ QTSETIBLK)); |
57 |
if (qtsetflag == NULL) |
58 |
goto memerr; |
59 |
if(qtallocsets) |
60 |
bzero((char *)((char *)(qtsetflag)+FLAG_BYTES(qtallocsets)), |
61 |
FLAG_BYTES(osi+QTSETIBLK)-FLAG_BYTES(qtallocsets)); |
62 |
else |
63 |
bzero((char *)(qtsetflag),FLAG_BYTES(osi +QTSETIBLK)); |
64 |
65 |
qtallocsets = osi + QTSETIBLK; |
66 |
67 |
qtsettab[osi] = (OBJECT *)malloc(QTNODESIZ(*oset)*sizeof(OBJECT)); |
68 |
if (qtsettab[osi] == NULL) |
69 |
goto memerr; |
70 |
setcopy(qtsettab[osi], oset); |
71 |
return(QT_INDEX(osi)); |
72 |
memerr: |
73 |
error(SYSTEM, "out of memory in qtnewleaf\n"); |
74 |
75 |
76 |
77 |
78 |
QUADTREE |
79 |
qtdelelem(qt, id) /* delete element from leaf node */ |
80 |
QUADTREE qt; |
81 |
OBJECT id; |
82 |
83 |
register QUADTREE lf; |
84 |
#ifdef DEBUG |
85 |
if(id < 0) |
86 |
eputs("qtdelelem():Invalid triangle id\n"); |
87 |
if (!QT_IS_LEAF(qt) || (lf = QT_SET_INDEX(qt)) >= qtnumsets) |
88 |
error(CONSISTENCY, "empty/bad node in qtdelelem"); |
89 |
#else |
90 |
lf = QT_SET_INDEX(qt); |
91 |
#endif |
92 |
93 |
if (!inset(qtsettab[lf], id)) |
94 |
95 |
#ifdef DEBUG |
96 |
eputs("id not in leaf in qtdelelem\n"); |
97 |
#endif |
98 |
return(qt); |
99 |
100 |
if (qtsettab[lf][0] <= 1) { /* blow leaf away */ |
101 |
free((char *)qtsettab[lf]); |
102 |
qtsettab[lf] = (OBJECT *)qtfreesets; |
103 |
qtfreesets = lf; |
104 |
return(EMPTY); |
105 |
106 |
deletelem(qtsettab[lf], id); |
107 |
if (QTONTHRESH(qtsettab[lf][0])) |
108 |
qtsettab[lf] = (OBJECT *)realloc((char *)qtsettab[lf], |
109 |
QTNODESIZ(qtsettab[lf][0])*sizeof(OBJECT)); |
110 |
return(qt); |
111 |
112 |
113 |
114 |
QUADTREE |
115 |
qtaddelem(qt, id) /* add element to leaf node */ |
116 |
QUADTREE qt; |
117 |
OBJECT id; |
118 |
119 |
OBJECT newset[2]; |
120 |
121 |
122 |
#ifdef DEBUG |
123 |
if(id < 0) |
124 |
eputs("qtaddelem():Invalid triangle id\n"); |
125 |
#endif |
126 |
if (QT_IS_EMPTY(qt)) { /* create new leaf */ |
127 |
newset[0] = 1; newset[1] = id; |
128 |
return(qtnewleaf(newset)); |
129 |
} /* else add element */ |
130 |
#ifdef DEBUG |
131 |
132 |
error(CONSISTENCY, "bad node in qtaddelem"); |
133 |
#else |
134 |
135 |
#endif |
136 |
137 |
if (inset(qtsettab[lf], id)) |
138 |
139 |
#ifdef DEBUG |
140 |
eputs("id already in leaf in qtaddelem\n"); |
141 |
#endif |
142 |
return(qt); |
143 |
144 |
if (QTONTHRESH(qtsettab[lf][0])) { |
145 |
146 |
QTNODESIZ(qtsettab[lf][0]+1)*sizeof(OBJECT)); |
147 |
if (qtsettab[lf] == NULL) |
148 |
error(SYSTEM, "out of memory in qtaddelem"); |
149 |
150 |
insertelem(qtsettab[lf], id); |
151 |
return(qt); |
152 |
153 |
154 |
#define insertuelem(os,id) ((os)[++((os)[0])] = (id)) |
155 |
156 |
int |
157 |
qtcompressuelem(qt,compress_set) |
158 |
QUADTREE qt; |
159 |
int (*compress_set)(); |
160 |
161 |
162 |
int i,j,osize; |
163 |
OBJECT *os; |
164 |
165 |
if(QT_IS_EMPTY(qt)) |
166 |
return(qt); |
167 |
#ifdef DEBUG |
168 |
169 |
170 |
#else |
171 |
172 |
#endif |
173 |
os = qtsettab[lf]; |
174 |
osize = os[0]; |
175 |
if((i=compress_set(os)) < osize) |
176 |
177 |
178 |
QTNODESIZ(i+1)*sizeof(OBJECT)); |
179 |
180 |
181 |
182 |
return(qt); |
183 |
184 |
185 |
186 |
QUADTREE |
187 |
qtadduelem(qt, id) /* add element to unsorted leaf node */ |
188 |
QUADTREE qt; |
189 |
OBJECT id; |
190 |
191 |
OBJECT newset[2]; |
192 |
193 |
194 |
#ifdef DEBUG |
195 |
if(id < 0) |
196 |
197 |
#endif |
198 |
199 |
200 |
201 |
202 |
#ifdef DEBUG |
203 |
204 |
205 |
#else |
206 |
207 |
#endif |
208 |
209 |
210 |
211 |
212 |
213 |
214 |
insertuelem(qtsettab[lf], id); |
215 |
return(qt); |
216 |
217 |
218 |
219 |
#ifdef DEBUG |
220 |
OBJECT * |
221 |
qtqueryset(qt) /* return object set for leaf node */ |
222 |
QUADTREE qt; |
223 |
224 |
225 |
226 |
227 |
error(CONSISTENCY, "bad node in qtqueryset"); |
228 |
return(qtsettab[lf]); |
229 |
230 |
#endif |
231 |
232 |
int |
233 |
qtinuset(qt,id) |
234 |
QUADTREE qt; |
235 |
OBJECT id; |
236 |
237 |
OBJECT *os; |
238 |
int i; |
239 |
240 |
os = qtqueryset(qt); |
241 |
for(i=os[0],os++; i > 0; i--,os++) |
242 |
if(*os==id) |
243 |
return(1); |
244 |
245 |
return(0); |
246 |
247 |
248 |
249 |
qtfreeleaf(qt) /* free set and leaf node */ |
250 |
QUADTREE qt; |
251 |
252 |
253 |
254 |
if (!QT_IS_LEAF(qt)) |
255 |
return; |
256 |
osi = QT_SET_INDEX(qt); |
257 |
if (osi >= qtnumsets) |
258 |
return; |
259 |
free((char *)qtsettab[osi]); |
260 |
qtsettab[osi] = (OBJECT *)qtfreesets; |
261 |
qtfreesets = osi; |
262 |
263 |
264 |
265 |
266 |
qtfreeleaves() /* free ALL sets and leaf nodes */ |
267 |
268 |
register int i; |
269 |
270 |
while ((i = qtfreesets) != EMPTY) { |
271 |
qtfreesets = (int)qtsettab[i]; |
272 |
qtsettab[i] = NULL; |
273 |
274 |
for (i = qtnumsets; i--; ) |
275 |
if (qtsettab[i] != NULL) |
276 |
free((char *)qtsettab[i]); |
277 |
free((char *)qtsettab); |
278 |
qtsettab = NULL; |
279 |
if(qtsetflag) |
280 |
281 |
free((char *)qtsetflag); |
282 |
qtsetflag=0; |
283 |
284 |
qtnumsets = 0; |
285 |
286 |
287 |
288 |
/* no bounds on os csptr. This routine is conservative: the result returned |
289 |
in os is the set intersection, and therefore is bounded by the size of os. |
290 |
cs is bound to be <= QT_MAXCSET |
291 |
292 |
check_set_large(os, cs) /* modify checked set and set to check */ |
293 |
register OBJECT *os; /* os' = os - cs */ |
294 |
register OBJECT *cs; /* cs' = cs + os */ |
295 |
296 |
OBJECT cset[QT_MAXCSET+1]; |
297 |
register int i, j; |
298 |
int k; |
299 |
/* copy os in place, cset <- cs */ |
300 |
301 |
cset[0] = 0; |
302 |
k = 0; |
303 |
for (i = j = 1; i <= os[0]; i++) { |
304 |
while (j <= cs[0] && cs[j] < os[i]) |
305 |
if(cset[0] < QT_MAXCSET) |
306 |
cset[++cset[0]] = cs[j++]; |
307 |
else |
308 |
j++; |
309 |
if (j > cs[0] || os[i] != cs[j]) { /* object to check */ |
310 |
os[++k] = os[i]; |
311 |
312 |
cset[++cset[0]] = os[i]; |
313 |
314 |
315 |
if (!(os[0] = k)) /* new "to check" set size */ |
316 |
return; /* special case */ |
317 |
318 |
while (j <= cs[0]) /* get the rest of cs */ |
319 |
if(cset[0] == QT_MAXCSET) |
320 |
break; |
321 |
else |
322 |
323 |
324 |
os = cset; /* copy cset back to cs */ |
325 |
for (i = os[0]; i-- >= 0; ) |
326 |
*cs++ = *os++; |
327 |
328 |
329 |
330 |
331 |
332 |
